[petsc-dev] 6-node wedge cells in DMPlex
Adrian Croucher
a.croucher at auckland.ac.nz
Wed Jan 25 23:12:29 CST 2017
hi Matt,
A couple of years ago we discussed adding support for 6-node wedge cells
in DMPlex- the hurdle being that at present DMPlex doesn't support cells
with faces of different shapes (see below)- and you said it could be
done, if and when I needed it.
People are starting to want to use my code on real models now, many of
which have 6-node wedge cells. So it would be very handy to have support
for those in DMPlex fairly soon if possible.
Any chance you would be able to take a look at it? In principle I would
be happy to help if I can. I have started looking at plexinterpolate.c
to try and see how it works, but at this stage I'm not at all confident
that I understand the subtleties.
Cheers, Adrian
On 16/04/14 08:42, Matthew Knepley wrote:
>> Yeah, I was afraid that might be the workaround ;-) It seems to me
>> that for a large unstructured mesh, creating the whole DAG would
>> basically amount to duplicating what the very handy
>> DMPlexInterpolate() function does.
>>> The problem here is that if I allow faces of different shapes, I
>>> have to keep track of the shape of each
>>> face when I make it. This is possible, and I have added it to the
>>> TODO list, but I think it will be a while
>>> before I get to it. If you want to try doing it, I would help.
>> I'd have to get more familiar with how it works first, and it
>> probably isn't top of my priority list either at present- I can
>> continue getting my code together without support for wedge cells at
>> the moment. But at some point I will need it.
> Okay, when you need it, we will make it work.
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170126/bce5068d/attachment.html>
