[petsc-dev] REPLACE for tests
    Matthew Knepley
    knepley at gmail.com
    Wed Jan 25 17:22:33 CST 2017
Does not seem to work in master:
 1knepley/feature-plex-tests-new +$|MERGING:/PETSc3/petsc/petsc-dev$
PETSC_ARCH=arch-c-exodus-master make -f gmakefile test
search=ts_tutorials-runex48% REPLACE=1
        TEST ts_tutorials-runex48_0
ok ts_tutorials-ex48_0
not ok diff-ts_tutorials-ex48_0
# Error! file1 check failed:
/PETSc3/petsc/petsc-dev/src/ts/examples/tutorials/output/ex48_0.out
#   Summary
# FAILED diff-ts_tutorials-ex48_0
# success 1/2 tests (50.0%)
# failed 1/2 tests (50.0%)
# todo 0/2 tests (0.0%)
# skip 0/2 tests (0.0%)
knepley/feature-plex-tests-new +$|MERGING:/PETSc3/petsc/petsc-dev$ ls
ls src/ts/examples/tutorials/output/ex48_0.out
ls: src/ts/examples/tutorials/output/ex48_0.out: No such file or directory
     Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170125/a48a9f57/attachment.html>
