[petsc-dev] Fwd: no petsc on Edison
    Mark Adams
    mfadams at lbl.gov
    Wed Jan 25 18:36:21 CST 2017
On Wed, Jan 25, 2017 at 6:26 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Ah - you are using 2016-12-21 snapshot - not 'from earlier this week'
> Do you have this issue with latest maint?
Treb, I think you used the wrong PETSC_DIR, there is no 3.7 anymore:
make PETSC_DIR=/global/homes/m/madams/petsc_install/petsc-xc30-dbg64-intel
PETSC_ARCH=""
> Satish
> On Wed, 25 Jan 2017, Satish Balay wrote:
> > Can you revert 33ba5e2fdab343b05366fddedfd8875376f7a774 - or go to a
> > snapshot before it - i.e 45d00d1deaa098115194142a3d0598148b5952ec -
> > and see if that works?
> > Satish
> > On Wed, 25 Jan 2017, Mark Adams wrote:
> > > We are still having problems with the large hash value. This should be
> with
> > > maint from earlier this week: v3.7.4-2584-g7175242.
> > > [2998]PETSC ERROR: --------------------- Error Message
> > > [2998]PETSC ERROR: Argument out of range
> > > [2998]PETSC ERROR: A really huge hash is being requested.. cannot
> process:
> > > 1073741824
> > > [2998]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d
> ocumentation/faq.html
> > > for trouble shooting.
> > > [2998]PETSC ERROR: Petsc Development GIT revision: v3.7.4-2584-g7175242
> > >  GIT Date: 2016-12-21 13:19:16 -0600
> > > [2998]PETSC ERROR: /tmp/targetExec on a arch-xc30-dbg64-intel named
> > > nid00718 by u6338 Tue Jan 24 23:55:02 2017
> > > [2998]PETSC ERROR: Configure options --COPTFLAGS="-O0 -g -no-ipo"
> > > --CXXOPTFLAGS="-O0 -g -no-ipo" --FOPTFLAGS="-O0 -g -ipo"
> > > --download-parmetis --download-metis --download-hypre --with-ssl=0
> > > --with-cc=cc --with-clib-autodetect=0 --with-cxx=CC
> > > --with-cxxlib-autodetect=0 --with-debugging=1 --with-fc=ftn
> > > --with-fortranlib-autodetect=0 --with-shared-libraries=0 --with-x=0
> > > --with-mpiexec=srun LIBS=-lstdc++ --with-64-bit-indices
> > > --prefix=/global/homes/m/madams/pets[3357]
> MatStashScatterBegin_Ref(): No
> > > of messages: 0
> > > [3357] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > [2993] MatStashScatterBegin_Ref(): No of messages: 0
> > > [2993] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > > c_install/petscv3.7-xc30-dbg64-intel PETSC_ARCH=arch-xc30-dbg64-intel
> > > PETSC_DIR=/global/u2/m/madams/petsc_install/petsc
> > > [2998]PETSC ERROR: #1 PetscTableCreateHashSize() line 28 in
> > > /global/u2/m/madams/petsc_install/petsc/src/sys/utils/ctable.c
> > > [2998]PETSC ERROR: #2 PetscTableCreate() line 52 in
> > > [2998]PETSC ERROR: #3 MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ()
> line 1691
> > > in
> > > /global/u2/m/madams/petsc_install/petsc/src/mat/impls/aij/
> mpi/mpimatmatmult.c
> > > [2998]PETSC ERROR: #4 MatTransposeMatMult_MPIAIJ_MPIAIJ() line 917 in
> mpi/mpimatmatmult.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170125/d177ba5f/attachment.html>
