[petsc-dev] Fwd: no petsc on Edison
    Hong
    hzhang at mcs.anl.gov
    Thu Jan 26 10:23:46 CST 2017
Mark:
>> > > [2998]PETSC ERROR: #2 PetscTableCreate() line 52 in
>> > > /global/u2/m/madams/petsc_install/petsc/src/sys/utils/ctable.c
>> > > [2998]PETSC ERROR: #3 MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ()
>> line 1691
 MatTransposeMatMult() tends to use much larger ctable than MatMatMult.
Is your matrix symmetric? If so, MatMatMult() will use smaller ctable and
require less communication.
Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170126/a70682c8/attachment.html>
