[petsc-dev] Fwd: no petsc on Edison
    Satish Balay
    balay at mcs.anl.gov
    Wed Jan 25 17:26:24 CST 2017
Ah - you are using 2016-12-21 snapshot - not 'from earlier this week'
Do you have this issue with latest maint?
Satish
On Wed, 25 Jan 2017, Satish Balay wrote:
> Can you revert 33ba5e2fdab343b05366fddedfd8875376f7a774 - or go to a
> snapshot before it - i.e 45d00d1deaa098115194142a3d0598148b5952ec -
> and see if that works?
> Satish
> On Wed, 25 Jan 2017, Mark Adams wrote:
> > We are still having problems with the large hash value. This should be with
> > maint from earlier this week: v3.7.4-2584-g7175242.
> > [2998]PETSC ERROR: --------------------- Error Message
> > [2998]PETSC ERROR: Argument out of range
> > [2998]PETSC ERROR: A really huge hash is being requested.. cannot process:
> > 1073741824
> > [2998]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> > for trouble shooting.
> > [2998]PETSC ERROR: Petsc Development GIT revision: v3.7.4-2584-g7175242
> >  GIT Date: 2016-12-21 13:19:16 -0600
> > [2998]PETSC ERROR: /tmp/targetExec on a arch-xc30-dbg64-intel named
> > nid00718 by u6338 Tue Jan 24 23:55:02 2017
> > [2998]PETSC ERROR: Configure options --COPTFLAGS="-O0 -g -no-ipo"
> > --CXXOPTFLAGS="-O0 -g -no-ipo" --FOPTFLAGS="-O0 -g -ipo"
> > --download-parmetis --download-metis --download-hypre --with-ssl=0
> > --with-cc=cc --with-clib-autodetect=0 --with-cxx=CC
> > --with-cxxlib-autodetect=0 --with-debugging=1 --with-fc=ftn
> > --with-fortranlib-autodetect=0 --with-shared-libraries=0 --with-x=0
> > --with-mpiexec=srun LIBS=-lstdc++ --with-64-bit-indices
> > --prefix=/global/homes/m/madams/pets[3357] MatStashScatterBegin_Ref(): No
> > of messages: 0
> > [3357] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > [2993] MatStashScatterBegin_Ref(): No of messages: 0
> > [2993] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
> > c_install/petscv3.7-xc30-dbg64-intel PETSC_ARCH=arch-xc30-dbg64-intel
> > PETSC_DIR=/global/u2/m/madams/petsc_install/petsc
> > [2998]PETSC ERROR: #1 PetscTableCreateHashSize() line 28 in
> > /global/u2/m/madams/petsc_install/petsc/src/sys/utils/ctable.c
> > [2998]PETSC ERROR: #2 PetscTableCreate() line 52 in
> > [2998]PETSC ERROR: #3 MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1691
> > in
> > /global/u2/m/madams/petsc_install/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c
> > [2998]PETSC ERROR: #4 MatTransposeMatMult_MPIAIJ_MPIAIJ() line 917 in
