[petsc-dev] Introducing new "test harness" to PETSc
Wed Jan 18 13:44:27 CST 2017
On Wed, Jan 18, 2017 at 1:43 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jan 17, 2017 at 8:54 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Matthew Knepley <knepley at gmail.com> writes:
>> > Gripes:
>> >   1) How do I run an individual test run?
>>   make -f gmakefile sys_tutorials-runex5
>> (tab completion works) or use a search that matches only that run.
>> > I use
>> >   make -f gmakefile test searchin=plex
>> > to run plex tests, and I think
>> >   make -f gmakefile test searchin=plex*ex1
>> Due to make syntax, % is the internal string matcher.
>> > will work. However, how do I select ex1_2?
>>   make -f gmakefile test search=plex%ex1_2
> This does not work
> knepley/fix-configure-pragmatic *+$:/PETSc3/petsc/petsc-dev$ make -f
> # No tests run
>     Matt
>> >   2) How do I replace the output which exists with the output of the
>> > current test run?
>> > This is amazingly useful after changes.
>> I have this script ~/bin/diffupdate:
>> #!/bin/sh
>> args=
>> if [ "$1" = "-u" ]; then
>>     args="-u"
>>     shift
>> fi
>> new="$2"
>> ref="$1"
>> diff $args "$ref" "$new"
>> ret=$?
>> echo "Updating $new --> $ref"
>> mv "$new" "$ref"
>> exit $ret
>> Then I run
>>   make -f gmakefile test search=plex% DIFF=diffupdate
>> It prints the diff and replaces the reference file (first argument) with
>> the second.
>> >   3) How do I give extra arguments with the make interface, rather than
>> > test_harness?
>> That is, run some modification of the test and still do the diff, but
>> don't change the reference output?  I have used PETSC_OPTIONS for that.
>>   make .... PETSC_OPTIONS=-more_magic
This is not alright since I already have options there, like -malloc_test
which I want.
   Matt
> > Once I have all the functionality of my Python stuff,  I will throw it
>> away.
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170118/01a06c65/attachment.html>
