[petsc-dev] Introducing new "test harness" to PETSc
Matthew Knepley
knepley at gmail.com
Wed Jan 18 13:43:34 CST 2017
On Tue, Jan 17, 2017 at 8:54 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > Gripes:
> > 1) How do I run an individual test run?
> make -f gmakefile sys_tutorials-runex5
> (tab completion works) or use a search that matches only that run.
> > I use
> > make -f gmakefile test searchin=plex
> > to run plex tests, and I think
> > make -f gmakefile test searchin=plex*ex1
> Due to make syntax, % is the internal string matcher.
> > will work. However, how do I select ex1_2?
> make -f gmakefile test search=plex%ex1_2
This does not work
knepley/fix-configure-pragmatic *+$:/PETSc3/petsc/petsc-dev$ make -f
# No tests run
Matt
> > 2) How do I replace the output which exists with the output of the
> > current test run?
> > This is amazingly useful after changes.
> I have this script ~/bin/diffupdate:
> #!/bin/sh
> args=
> if [ "$1" = "-u" ]; then
> args="-u"
> shift
> fi
> new="$2"
> ref="$1"
> diff $args "$ref" "$new"
> ret=$?
> echo "Updating $new --> $ref"
> mv "$new" "$ref"
> exit $ret
> Then I run
> make -f gmakefile test search=plex% DIFF=diffupdate
> It prints the diff and replaces the reference file (first argument) with
> the second.
> > 3) How do I give extra arguments with the make interface, rather than
> > test_harness?
> That is, run some modification of the test and still do the diff, but
> don't change the reference output? I have used PETSC_OPTIONS for that.
> make .... PETSC_OPTIONS=-more_magic
> > Once I have all the functionality of my Python stuff, I will throw it
> away.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170118/d3cec77a/attachment.html>
