[petsc-dev] Introducing new "test harness" to PETSc
Scott Kruger kruger at txcorp.com
Wed Jan 18 14:05:21 CST 2017
> This does not work
> knepley/fix-configure-pragmatic *+$:/PETSc3/petsc/petsc-dev$ make -f
> gmakefile test search=plex%ex1_2
> make -f gmakefile test search=plex%ex1_2
> # No tests run
If you replace test with "echo_test" as a target it will echo all of the
targets.  This is useful for debugging.
make -f gmakefile echo_test search=plex%
and then make sure you see it.
Then do an echo_test to see the match.
Here is an example with the current version:
 > make -f gmakefile echo_test search=sys%
sys_tests-runex19 sys_tests-runex10 sys_tests-runex11 sys_tests-runex12
sys_tests-runex14 sys_tests-runex31 sys_tests-runex31_2
sys_tests-runex20_2 sys_tests-runex20_3 sys_tutorials-runex9_2 ...
 > make -f gmakefile echo_test search=sys%ex9_2
>     >   3) How do I give extra arguments with the make interface, rather than
>     > test_harness?
>     That is, run some modification of the test and still do the diff, but
>     don't change the reference output?  I have used PETSC_OPTIONS for that.
>       make .... PETSC_OPTIONS=-more_magic
I'm not sure I 100% understand what is being asked (perhaps it's my cold
medicine), but I think TESTFLAGS does what you want; e.g.,
 > make -f gmakefile test search=sys%ex9_2 TESTFLAGS="-h"
         TEST sys_tutorials-runex9_2
Usage: arch-osx-xsdk-opt/tests/src/sys/examples/tutorials/runex9_2.sh
[options]
OPTIONS
   -a <args> ......... Override default arguments
   -c <cleanup> ...... Cleanup (remove generated files)
   -e <args> ......... Add extra arguments to default
   -h ................ help: print this message
   -n <integer> ...... Override the number of processors to use
   -o <output file> .. Override default output file to diff with
   -t <testname> ..... Override test name
   -v ................ Verbose: Print commands
# No tests run
>     > Once I have all the functionality of my Python stuff,  I will
>     throw it away.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
Boulder, CO 80303                Fax:   (303) 448-7756
