[petsc-dev] Introducing new "test harness" to PETSc
Scott Kruger
kruger at txcorp.com
Tue Jan 17 18:27:46 CST 2017
I think this is more YAML compliant as you can do this:
args: -foo # Foo test
--- a/config/testparse.py
+++ b/config/testparse.py
@@ -59,6 +59,7 @@ def _stripIndent(block,srcfile):
ext=os.path.splitext(srcfile)[1]
for lline in block.split("\n"):
line=lline[1:] if lline.startswith("!") else lline
+ line=line.split('#')[0]
if not line.strip(): continue
stripstr=" "
nspace=len(line)-len(line.lstrip(stripstr))
@@ -70,6 +71,7 @@ def _stripIndent(block,srcfile):
newTestStr="\n"
newline=line[nspace:]
newTestStr=newTestStr+newline.rstrip()+"\n"
On 1/17/17 5:11 PM, Matthew Knepley wrote:
> On Tue, Jan 17, 2017 at 6:08 PM, Barry Smith <bsmith at mcs.anl.gov
> <mailto:bsmith at mcs.anl.gov>> wrote:
> Comments would be a new feature so belong in a new branch, so
> create a branch off of master, call it say
> scott/test-harness-comments then after you tested it (by adding at
> least one comment to a current example) and then make a pull request
> and we can get it into master very quickly.
> This works
> @@ -98,6 +98,7 @@ def parseTest(testStr,srcfile):
> subdict={}
> for line in striptest.split("\n"):
> + if len(line.split(":")) < 2: continue
> var=line.split(":")[0].strip()
> val=line.split(":")[1].strip()
> # Start by seeing if we are in a subtest
> Matt
> Barry
> > On Jan 17, 2017, at 5:29 PM, Scott Kruger <kruger at txcorp.com
> <mailto:kruger at txcorp.com>> wrote:
> > The "This" is not at the same indentation level as the "test:"
> > According the YAML standard, comments begin with #.
> > I did not implement comments.
> > Where do you want the fix pushed?
> > Scott
> > On 1/17/17 4:19 PM, Barry Smith wrote:
> >> I don't see any difference in the spacing between the two
> cases? We definitely don't want white space or lack of white space
> to matter in the definitions, that is too hard to manage.
> >>> On Jan 17, 2017, at 5:04 PM, Scott Kruger <kruger at txcorp.com
> >>> It has to do with the spacing. Looking at
> src/sys/examples/test/ex1.c
> >>> This works:
> >>> /*TEST
> >>> This test does foo
> >>> test:
> >>> filter: egrep "(PETSC ERROR)" | egrep
> "(main|CreateError|Error Created)" | cut -f1,2,3,4,5,6 -d" "
> >>> TEST*/
> >>> which I can see by doing this:
> >>> gabrielle 81: ../../../../config/testparse.py -t ex1.c -v 1
> >>> ex1.c
> >>> runex1
> >>> but this does not:
> >>> /*TEST
> >>> This test does foo
> >>> test:
> >>> TEST*/
> >>> I would suggest that using # as a comment delimiter would be the
> best approach to enabling comments.
> >>> Scott
> >>> On 1/17/17 3:53 PM, Matthew Knepley wrote:
> >>>> On Tue, Jan 17, 2017 at 4:31 PM, Satish Balay
> <balay at mcs.anl.gov <mailto:balay at mcs.anl.gov>
> >>>> <mailto:balay at mcs.anl.gov <mailto:balay at mcs.anl.gov>>> wrote:
> >>>> On Tue, 17 Jan 2017, Matthew Knepley wrote:
> >>>> > Also, how do I put comments inside these blocks to tell me
> what the test is
> >>>> > about?
> >>>> Looks like everything other than the define format is ignored..
> >>>> It does not look that way to me:
> >>>> /usr/bin/python ./config/gmakegentest.py
> --petsc-arch=arch-c-exodus-master
> >>>> Traceback (most recent call last):
> >>>> File "./config/gmakegentest.py", line 733, in <module>
> >>>> main(petsc_arch=opts.petsc_arch, output=opts.output,
> >>>> verbose=opts.verbose, single_ex=opts.single_executable)
> >>>> File "./config/gmakegentest.py", line 718, in main
> dataDict=pEx.walktree(os.path.join(pEx.petsc_dir,'src'),action="genPetscTests")
> >>>> File "./config/gmakegentest.py", line 613, in walktree
> >>>> eval("self."+action+"(root,dirs,files,dataDict)")
> >>>> File "<string>", line 1, in <module>
> >>>> File "./config/gmakegentest.py", line 593, in genPetscTests
> >>>> dataDict[root].update(testparse.parseTestFile(fullex))
> >>>> File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 175, in
> >>>> parseTestFile
> >>>> testDict[basename]=parseTests(testString,srcfile)
> >>>> File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 140, in
> >>>> parseTests
> >>>> testname,subdict=parseTest(test,srcfile)
> >>>> File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 102,
> in parseTest
> >>>> IndexError: list index out of range
> >>>> Matt
> >>>> Satish
> >>>> What most experimenters take for granted before they begin their
> >>>> experiments is infinitely more interesting than any results to
> which
> >>>> their experiments lead.
> >>>> -- Norbert Wiener
> >>> Tech-X Corporation kruger at txcorp.com
> >>> 5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
> <tel:%28720%29%20974-1841>
> >>> Boulder, CO 80303 Fax: (303) 448-7756
> <tel:%28303%29%20448-7756>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
