[petsc-dev] Introducing new "test harness" to PETSc
Matthew Knepley
knepley at gmail.com
Tue Jan 17 18:11:18 CST 2017
On Tue, Jan 17, 2017 at 6:08 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Comments would be a new feature so belong in a new branch, so create a
> branch off of master, call it say
> scott/test-harness-comments then after you tested it (by adding at least
> one comment to a current example) and then make a pull request and we can
> get it into master very quickly.
This works
--- a/config/testparse.py
+++ b/config/testparse.py
@@ -98,6 +98,7 @@ def parseTest(testStr,srcfile):
subdict={}
for line in striptest.split("\n"):
if not line.strip(): continue
+ if len(line.split(":")) < 2: continue
var=line.split(":")[0].strip()
val=line.split(":")[1].strip()
# Start by seeing if we are in a subtest
Matt
> Barry
> > On Jan 17, 2017, at 5:29 PM, Scott Kruger <kruger at txcorp.com> wrote:
> > The "This" is not at the same indentation level as the "test:"
> > According the YAML standard, comments begin with #.
> > I did not implement comments.
> > Where do you want the fix pushed?
> > Scott
> > On 1/17/17 4:19 PM, Barry Smith wrote:
> >> I don't see any difference in the spacing between the two cases? We
> definitely don't want white space or lack of white space to matter in the
> definitions, that is too hard to manage.
> >>> On Jan 17, 2017, at 5:04 PM, Scott Kruger <kruger at txcorp.com> wrote:
> >>> It has to do with the spacing. Looking at src/sys/examples/test/ex1.c
> >>> This works:
> >>> /*TEST
> >>> This test does foo
> >>> test:
> >>> filter: egrep "(PETSC ERROR)" | egrep "(main|CreateError|Error
> Created)" | cut -f1,2,3,4,5,6 -d" "
> >>> TEST*/
> >>> which I can see by doing this:
> >>> gabrielle 81: ../../../../config/testparse.py -t ex1.c -v 1
> >>> ex1.c
> >>> runex1
> >>> but this does not:
> >>> /*TEST
> >>> This test does foo
> >>> test:
> >>> TEST*/
> >>> I would suggest that using # as a comment delimiter would be the best
> approach to enabling comments.
> >>> Scott
> >>> On 1/17/17 3:53 PM, Matthew Knepley wrote:
> >>>> On Tue, Jan 17, 2017 at 4:31 PM, Satish Balay <balay at mcs.anl.gov
> >>>> <mailto:balay at mcs.anl.gov>> wrote:
> >>>> On Tue, 17 Jan 2017, Matthew Knepley wrote:
> >>>> > Also, how do I put comments inside these blocks to tell me what
> the test is
> >>>> > about?
> >>>> Looks like everything other than the define format is ignored..
> >>>> It does not look that way to me:
> >>>> /usr/bin/python ./config/gmakegentest.py --petsc-arch=arch-c-exodus-
> master
> >>>> Traceback (most recent call last):
> >>>> File "./config/gmakegentest.py", line 733, in <module>
> >>>> main(petsc_arch=opts.petsc_arch, output=opts.output,
> >>>> verbose=opts.verbose, single_ex=opts.single_executable)
> >>>> File "./config/gmakegentest.py", line 718, in main
> >>>> dataDict=pEx.walktree(os.path.join(pEx.petsc_dir,'src'),
> action="genPetscTests")
> >>>> File "./config/gmakegentest.py", line 613, in walktree
> >>>> eval("self."+action+"(root,dirs,files,dataDict)")
> >>>> File "<string>", line 1, in <module>
> >>>> File "./config/gmakegentest.py", line 593, in genPetscTests
> >>>> dataDict[root].update(testparse.parseTestFile(fullex))
> >>>> File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 175, in
> >>>> parseTestFile
> >>>> testDict[basename]=parseTests(testString,srcfile)
> >>>> File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 140, in
> >>>> parseTests
> >>>> testname,subdict=parseTest(test,srcfile)
> >>>> File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 102, in
> parseTest
> >>>> IndexError: list index out of range
> >>>> Matt
> >>>> Satish
> >>>> What most experimenters take for granted before they begin their
> >>>> experiments is infinitely more interesting than any results to which
> >>>> their experiments lead.
> >>>> -- Norbert Wiener
> >>> Tech-X Corporation kruger at txcorp.com
> >>> 5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
> >>> Boulder, CO 80303 Fax: (303) 448-7756
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170117/9a558b93/attachment.html>
