[petsc-dev] Introducing new "test harness" to PETSc
    Matthew Knepley
    knepley at gmail.com
    Tue Jan 17 19:33:43 CST 2017
On Tue, Jan 17, 2017 at 6:27 PM, Scott Kruger <kruger at txcorp.com> wrote:
> I think this is more YAML compliant as you can do this:
We need another parser fix:
  test:
    suffix: 2
    args: -dim 2 -dm_view ::ascii_latex
    Matt
>    args: -foo     # Foo test
> --- a/config/testparse.py
> +++ b/config/testparse.py
> @@ -59,6 +59,7 @@ def _stripIndent(block,srcfile):
>    ext=os.path.splitext(srcfile)[1]
>    for lline in block.split("\n"):
>      line=lline[1:] if lline.startswith("!") else lline
> +    line=line.split('#')[0]
>      if not line.strip(): continue
>      stripstr=" "
>      nspace=len(line)-len(line.lstrip(stripstr))
> @@ -70,6 +71,7 @@ def _stripIndent(block,srcfile):
>    newTestStr="\n"
>      newline=line[nspace:]
>      newTestStr=newTestStr+newline.rstrip()+"\n"
> On 1/17/17 5:11 PM, Matthew Knepley wrote:
>> On Tue, Jan 17, 2017 at 6:08 PM, Barry Smith <bsmith at mcs.anl.gov
>> <mailto:bsmith at mcs.anl.gov>> wrote:
>>       Comments would be a new feature so belong in a new branch, so
>>     create a branch off of master, call it say
>>     scott/test-harness-comments then after you tested it (by adding at
>>     least one comment to a current example) and then make a pull request
>>     and we can get it into master very quickly.
>> This works
>> @@ -98,6 +98,7 @@ def parseTest(testStr,srcfile):
>>    subdict={}
>>    for line in striptest.split("\n"):
>> +    if len(line.split(":")) < 2: continue
>>      var=line.split(":")[0].strip()
>>      val=line.split(":")[1].strip()
>>      # Start by seeing if we are in a subtest
>>    Matt
>>        Barry
>>     > On Jan 17, 2017, at 5:29 PM, Scott Kruger <kruger at txcorp.com
>>     <mailto:kruger at txcorp.com>> wrote:
>>     > The "This" is not at the same indentation level as the "test:"
>>     > According the YAML standard, comments begin with #.
>>     > I did not implement comments.
>>     > Where do you want the fix pushed?
>>     > Scott
>>     > On 1/17/17 4:19 PM, Barry Smith wrote:
>>     >>   I don't see any difference in the spacing between the two
>>     cases? We definitely don't want white space or lack of white space
>>     to matter in the definitions, that is too hard to manage.
>>     >>> On Jan 17, 2017, at 5:04 PM, Scott Kruger <kruger at txcorp.com
>>     >>> It has to do with the spacing.  Looking at
>>     src/sys/examples/test/ex1.c
>>     >>> This works:
>>     >>> /*TEST
>>     >>>  This test does foo
>>     >>>  test:
>>     >>>     filter: egrep "(PETSC ERROR)" | egrep
>>     "(main|CreateError|Error Created)" | cut -f1,2,3,4,5,6 -d" "
>>     >>> TEST*/
>>     >>> which I can see by doing this:
>>     >>> gabrielle 81: ../../../../config/testparse.py -t ex1.c -v 1
>>     >>> ex1.c
>>     >>>  runex1
>>     >>> but this does not:
>>     >>> /*TEST
>>     >>> This test does foo
>>     >>>  test:
>>     >>> TEST*/
>>     >>> I would suggest that using # as a comment delimiter would be the
>>     best approach to enabling comments.
>>     >>> Scott
>>     >>> On 1/17/17 3:53 PM, Matthew Knepley wrote:
>>     >>>> On Tue, Jan 17, 2017 at 4:31 PM, Satish Balay
>>     <balay at mcs.anl.gov <mailto:balay at mcs.anl.gov>
>>     >>>> <mailto:balay at mcs.anl.gov <mailto:balay at mcs.anl.gov>>> wrote:
>>     >>>>   On Tue, 17 Jan 2017, Matthew Knepley wrote:
>>     >>>>   > Also, how do I put comments inside these blocks to tell me
>>     what the test is
>>     >>>>   > about?
>>     >>>>   Looks like everything other than the define format is ignored..
>>     >>>> It does not look that way to me:
>>     >>>> /usr/bin/python ./config/gmakegentest.py
>>     --petsc-arch=arch-c-exodus-master
>>     >>>> Traceback (most recent call last):
>>     >>>> File "./config/gmakegentest.py", line 733, in <module>
>>     >>>>   main(petsc_arch=opts.petsc_arch, output=opts.output,
>>     >>>> verbose=opts.verbose, single_ex=opts.single_executable)
>>     >>>> File "./config/gmakegentest.py", line 718, in main
>>     dataDict=pEx.walktree(os.path.join(pEx.petsc_dir,'src'),acti
>> on="genPetscTests")
>>     >>>> File "./config/gmakegentest.py", line 613, in walktree
>>     >>>>   eval("self."+action+"(root,dirs,files,dataDict)")
>>     >>>> File "<string>", line 1, in <module>
>>     >>>> File "./config/gmakegentest.py", line 593, in genPetscTests
>>     >>>>   dataDict[root].update(testparse.parseTestFile(fullex))
>>     >>>> File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 175, in
>>     >>>> parseTestFile
>>     >>>>   testDict[basename]=parseTests(testString,srcfile)
>>     >>>> File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 140, in
>>     >>>> parseTests
>>     >>>>   testname,subdict=parseTest(test,srcfile)
>>     >>>> File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 102,
>>     in parseTest
>>     >>>> IndexError: list index out of range
>>     >>>>  Matt
>>     >>>>   Satish
>>     >>>> What most experimenters take for granted before they begin their
>>     >>>> experiments is infinitely more interesting than any results to
>>     which
>>     >>>> their experiments lead.
>>     >>>> -- Norbert Wiener
>>     >>> Tech-X Corporation               kruger at txcorp.com
>>     >>> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
>>     <tel:%28720%29%20974-1841>
>>     >>> Boulder, CO 80303                Fax:   (303) 448-7756
>>     <tel:%28303%29%20448-7756>
>> experiments is infinitely more interesting than any results to which
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170117/02e92f72/attachment.html>
