[petsc-dev] Introducing new "test harness" to PETSc
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Jan 17 18:08:35 CST 2017
  Comments would be a new feature so belong in a new branch, so create a branch off of master, call it say
scott/test-harness-comments then after you tested it (by adding at least one comment to a current example) and then make a pull request and we can get it into master very quickly.
   Barry
> On Jan 17, 2017, at 5:29 PM, Scott Kruger <kruger at txcorp.com> wrote:
> The "This" is not at the same indentation level as the "test:"
> According the YAML standard, comments begin with #.
> I did not implement comments.
> Where do you want the fix pushed?
> Scott
> On 1/17/17 4:19 PM, Barry Smith wrote:
>>   I don't see any difference in the spacing between the two cases? We definitely don't want white space or lack of white space to matter in the definitions, that is too hard to manage.
>>> On Jan 17, 2017, at 5:04 PM, Scott Kruger <kruger at txcorp.com> wrote:
>>> It has to do with the spacing.  Looking at src/sys/examples/test/ex1.c
>>> This works:
>>> /*TEST
>>>  This test does foo
>>>  test:
>>>     filter: egrep "(PETSC ERROR)" | egrep "(main|CreateError|Error Created)" | cut -f1,2,3,4,5,6 -d" "
>>> TEST*/
>>> which I can see by doing this:
>>> gabrielle 81: ../../../../config/testparse.py -t ex1.c -v 1
>>> ex1.c
>>>  runex1
>>> but this does not:
>>> /*TEST
>>> This test does foo
>>>  test:
>>> TEST*/
>>> I would suggest that using # as a comment delimiter would be the best approach to enabling comments.
>>> Scott
>>> On 1/17/17 3:53 PM, Matthew Knepley wrote:
>>>> On Tue, Jan 17, 2017 at 4:31 PM, Satish Balay <balay at mcs.anl.gov
>>>> <mailto:balay at mcs.anl.gov>> wrote:
>>>>   On Tue, 17 Jan 2017, Matthew Knepley wrote:
>>>>   > Also, how do I put comments inside these blocks to tell me what the test is
>>>>   > about?
>>>>   Looks like everything other than the define format is ignored..
>>>> It does not look that way to me:
>>>> /usr/bin/python ./config/gmakegentest.py --petsc-arch=arch-c-exodus-master
>>>> Traceback (most recent call last):
>>>> File "./config/gmakegentest.py", line 733, in <module>
>>>>   main(petsc_arch=opts.petsc_arch, output=opts.output,
>>>> verbose=opts.verbose, single_ex=opts.single_executable)
>>>> File "./config/gmakegentest.py", line 718, in main
>>>> dataDict=pEx.walktree(os.path.join(pEx.petsc_dir,'src'),action="genPetscTests")
>>>> File "./config/gmakegentest.py", line 613, in walktree
>>>>   eval("self."+action+"(root,dirs,files,dataDict)")
>>>> File "<string>", line 1, in <module>
>>>> File "./config/gmakegentest.py", line 593, in genPetscTests
>>>>   dataDict[root].update(testparse.parseTestFile(fullex))
>>>> File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 175, in
>>>> parseTestFile
>>>>   testDict[basename]=parseTests(testString,srcfile)
>>>> File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 140, in
>>>> parseTests
>>>>   testname,subdict=parseTest(test,srcfile)
>>>> File "/PETSc3/petsc/petsc-dev/config/testparse.py", line 102, in parseTest
>>>>   val=line.split(":")[1].strip()
>>>> IndexError: list index out of range
>>>>  Matt
>>>>   Satish
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which
>>>> their experiments lead.
>>>> -- Norbert Wiener
>>> Tech-X Corporation               kruger at txcorp.com
>>> 5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
>>> Boulder, CO 80303                Fax:   (303) 448-7756
