[petsc-dev] Seeking current Eclipse/PETSc developer
Patrick Sanan
patrick.sanan at gmail.com
Sun Jan 15 11:59:00 CST 2017
Thanks! I added a commit, on a branch off of yours, which fixes some
typos here - you could merge this into your branch before merging to
master :https://bitbucket.org/petsc/petsc/commits/9a8de0f383a6aeace4af45b56c77616114a62552
Do you or anyone else know if the "To make PETSc an Eclipse Package"
instructions are stale? It mentions using Mercurial, which I assume
implies implies that it's fairly old.
On Sun, Jan 15, 2017 at 3:39 AM, Zhang, Hong <hongzhang at anl.gov> wrote:
> I am always itching to add something in this section. Finally got the change to do that.
> Since Patrick has already added the part on how to use PETSc with other codes in Eclipse, I prepared a write-up based on my experience of indexing and building just the PETSc code. See
> https://bitbucket.org/petsc/petsc/src/ed945043d5c70928faa72750bc5cf0ad23ecc966/src/docs/tex/manual/part2.tex?at=hongzh%2Fadd-eclipse-instructions&fileviewer=file-view-default#part2.tex-8145
> It was only tested with Eclipse Neon(4.6.2) on Mac. Any feedback/suggestion would be welcome.
> Hong (Mr.)
>> On Jan 7, 2017, at 9:13 AM, Patrick Sanan <patrick.sanan at gmail.com> wrote:
>> Does anyone reading this use Eclipse with PETSc? If so, it would be
>> very helpful to have your input in updating the relevant section of
>> the manual! https://bitbucket.org/petsc/petsc/src/2c3da9953db2152e46e186ff7b209b4a6704b1a0/src/docs/tex/manual/part2.tex?at=master&fileviewer=file-view-default#part2.tex-7978
