[petsc-dev] Seeking current Eclipse/PETSc developer
    Zhang, Hong
    hongzhang at anl.gov
    Sun Jan 15 19:16:49 CST 2017
On Jan 15, 2017, at 11:59 AM, Patrick Sanan <patrick.sanan at gmail.com<mailto:patrick.sanan at gmail.com>> wrote:
Thanks! I added a commit, on a branch off of yours, which fixes some
typos here - you could merge this into your branch before merging to
master :https://bitbucket.org/petsc/petsc/commits/9a8de0f383a6aeace4af45b56c77616114a62552
Thanks for fixing the typos.
Do you or anyone else know if the "To make PETSc an Eclipse Package"
instructions are stale? It mentions using Mercurial, which I assume
implies implies that it's fairly old.
I also think it is too old. Maybe we should remove this paragraph. I can do it if nobody else objects.
Hong (Mr.)
On Sun, Jan 15, 2017 at 3:39 AM, Zhang, Hong <hongzhang at anl.gov<mailto:hongzhang at anl.gov>> wrote:
I am always itching to add something in this section. Finally got the change to do that.
Since Patrick has already added the part on how to use PETSc with other codes in Eclipse, I prepared a write-up based on my experience of indexing and building just the PETSc code. See
https://bitbucket.org/petsc/petsc/src/ed945043d5c70928faa72750bc5cf0ad23ecc966/src/docs/tex/manual/part2.tex?at=hongzh%2Fadd-eclipse-instructions&fileviewer=file-view-default#part2.tex-8145
It was only tested with Eclipse Neon(4.6.2) on Mac. Any feedback/suggestion would be welcome.
Hong (Mr.)
On Jan 7, 2017, at 9:13 AM, Patrick Sanan <patrick.sanan at gmail.com> wrote:
Does anyone reading this use Eclipse with PETSc? If so, it would be
very helpful to have your input in updating the relevant section of
the manual! https://bitbucket.org/petsc/petsc/src/2c3da9953db2152e46e186ff7b209b4a6704b1a0/src/docs/tex/manual/part2.tex?at=master&fileviewer=file-view-default#part2.tex-7978
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170116/6f2a5eea/attachment.html>
