[petsc-dev] Bump MOAB version?
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Mon Feb 20 14:09:50 CST 2017
Toby, sorry about the delay. The tarball corresponding to the commit
f862b4c is available at [1]. I will look into the memory leaks and
submit a separate PR to PETSc. I can also submit an update to MOAB.py
to point to the new hash/tarball once you verify and confirm.
Vijay
[1] ftp://ftp.mcs.anl.gov/pub/fathom/moab-f862b4c.tar.gz
On Wed, Feb 1, 2017 at 8:50 PM, Tobin Isaac <tisaac at uchicago.edu> wrote:
> FYI, the PETSc tests that use MOAB passed using MOAB commit f862b4c on
> my laptop, though when I had mpich debugging on there looks like there
> may have been some memory leaks that don't appear in other PETSc
> tests.  (log attached)
> Cheers,
>   Toby
> On Wed, Feb 01, 2017 at 03:22:18AM +0530, Vijay S. Mahadevan wrote:
>> Toby, thanks for the update. Yes, I recently updated the "petsc"
>> branch in MOAB to make sure that v4.9.2 is merged. Some of these
>> changes are needed for one of my upcoming PR's to improve DMMoab
>> support. I however have been on some international travel and haven't
>> found enough time to take care of this.
>> Iulian, can you create a tarball that corresponds to the HEAD in petsc
>> branch (if not already available from the ftp site) ?
>> Vijay
>> PS: The macports errors are related to ESMF. They have their custom
>> version of MOAB (4.6.x) and so I'm unsure whether the port needs the
>> latest MOAB as its dependency.
>> On Wed, Feb 1, 2017 at 3:07 AM, Tobin Isaac <tisaac at uchicago.edu> wrote:
>> > The commit of MOAB that we use in MAOB.py doesn't compile in gcc6
>> > due to c++14 compatibility issues [1].  I checked out the latest petsc
>> > branch from their repo and it seems to compile.  Can we ask them to
>> > host an updated tarball, too?
>> > [1] https://trac.macports.org/ticket/52427#comment:2
>> >   Toby
