[petsc-dev] Fwd: no petsc on Edison
Mark Adams
mfadams at lbl.gov
Wed Feb 1 22:39:53 CST 2017
We are getting this error on Edison. This problem has run before. This is
using maint from last week.
I recall there are low memory options for mpiptap. I don't think we are
using them.
3404]PETSC ERROR: --------------------- Error Message
[3404]PETSC ERROR: Out of memory. This could be due to allocating
[3404]PETSC ERROR: too large an object or bleeding by not properly
[3404]PETSC ERROR: destroying unneeded objects.
[3404]PETSC ERROR: Memory allocated 0 Memory used by process 2537885696
<(253)%20788-5696>
[3404]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[3404]PETSC ERROR: Memory requested 657532760
[3404]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[3404]PETSC ERROR: Petsc Release Version 3.7.5, unknown
[3404]PETSC ERROR: /tmp/targetExec on a arch-xc30-opt64-intel named
nid00713 by u6338 Wed Feb 1 16:15:09 2017
[3404]PETSC ERROR: Configure options --COPTFLAGS="-fast -no-ipo"
--CXXOPTFLAGS="-fast -no-ipo" --FOPTFLAGS="-fast -no-ipo"
--download-parmetis --download-metis --download-hypre --with-ssl=0
--with-cc=cc --with-clib-autodetect=0 --with-cxx=CC
--with-cxxlib-autodetect=0 --with-debugging=0 --with-fc=ftn
--with-fortranlib-autodetect=0 --with-shared-libraries=0 --with-x=0
--with-mpiexec=srun LIBS=-lstdc++ --with-64-bit-indices
--prefix=/global/homes/m/madams/petsc_install/petsc-xc30-opt64-intel
PETSC_ARCH=arch-xc30-opt64-intel PETSC_DIR=/global/homes/m/mada
[3404]PETSC ERROR: #1 MatMatMultNumeric_SeqAIJ_SeqAIJ() line 187 in
/global/u2/m/madams/petsc_install/petsc/src/mat/impls/aij/seq/matmatmult.c
[3404]PETSC ERROR: #2 MatMatMultNumeric_SeqAIJ_SeqAIJ() line 187 in
[3404]PETSC ERROR: #3 MatPtAPNumeric_MPIAIJ_MPIAIJ() line 557 in
/global/u2/m/madams/petsc_install/petsc/src/mat/impls/aij/mpi/mpiptap.c
[3404]PETSC ERROR: #4 MatPtAP_MPIAIJ_MPIAIJ() line 110 in
[3404]PETSC ERROR: #5 MatPtAP() line 9150 in /global/u2/m/madams/petsc_inst
all/petsc/src/mat/interface/matrix.c
[3404]PETSC ERROR: #6 PCGAMGCreateLevel_GAMG() line 88 in
/global/u2/m/madams/petsc_install/petsc/src/ksp/pc/impls/gamg/gamg.c
[3404]PETSC ERROR: #7 PCSetUp_GAMG() line 611 in
[3404]PETSC ERROR: #8 PCSetUp() line 968 in /global/u2/m/madams/petsc_inst
all/petsc/src/ksp/pc/interface/precon.c
[3404]PETSC ERROR: #9 KSPSetUp() line 390 in /global/u2/m/madams/petsc_inst
all/petsc/src/ksp/ksp/interface/itfunc.c
[3404]PETSC ERROR: #10 KSPSolve() line 599 in /global/u2/m/madams/petsc_inst
[3406]PETSC ERROR: --------------------- Error Message
[3406]PETSC ERROR: Out of memory. This could be due to allocating
[3406]PETSC ERROR: too large an object or bleeding by not properly
[3406]PETSC ERROR: destroying unneeded objects.
[3406]PETSC ERROR: Memory allocated 0 Memory used by process 2603798528
<(260)%20379-8528>
[3406]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[3406]PETSC ERROR: Memory requested 657532760
[3406]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
[3406]PETSC ERROR: Petsc Release Version 3.7.5, unknown
[3406]PETSC ERROR: /tmp/targetExec on a arch-xc30-opt64-intel named
[3406]PETSC ERROR: Configure options --COPTFLAGS="-fast -no-ipo"
PETSC_DIR=/global/homes/m/madams/petsc_[7940]PETSC
ERROR: -
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170201/dd8fcea2/attachment.html>
