[petsc-dev] download problem p4est on Cori at NERSC
Barry Smith
bsmith at mcs.anl.gov
Fri Feb 17 13:02:53 CST 2017
> On Feb 17, 2017, at 12:58 PM, Tobin Isaac <tisaac at uchicago.edu> wrote:
> On Fri, Feb 17, 2017 at 01:28:25PM -0500, Mark Adams wrote:
>> p4est seems to work now, but I am getting a BLAS failure. But I download
>> blas....
> I'm investigating how to pass the petsc discovered blas to p4est
> automatically. Until then, I think the configure logic says that if
> BLAS_LIBS is defined in the environment it will be be checked, so you
> could set that to whatever your know the blas libraries to be.
Satish already fixed this :-)
> Cheers,
> Toby
