[petsc-dev] download problem p4est on Cori at NERSC
Tobin Isaac
tisaac at uchicago.edu
Fri Feb 17 12:58:14 CST 2017
On Fri, Feb 17, 2017 at 01:28:25PM -0500, Mark Adams wrote:
> p4est seems to work now, but I am getting a BLAS failure. But I download
> blas....
I'm investigating how to pass the petsc discovered blas to p4est
automatically. Until then, I think the configure logic says that if
BLAS_LIBS is defined in the environment it will be be checked, so you
could set that to whatever your know the blas libraries to be.
Cheers,
Toby
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170217/740c8380/attachment.sig>
