[petsc-dev] download problem p4est on Cori at NERSC
Tobin Isaac tisaac at uchicago.edu
Fri Feb 17 13:31:52 CST 2017
On Fri, Feb 17, 2017 at 01:02:53PM -0600, Barry Smith wrote:
> > On Feb 17, 2017, at 12:58 PM, Tobin Isaac <tisaac at uchicago.edu> wrote:
> > On Fri, Feb 17, 2017 at 01:28:25PM -0500, Mark Adams wrote:
> >> p4est seems to work now, but I am getting a BLAS failure.  But I download
> >> blas....
> > I'm investigating how to pass the petsc discovered blas to p4est
> > automatically.  Until then, I think the configure logic says that if
> > BLAS_LIBS is defined in the environment it will be be checked, so you
> > could set that to whatever your know the blas libraries to be.
>    Satish already fixed this :-)
*checks watch* yep, it's a day ending in 'y'.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170217/a50caba1/attachment.sig>
