[petsc-dev] download problem p4est on Cori at NERSC
    Jeff Hammond
    jeff.science at gmail.com
    Sat Feb 18 21:29:04 CST 2017
Please be more precise with your comments.  Git works just fine on KNL and
I have hundreds of data to confirm this.  Any issues you have with Git on a
KNL-based platform are the result of the software configuration.
Furthermore, every Haswell Xeon binary runs on KNL* so there is no
hardware-related reason why login-node packages won't work on the KNL nodes.
* KNL doesn't support TSX but the programming guide states that TSX users
must query cpuid to confirm support.
Jeff
On Wed, Feb 15, 2017 at 1:38 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Oh, this is because git does not work on KNL. Maybe I should do
> with-batch=1,
> On Wed, Feb 15, 2017 at 4:36 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> I get this error on the KNL partition at NERSC.  P4est works on the
>> Haswell partition and other downloads seem to work on the KNL partition.
>> Any ideas?
Jeff Hammond
http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170218/48fa807b/attachment.html>
