[petsc-dev] Test harness upgrade
Barry Smith
bsmith at mcs.anl.gov
Sun Feb 12 15:30:38 CST 2017
> On Feb 12, 2017, at 12:34 PM, Scott Kruger <kruger at txcorp.com> wrote:
>>>> Why is test listed twice here?
>>> To invoke mpiexec twice. The first invocation
>>> will have no additional args beyond what the parent
>>> has.
>> But why would I EVER want to run it again with the same arguments as the previous time? Run the same test with the same arguments?
> There is a confusion here.
Indeed.
> When there are subtest blocks, the parent block does not generate any tests.
> Perhaps a better specification would be to change the name of the top-level block since it is not generating a test:
> container:
> suffix: 19
> requires: datafilespath
> args: -f0 ${DATAFILESPATH}/matrices/poisson1
> args: -ksp_type cg -pc_type icc
> args: -pc_factor_levels {{0 2 4}}
> separate_testvars: pc_factor_levels
> test:
> test:
> args: -mat_type seqsbaij
> Two mpiexec invocations, same output, but wanting to test minor permutations of arguments.
> Other examples in ex10 that are of the same ilk are
> ILU, cg_singlereduction, mumps_cholesky, mumps_lu, pastix_lu, zeropivot
> It's more common though to have arguments change
> the output requiring a new suffix:
> {2,3},{4,5}, 7{a,b,c}, {13,14,15,17}, etc.
> Instead of container, perhaps "testset" would
> be more descriptive.
I'm ok with testset
>>>>> test:
>>>>> args:
>>>>> test:
>>>> Instead of having the ugly separate_testvars argument could you somehow indicate it with the loop definition?
>>>>> args: -pc_factor_levels {{0 2 4}separate test output files}
>>>> and
>>>>> args: -pc_factor_levels {{0 2 4}shared test output file}
>>> It's possible.
>>> What about [[0 2 4]] implying separate test output files?
>> That works, the problem is that people have to remember what {{ means and and what [[ means. I would never be able to keep them straight, better to have a clear word that distinguishes them. I agree what I suggest is wordy, could be "shared/separate output"
> So:
> {{0 2 4}shared output}
> and
> {{0 2 4}separate output}
> Would you accept {{0 2 4}} as being equivalent to {{0 2 4} shared ouput}
Yes
> Scott
>>> Scott
>>> Tech-X Corporation kruger at txcorp.com
>>> 5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
>>> Boulder, CO 80303 Fax: (303) 448-7756
