[petsc-dev] Test harness upgrade
Scott Kruger
kruger at txcorp.com
Mon Feb 13 16:09:41 CST 2017
OK.
Down with subtest -- Long live testset.
Pushed with updated documentation.
Scott
On 2/12/17 2:30 PM, Barry Smith wrote:
>> On Feb 12, 2017, at 12:34 PM, Scott Kruger <kruger at txcorp.com> wrote:
>>>>> Why is test listed twice here?
>>>> To invoke mpiexec twice. The first invocation
>>>> will have no additional args beyond what the parent
>>>> has.
>>> But why would I EVER want to run it again with the same arguments as the previous time? Run the same test with the same arguments?
>> There is a confusion here.
> Indeed.
>> When there are subtest blocks, the parent block does not generate any tests.
>> Perhaps a better specification would be to change the name of the top-level block since it is not generating a test:
>> container:
>> suffix: 19
>> requires: datafilespath
>> args: -f0 ${DATAFILESPATH}/matrices/poisson1
>> args: -ksp_type cg -pc_type icc
>> args: -pc_factor_levels {{0 2 4}}
>> separate_testvars: pc_factor_levels
>> test:
>> test:
>> args: -mat_type seqsbaij
>> Two mpiexec invocations, same output, but wanting to test minor permutations of arguments.
>> Other examples in ex10 that are of the same ilk are
>> ILU, cg_singlereduction, mumps_cholesky, mumps_lu, pastix_lu, zeropivot
>> It's more common though to have arguments change
>> the output requiring a new suffix:
>> {2,3},{4,5}, 7{a,b,c}, {13,14,15,17}, etc.
>> Instead of container, perhaps "testset" would
>> be more descriptive.
> I'm ok with testset
>>>>>> test:
>>>>>> args:
>>>>>> test:
>>>>> Instead of having the ugly separate_testvars argument could you somehow indicate it with the loop definition?
>>>>>> args: -pc_factor_levels {{0 2 4}separate test output files}
>>>>> and
>>>>>> args: -pc_factor_levels {{0 2 4}shared test output file}
>>>> It's possible.
>>>> What about [[0 2 4]] implying separate test output files?
>>> That works, the problem is that people have to remember what {{ means and and what [[ means. I would never be able to keep them straight, better to have a clear word that distinguishes them. I agree what I suggest is wordy, could be "shared/separate output"
>> So:
>> {{0 2 4}shared output}
>> and
>> {{0 2 4}separate output}
>> Would you accept {{0 2 4}} as being equivalent to {{0 2 4} shared ouput}
> Yes
>> Scott
>>>> Scott
>>>> Tech-X Corporation kruger at txcorp.com
>>>> 5621 Arapahoe Ave, Suite A Phone: (720) 974-1841
>>>> Boulder, CO 80303 Fax: (303) 448-7756
