[petsc-dev] I don't understand PETSCPARTITIONSHELL
Thu Feb 9 21:56:23 CST 2017
On Thu, Feb 9, 2017 at 9:51 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   So shell can 1) use some random partitioner or 2) allow the user to
> provide the partitioning?
>   This is a strange combination. Won't it be better to have
> PETSCPARTIONERRANDOM and PETSCPARTITIONERSHELL?
>   You could use the random for the tests (but as command line options not
> hardwired in the examples).
Oh God. Yes, I forgot that was in there. We can move it to Simple, where it
makes sense.
  Matt
>    Barry
> > On Feb 9, 2017, at 9:45 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Thu, Feb 9, 2017 at 9:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   Matt,
> >    I don't understand PETSCPARTITIONSHELL.
> >    Why does it exist? Why not just use PETSCPARTITIONSIMPLE when no
> other partitioner exists?
> >    Why is it called shell? Other XXSHELL allow users to provide their
> own routines to provide the XX functionality, this does not seem to do
> that. So it is not shell in the PETSc sense.
> >    Why hard wire examples to use it? Why not just have list it as an
> args: in the test cases with -petscpartitioner_type shell (but why not just
> simple?) putting the ugly shit directly into the source code seems
> unnecessary and annoying.
> > 1) The two partitioners do different things:
> >   Simple: It divides the cells evenly without reordering.
> >   Shell: It allows the user to set a prescribed partition
> > It is clear to me that Shell is needed because sometimes you want to
> prescribe the partition, if for no
> > other reason than you know that a certain partition has a bug. Simple is
> questionable, but we were
> > using it for testing.
> > 2) It is called Shell because for a shell the user prescribes the
> behavior directly, which is exactly what happens.
> > 3) I did not put it in arguments because it can get very long, and I
> thought it was easier to see and manipulate in the code. I am open to
> moving it.
> >   Matt
> >   Barry
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170209/9e9886aa/attachment.html>
