[petsc-dev] Right-preconditioned GMRES
Pierre Jolivet
pierre.jolivet at enseeiht.fr
Thu Feb 9 07:06:26 CST 2017
> On Feb 9, 2017, at 1:37 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Feb 9, 2017 at 4:56 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr <mailto:pierre.jolivet at enseeiht.fr>> wrote:
> Hello,
> I _might_ be doing something wrong when calling KSPSetFromOptions/KSPSetUp, but still, am I supposed to get this kind of error?
> [0]PETSC ERROR: No support for this operation for this object type
> [0]PETSC ERROR: KSP gmres does not support PRECONDITIONED with RIGHT
> If not, I’ll try to send a MWE (it basically depends on where I set the option -ksp_pc_side right).
> I believe its telling you that it cannot display the preconditioned residual with right preconditioning, which is true.
> Are you requesting both?
No, I’m just using -ksp_view and -ksp_pc_side right. In the “standard” case, it obviously work.
However, the error is triggered if I set -ksp_pc_side right after a first call to KSPSetOperators()/KSPSetUp() without destroying the KSP.
Should I destroy my KSP before changing from left- (default) to right-preconditioning if KSPSetOperators()/KSPSetUp has already been called?
Thanks.
> Thanks,
> Matt
> Thanks,
> Pierre
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170209/7058a945/attachment.html>
