[petsc-dev] Right-preconditioned GMRES
Thu Feb 9 06:37:30 CST 2017
On Thu, Feb 9, 2017 at 4:56 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr>
wrote:
> Hello,
> I _might_ be doing something wrong when calling
> KSPSetFromOptions/KSPSetUp, but still, am I supposed to get this kind of
> error?
> [0]PETSC ERROR: No support for this operation for this object type
> [0]PETSC ERROR: KSP gmres does not support PRECONDITIONED with RIGHT
> If not, I’ll try to send a MWE (it basically depends on where I set the
> option -ksp_pc_side right).
I believe its telling you that it cannot display the preconditioned
residual with right preconditioning, which is true.
Are you requesting both?
     Matt
> Thanks,
> Pierre
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170209/c6ecf82b/attachment.html>
