[petsc-dev] Right-preconditioned GMRES
    Matthew Knepley
    knepley at gmail.com
    Thu Feb  9 07:17:18 CST 2017
On Thu, Feb 9, 2017 at 7:06 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr>
wrote:
> On Feb 9, 2017, at 1:37 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Feb 9, 2017 at 4:56 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr
> > wrote:
>> Hello,
>> I _might_ be doing something wrong when calling
>> KSPSetFromOptions/KSPSetUp, but still, am I supposed to get this kind of
>> error?
>> [0]PETSC ERROR: No support for this operation for this object type
>> [0]PETSC ERROR: KSP gmres does not support PRECONDITIONED with RIGHT
>> If not, I’ll try to send a MWE (it basically depends on where I set the
>> option -ksp_pc_side right).
> I believe its telling you that it cannot display the preconditioned
> residual with right preconditioning, which is true.
> Are you requesting both?
> No, I’m just using -ksp_view and -ksp_pc_side right. In the “standard”
> case, it obviously work.
> However, the error is triggered if I set -ksp_pc_side right after a first
> call to KSPSetOperators()/KSPSetUp() without destroying the KSP.
> Should I destroy my KSP before changing from left- (default) to
> right-preconditioning if KSPSetOperators()/KSPSetUp has already been called?
Its likely you have to use
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPSetNormType.html
or
  *-ksp_norm_type unpreconditioned*
since we would not have a chance to change it since its been set already.
     Matt
Thanks.
>   Thanks,
>      Matt
>> Thanks,
>> Pierre
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170209/9161dee4/attachment.html>
