[petsc-dev] no petsc on Edison
Hong hzhang at mcs.anl.gov
Wed Feb 8 11:07:45 CST 2017
I conducted tests on MatMatMult() and MatPtAP()
using petsc/src/ksp/ksp/examples/tutorials/ex56.c (gamg) on a 8-core
machine (petsc machine). The output file is attached.
Summary:
1) non-scalable MatMatMult() for mpiaij format is 2x faster than scalable
version. The major difference between the two is dense-axpy vs. sparse-axpy.
Currently, we set non-scalable as default, which leads to problem when
running large problems.
How about setting default as
 - non-scalable for small to medium size matrices
 - scalable for larger ones, e.g.
+    ierr = PetscOptionsEList("-matmatmult_via","Algorithmic
approach","MatMatMult",algTypes,nalg,algTypes[1],&alg,&flg);
+    if (!flg) { /* set default algorithm based on B->cmap->N */
+      PetscMPIInt size;
+      ierr = MPI_Comm_size(comm,&size);CHKERRQ(ierr);
+      if ((PetscReal)(B->cmap->N)/size > 100000.0) alg = 0; /* scalable
algorithm */
i.e., if user does NOT pick an algorithm, when ave cols per process > 100k,
use scalable implementation; otherwise, non-scalable version.
2) We do NOT have scalable implementation for MatPtAP() yet.
We have non-scalable PtAP and interface to Hypre's PtAP. Comparing the two,
Petsc MatPtAP() is approx 3x faster than Hypre's.
I'm writing a scalable MatPtAP() now.
Hong
On Thu, Feb 2, 2017 at 2:54 PM, Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> Il 02 Feb 2017 23:43, "Mark Adams" <mfadams at lbl.gov> ha scritto:
> On Thu, Feb 2, 2017 at 12:02 PM, Stefano Zampini <
> stefano.zampini at gmail.com> wrote:
>> Mark,
>> I saw your configuration has hypre. If you could run with master, you may
>> try -matptap_via hypre.
> This is worth trying. Does this even work with GAMG?
> Yes, it should work, except that the block sizes, if any, are not
> propagated to the resulting matrix. I can add it if you need it.
> Treb: try hypre anyway. It has its own RAP code.
> With that option, you will use hypre's RAP with MATAIJ
> It uses BoomerAMGBuildCoarseOperator directly with the AIJ matrices.
>> Stefano
>> On Feb 2, 2017, at 7:28 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> On Thu, Feb 2, 2017 at 11:13 AM, Hong <hzhang at mcs.anl.gov> wrote:
>>> Mark:
>>> Try '-matmatmult_via scalable' first. If this works, should we set it as
>>> default?
>> If it is robust I would say yes unless it is noticeably slower (say >20%)
>> small scale problems.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170208/5ecf6129/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170208/5ecf6129/attachment.obj>
