[petsc-dev] no petsc on Edison
Mark Adams
mfadams at lbl.gov
Wed Feb 8 19:25:08 CST 2017
Thanks Hong, that sounds great.
I am weary of silent optimizations like you suggest but 2x is big! and
failure is very bad. So I would vote for your suggestion.
ex56 is an elasticity problem. It would be nice, now that you have this
experimental setup in place, to compare with hypre on a 3D scalar problem.
Hypre might not spend much effort optimizing for block matrices. 3x better
than hypre seems large to me. I have to suspect that hypre does not
exploit blocked matrices as much as we do.
Thanks again,
On Wed, Feb 8, 2017 at 12:07 PM, Hong <hzhang at mcs.anl.gov> wrote:
> I conducted tests on MatMatMult() and MatPtAP() using petsc/src/ksp/ksp/examples/tutorials/ex56.c
> (gamg) on a 8-core machine (petsc machine). The output file is attached.
> Summary:
> 1) non-scalable MatMatMult() for mpiaij format is 2x faster than scalable
> version. The major difference between the two is dense-axpy vs. sparse-axpy.
> Currently, we set non-scalable as default, which leads to problem when
> running large problems.
> How about setting default as
> - non-scalable for small to medium size matrices
> - scalable for larger ones, e.g.
> + ierr = PetscOptionsEList("-matmatmult_via","Algorithmic
> approach","MatMatMult",algTypes,nalg,algTypes[1],&alg,&flg);
> + if (!flg) { /* set default algorithm based on B->cmap->N */
> + PetscMPIInt size;
> + ierr = MPI_Comm_size(comm,&size);CHKERRQ(ierr);
> + if ((PetscReal)(B->cmap->N)/size > 100000.0) alg = 0; /* scalable
> algorithm */
> i.e., if user does NOT pick an algorithm, when ave cols per process >
> 100k, use scalable implementation; otherwise, non-scalable version.
> 2) We do NOT have scalable implementation for MatPtAP() yet.
> We have non-scalable PtAP and interface to Hypre's PtAP. Comparing the
> two,
> Petsc MatPtAP() is approx 3x faster than Hypre's.
> I'm writing a scalable MatPtAP() now.
> Hong
> On Thu, Feb 2, 2017 at 2:54 PM, Stefano Zampini <stefano.zampini at gmail.com
> > wrote:
>> Il 02 Feb 2017 23:43, "Mark Adams" <mfadams at lbl.gov> ha scritto:
>> On Thu, Feb 2, 2017 at 12:02 PM, Stefano Zampini <
>> stefano.zampini at gmail.com> wrote:
>>> Mark,
>>> I saw your configuration has hypre. If you could run with master, you
>>> may try -matptap_via hypre.
>> This is worth trying. Does this even work with GAMG?
>> Yes, it should work, except that the block sizes, if any, are not
>> propagated to the resulting matrix. I can add it if you need it.
>> Treb: try hypre anyway. It has its own RAP code.
>> With that option, you will use hypre's RAP with MATAIJ
>> It uses BoomerAMGBuildCoarseOperator directly with the AIJ matrices.
>>> Stefano
>>> On Feb 2, 2017, at 7:28 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> On Thu, Feb 2, 2017 at 11:13 AM, Hong <hzhang at mcs.anl.gov> wrote:
>>>> Mark:
>>>> Try '-matmatmult_via scalable' first. If this works, should we set it
>>>> as default?
>>> If it is robust I would say yes unless it is noticeably slower (say
>>> >20%) small scale problems.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170208/e7e91238/attachment.html>
