[petsc-dev] no petsc on Edison
Mark Adams
mfadams at lbl.gov
Thu Feb 2 14:43:01 CST 2017
On Thu, Feb 2, 2017 at 12:02 PM, Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> Mark,
> I saw your configuration has hypre. If you could run with master, you may
> try -matptap_via hypre.
This is worth trying. Does this even work with GAMG?
Treb: try hypre anyway. It has its own RAP code.
> It uses BoomerAMGBuildCoarseOperator directly with the AIJ matrices.
> Stefano
> On Feb 2, 2017, at 7:28 PM, Mark Adams <mfadams at lbl.gov> wrote:
> On Thu, Feb 2, 2017 at 11:13 AM, Hong <hzhang at mcs.anl.gov> wrote:
>> Mark:
>> Try '-matmatmult_via scalable' first. If this works, should we set it as
>> default?
> If it is robust I would say yes unless it is noticeably slower (say >20%)
> small scale problems.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170202/6582f6af/attachment.html>
