[petsc-dev] no petsc on Edison
    Stefano Zampini
    stefano.zampini at gmail.com
    Thu Feb  2 11:02:14 CST 2017
Mark,
I saw your configuration has hypre. If you could run with master, you may try -matptap_via hypre.
It uses BoomerAMGBuildCoarseOperator directly with the AIJ matrices.
Stefano
> On Feb 2, 2017, at 7:28 PM, Mark Adams <mfadams at lbl.gov> wrote:
> On Thu, Feb 2, 2017 at 11:13 AM, Hong <hzhang at mcs.anl.gov <mailto:hzhang at mcs.anl.gov>> wrote:
> Mark:
> Try '-matmatmult_via scalable' first. If this works, should we set it as default?
> If it is robust I would say yes unless it is noticeably slower (say >20%) small scale problems.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170202/dd8165f0/attachment.html>
