[petsc-dev] Issue with Lapack names
Matthew Knepley
knepley at gmail.com
Mon Dec 18 11:58:23 CST 2017
On Mon, Dec 18, 2017 at 12:30 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> I find the following definitions in petscconf.h, which are wrong because
> the corresponding subroutines are present.
> #define PETSC_MISSING_LAPACK_UNGQR 1
> #define PETSC_MISSING_LAPACK_HETRS 1
> #define PETSC_MISSING_LAPACK_HETRF 1
> #define PETSC_MISSING_LAPACK_HETRI 1
> This did not happen in 3.8, it is due to this change:
> https://bitbucket.org/petsc/petsc/commits/b8695a4a8c7
> So now one cannot use PETSC_MISSING_LAPACK_UNGQR to protect a code that
> calls LAPACKungqr_
> This is related to a message I sent 2 years ago to petsc-maint
> "Inconsistent naming of one Lapack subroutine", where I advocated renaming
> LAPACKungqr_ --> LAPACKorgqr_. But that thread did not end up in any
> modification...
I can't find the thread. I also do not understand the problem. Are you
saying that the check succeeds but the routines is still missing?
Matt
> Jose
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171218/43bc27ae/attachment.html>
