[petsc-dev] remove temporary output with new test-harness
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Sun Dec  3 11:09:16 CST 2017
  Satish,
    I fixed the errors related to the DATAFILESPATH in ex37
  Barry
> On Dec 3, 2017, at 10:51 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Hm - how do we reproduce this?
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/12/03/examples_full_next.log
> There are a bunch of failures about - but I dn't see 'petsc-' prefix in them.
> Satish
> On Sun, 3 Dec 2017, Stefano Zampini wrote:
>> An inconsistency I have just noted. The command suggested to re-run failed tests does not work (it provides ‘petsc’ instead of the source tree location ’sees_tutorials’ as per the example below)
>> # To rerun failed tests:
>> #     make -f gmakefile.test test search='petsc-runex62_fetidp_3d_tet'
>> [szampini at localhost petsc]$ make -f gmakefile.test test search='petsc-runex62_fetidp_3d_tet'
>> # No tests run
>> [szampini at localhost petsc]$ make -f gmakefile.test test search='snes_tutorials-runex62_fetidp_3d_tet'
>>        TEST snes_tutorials-runex62_fetidp_3d_tet
