[petsc-dev] remove temporary output with new test-harness
Satish Balay
balay at mcs.anl.gov
Sun Dec 3 10:51:58 CST 2017
Hm - how do we reproduce this?
http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/12/03/examples_full_next.log
There are a bunch of failures about - but I dn't see 'petsc-' prefix in them.
Satish
On Sun, 3 Dec 2017, Stefano Zampini wrote:
> An inconsistency I have just noted. The command suggested to re-run failed tests does not work (it provides ‘petsc’ instead of the source tree location ’sees_tutorials’ as per the example below)
> # To rerun failed tests:
> # make -f gmakefile.test test search='petsc-runex62_fetidp_3d_tet'
> [szampini at localhost petsc]$ make -f gmakefile.test test search='petsc-runex62_fetidp_3d_tet'
> # No tests run
> [szampini at localhost petsc]$ make -f gmakefile.test test search='snes_tutorials-runex62_fetidp_3d_tet'
> TEST snes_tutorials-runex62_fetidp_3d_tet
