[petsc-dev] remove temporary output with new test-harness
Satish Balay
balay at mcs.anl.gov
Sun Dec 3 10:48:04 CST 2017
On Sun, 3 Dec 2017, Stefano Zampini wrote:
> The issue may arise with output files from a previous test run.
Wouldn't those files get overwritten when the test is rerun?
> Would it be possible to run ‘rm -rf *’ in the example temporary directory before running the test?
The current thought is - the dependencies should work in such a way that recompiles etc should be avoided.
An always 'rm' would defete this feature..
But you can do this 'rm' manually.
Satish
