[petsc-dev] snes_type test
Matthew Knepley
knepley at gmail.com
Wed Aug 16 10:22:46 CDT 2017
On Wed, Aug 16, 2017 at 10:14 AM, Mark Adams <mfadams at lbl.gov> wrote:
> I just want to check the interpretation of snes_type test. Is this pretty
> conclusively good?
It looks right, but the entires in the Jacobian are crazy. You should
non-dimensionalize first.
Matt
> Testing hand-coded Jacobian, if the ratio is
> O(1.e-8), the hand-coded Jacobian is probably correct.
> Run with -snes_test_display to show difference
> of hand-coded and finite difference Jacobian.
> Norm of matrix ratio 1.38299e-16, difference 1.11738 (user-defined state)
> Norm of matrix ratio 9.50529e-09, difference 7.67972e+07 (constant state
> -1.0)
> Norm of matrix ratio 1.07438e-08, difference 8.68036e+07 (constant state
> 1.0)
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170816/47916b7c/attachment.html>
