[petsc-dev] snes_type test
Mark Adams
mfadams at lbl.gov
Wed Aug 16 10:30:10 CDT 2017
On Thu, Aug 17, 2017 at 12:22 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Aug 16, 2017 at 10:14 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> I just want to check the interpretation of snes_type test. Is this pretty
>> conclusively good?
> It looks right, but the entires in the Jacobian are crazy. You should
> non-dimensionalize first.
This is non-dimensionalize and it is 2D FE 2nd order equation so everything
should be O(1), that is, there is no 1/h like term. And the domain is (1)
and the grid is small so h is O(1) anyway.
> Matt
>> Testing hand-coded Jacobian, if the ratio is
>> O(1.e-8), the hand-coded Jacobian is probably correct.
>> Run with -snes_test_display to show difference
>> of hand-coded and finite difference Jacobian.
>> Norm of matrix ratio 1.38299e-16, difference 1.11738 (user-defined state)
>> Norm of matrix ratio 9.50529e-09, difference 7.67972e+07 (constant state
>> -1.0)
>> Norm of matrix ratio 1.07438e-08, difference 8.68036e+07 (constant state
>> 1.0)
> experiments lead.
> -- Norbert Wiener
> http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170817/5d104cb0/attachment.html>
