[petsc-dev] DMPlex label distribution
    Matthew Knepley
    knepley at gmail.com
    Thu Mar 17 20:03:41 CDT 2016
On Thu, Mar 17, 2016 at 7:49 PM, Adrian Croucher <a.croucher at auckland.ac.nz>
wrote:
> hi
> On 18/03/16 13:13, Matthew Knepley wrote:
> I believe I have fixed your bug:
> https://bitbucket.org/petsc/petsc/branch/knepley/fix-plex-distribute-label
> I merged to next, and it will get to master before the release.
> Great, thanks- that does seem to have fixed it!
> I can build your fix-plex-distribute-label branch OK, but currently am
> getting build errors when I try to build 'next' (the problem seems to be
> ksp/pc/impls/telescope/telescope.c). The make log is below.
There is a discussion going on about that pull request. It should be sorted
out shortly. Until the release, I would just
use that branch.
    Matt
> Cheers, Adrian
> make[1]: Entering directory `/home/acro018/software/PETSc/code'
> See documentation/faq.html and documentation/bugreporting.html
> for help with installation problems.  Please send EVERYTHING
> printed out below when reporting problems.  Please check the
> mailing list archives and consider subscribing.
>   http://www.mcs.anl.gov/petsc/miscellaneous/mailing-lists.html
> Starting on des108 at Fri Mar 18 13:44:32 NZDT 2016
> Machine characteristics: Linux des108 3.2.0-4-amd64 #1 SMP Debian
> 3.2.73-2+deb7u2 x86_64 GNU/Linux
> Using PETSc directory: /home/acro018/software/PETSc/code
> Using PETSc arch: linux-gnu-c-opt
> PETSC_VERSION_RELEASE    0
> PETSC_VERSION_MAJOR      3
> PETSC_VERSION_MINOR      6
> PETSC_VERSION_SUBMINOR   3
> PETSC_VERSION_PATCH      0
> PETSC_VERSION_DATE       "unknown"
> PETSC_VERSION_GIT        "unknown"
> PETSC_VERSION_DATE_GIT   "unknown"
> PETSC_VERSION_(MAJOR,MINOR,SUBMINOR) \
> PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR)          \
> PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
> PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
> PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
> Using configure Options: --download-netcdf --download-exodusii
> --with-hdf5-dir=/usr --download-triangle --download-ptscotch
> --download-chaco
> Using configuration flags:
> #define INCLUDED_PETSCCONF_H
> #define ANSI_DECLARATORS 1
> #define IS_COLORING_MAX 65535
> #define STDC_HEADERS 1
> #define MPIU_COLORING_VALUE MPI_UNSIGNED_SHORT
> #define PETSC_UINTPTR_T uintptr_t
> #define PETSC_HAVE_PTHREAD 1
> #define PETSC_HAVE_SSL 1
> #define PETSC_DEPRECATED(why) __attribute((deprecated))
> #define PETSC_REPLACE_DIR_SEPARATOR '\\'
> #define PETSC_HAVE_HDF5 1
> #define PETSC_HAVE_TRIANGLE 1
> #define PETSC_HAVE_SO_REUSEADDR 1
> #define PETSC_HAVE_MPI 1
> #define PETSC_PREFETCH_HINT_T2 _MM_HINT_T2
> #define PETSC_PREFETCH_HINT_T0 _MM_HINT_T0
> #define PETSC_PREFETCH_HINT_T1 _MM_HINT_T1
> #define PETSC_HAVE_FORTRAN 1
> #define PETSC_DIR "/home/acro018/software/PETSc/code"
> #define PETSC_HAVE_X 1
> #define PETSC_LIB_DIR
> "/home/acro018/software/PETSc/code/linux-gnu-c-opt/lib"
> #define PETSC_USE_SOCKET_VIEWER 1
> #define PETSC_USE_ISATTY 1
> #define PETSC_HAVE_SOWING 1
> #define PETSC_SLSUFFIX "so"
> #define PETSC_FUNCTION_NAME_CXX __func__
> #define PETSC_HAVE_ATOLL 1
> #define PETSC_HAVE_ATTRIBUTEALIGNED 1
> #define PETSC_HAVE_DOUBLE_ALIGN_MALLOC 1
> #define PETSC_UNUSED __attribute((unused))
> #define PETSC_ATTRIBUTEALIGNED(size) __attribute((aligned (size)))
> #define PETSC_FUNCTION_NAME_C __func__
> #define PETSC_HAVE_EXODUSII 1
> #define PETSC_HAVE_VALGRIND 1
> #define PETSC_USE_SINGLE_LIBRARY 1
> #define PETSC_HAVE_CHACO 1
> #define PETSC_HAVE_BUILTIN_EXPECT 1
> #define PETSC_HAVE_PTSCOTCH 1
> #define PETSC_HAVE_NETCDF 1
> #define PETSC_DIR_SEPARATOR '/'
> #define PETSC_PATH_SEPARATOR ':'
> #define PETSC_HAVE_XMMINTRIN_H 1
> #define PETSC_PREFETCH_HINT_NTA _MM_HINT_NTA
> #define PETSC_Prefetch(a,b,c) _mm_prefetch((const char*)(a),(c))
> #define PETSC_HAVE_BLASLAPACK 1
> #define PETSC_HAVE_GZIP 1
> #define PETSC_HAVE_STRING_H 1
> #define PETSC_HAVE_SYS_TYPES_H 1
> #define PETSC_HAVE_ENDIAN_H 1
> #define PETSC_HAVE_SYS_PROCFS_H 1
> #define PETSC_HAVE_DLFCN_H 1
> #define PETSC_HAVE_SCHED_H 1
> #define PETSC_HAVE_STDINT_H 1
> #define PETSC_HAVE_LINUX_KERNEL_H 1
> #define PETSC_HAVE_TIME_H 1
> #define PETSC_HAVE_MATH_H 1
> #define PETSC_TIME_WITH_SYS_TIME 1
> #define PETSC_HAVE_SYS_PARAM_H 1
> #define PETSC_HAVE_PTHREAD_H 1
> #define PETSC_HAVE_UNISTD_H 1
> #define PETSC_HAVE_STDLIB_H 1
> #define PETSC_HAVE_SYS_WAIT_H 1
> #define PETSC_HAVE_SETJMP_H 1
> #define PETSC_HAVE_LIMITS_H 1
> #define PETSC_HAVE_SYS_UTSNAME_H 1
> #define PETSC_HAVE_NETINET_IN_H 1
> #define PETSC_HAVE_SYS_SOCKET_H 1
> #define PETSC_HAVE_FLOAT_H 1
> #define PETSC_HAVE_SEARCH_H 1
> #define PETSC_HAVE_SYS_RESOURCE_H 1
> #define PETSC_HAVE_SYS_TIMES_H 1
> #define PETSC_HAVE_NETDB_H 1
> #define PETSC_HAVE_MALLOC_H 1
> #define PETSC_HAVE_PWD_H 1
> #define PETSC_HAVE_FCNTL_H 1
> #define PETSC_HAVE_STRINGS_H 1
> #define PETSC_HAVE_SYS_SYSINFO_H 1
> #define PETSC_HAVE_SYS_TIME_H 1
> #define PETSC_USING_F90 1
> #define PETSC_USING_F2003 1
> #define PETSC_HAVE_RTLD_NOW 1
> #define PETSC_HAVE_RTLD_LOCAL 1
> #define PETSC_HAVE_RTLD_LAZY 1
> #define PETSC_C_STATIC_INLINE static inline
> #define PETSC_HAVE_FORTRAN_UNDERSCORE 1
> #define PETSC_HAVE_CXX_NAMESPACE 1
> #define PETSC_HAVE_RTLD_GLOBAL 1
> #define PETSC_C_RESTRICT  __restrict__
> #define PETSC_CXX_RESTRICT  __restrict__
> #define PETSC_CXX_STATIC_INLINE static inline
> #define PETSC_HAVE_LIBBLAS 1
> #define PETSC_HAVE_LIBZ 1
> #define PETSC_HAVE_LIBDL 1
> #define PETSC_HAVE_LIBGFORTRAN 1
> #define PETSC_HAVE_LIBLAPACK 1
> #define PETSC_HAVE_LIBCRYPTO 1
> #define PETSC_HAVE_LIBPTSCOTCH 1
> #define PETSC_HAVE_LIBM 1
> #define PETSC_HAVE_LIBSCOTCHERR 1
> #define PETSC_HAVE_LIBTRIANGLE 1
> #define PETSC_HAVE_LIBPTESMUMPS 1
> #define PETSC_HAVE_LIBMPI_F77 1
> #define PETSC_HAVE_LIBHDF5 1
> #define PETSC_HAVE_LIBMPI_F90 1
> #define PETSC_HAVE_LIBNETCDF 1
> #define PETSC_HAVE_LIBHDF5HL_FORTRAN 1
> #define PETSC_HAVE_LIBX11 1
> #define PETSC_HAVE_FENV_H 1
> #define PETSC_HAVE_LIBEXODUS 1
> #define PETSC_HAVE_LOG2 1
> #define PETSC_HAVE_LIBHDF5_HL 1
> #define PETSC_HAVE_LIBRT 1
> #define PETSC_HAVE_LIBPTSCOTCHERR 1
> #define PETSC_HAVE_LIBEXOIIV2FOR 1
> #define PETSC_HAVE_ERF 1
> #define PETSC_HAVE_LIBSSL 1
> #define PETSC_HAVE_LIBQUADMATH 1
> #define PETSC_HAVE_LIBHDF5_FORTRAN 1
> #define PETSC_HAVE_LIBCHACO 1
> #define PETSC_HAVE_TGAMMA 1
> #define PETSC_HAVE_LIBSCOTCH 1
> #define PETSC_ARCH "linux-gnu-c-opt"
> #define PETSC_USE_SCALAR_REAL 1
> #define PETSC_HAVE_ISINF 1
> #define PETSC_HAVE_ISNAN 1
> #define PETSC_HAVE_ISNORMAL 1
> #define PETSC_USE_REAL_DOUBLE 1
> #define PETSC_SIZEOF_MPI_COMM 8
> #define PETSC_BITS_PER_BYTE 8
> #define PETSC_SIZEOF_MPI_FINT 4
> #define PETSC_USE_VISIBILITY_C 1
> #define PETSC_SIZEOF_VOID_P 8
> #define PETSC_RETSIGTYPE void
> #define PETSC_HAVE_CXX_COMPLEX 1
> #define PETSC_SIZEOF_LONG 8
> #define PETSC_USE_FORTRANKIND 1
> #define PETSC_USE_VISIBILITY_CXX 1
> #define PETSC_SIZEOF_SIZE_T 8
> #define PETSC_HAVE_SIGINFO_T 1
> #define PETSC_SIZEOF_CHAR 1
> #define PETSC_SIZEOF_DOUBLE 8
> #define PETSC_SIZEOF_FLOAT 4
> #define PETSC_HAVE_C99_COMPLEX 1
> #define PETSC_SIZEOF_INT 4
> #define PETSC_SIZEOF_LONG_LONG 8
> #define PETSC_SIZEOF_SHORT 2
> #define PETSC_CLANGUAGE_C 1
> #define PETSC_HAVE_MPI_F90MODULE 1
> #define PETSC_HAVE_OMPI_MINOR_VERSION 4
> #define PETSC_HAVE_MPI_IN_PLACE 1
> #define PETSC_HAVE_MPI_COMM_C2F 1
> #define PETSC_HAVE_MPI_COMBINER_CONTIGUOUS 1
> #define PETSC_HAVE_MPI_TYPE_GET_EXTENT 1
> #define PETSC_HAVE_MPI_WIN_CREATE 1
> #define PETSC_HAVE_MPI_TYPE_DUP 1
> #define PETSC_HAVE_MPI_INIT_THREAD 1
> #define PETSC_HAVE_MPI_LONG_DOUBLE 1
> #define PETSC_HAVE_MPI_COMM_F2C 1
> #define PETSC_HAVE_MPI_TYPE_GET_ENVELOPE 1
> #define PETSC_HAVE_MPI_ALLTOALLW 1
> #define PETSC_HAVE_OMPI_MAJOR_VERSION 1
> #define PETSC_HAVE_MPI_REDUCE_SCATTER 1
> #define PETSC_HAVE_MPIIO 1
> #define PETSC_HAVE_MPI_COMM_SPAWN 1
> #define PETSC_HAVE_MPI_FINT 1
> #define PETSC_HAVE_MPI_FINALIZED 1
> #define PETSC_HAVE_OMPI_RELEASE_VERSION 5
> #define PETSC_HAVE_MPI_REPLACE 1
> #define PETSC_HAVE_MPI_EXSCAN 1
> #define PETSC_HAVE_MPI_COMBINER_DUP 1
> #define PETSC_USE_ERRORCHECKING 1
> #define PETSC_HAVE_STRCASECMP 1
> #define PETSC_HAVE_GET_NPROCS 1
> #define PETSC_HAVE_POPEN 1
> #define PETSC_HAVE_SIGSET 1
> #define PETSC_HAVE_GETWD 1
> #define PETSC_HAVE_VSNPRINTF 1
> #define PETSC_HAVE_TIMES 1
> #define PETSC_HAVE_DLSYM 1
> #define PETSC_HAVE_SNPRINTF 1
> #define PETSC_HAVE_GETHOSTBYNAME 1
> #define PETSC_HAVE_GETCWD 1
> #define PETSC_HAVE_DLERROR 1
> #define PETSC_HAVE_FORK 1
> #define PETSC_HAVE_RAND 1
> #define PETSC_HAVE_GETTIMEOFDAY 1
> #define PETSC_HAVE_DLCLOSE 1
> #define PETSC_HAVE_UNAME 1
> #define PETSC_HAVE_GETHOSTNAME 1
> #define PETSC_HAVE_MKSTEMP 1
> #define PETSC_HAVE_SIGACTION 1
> #define PETSC_HAVE_DRAND48 1
> #define PETSC_HAVE_MEMALIGN 1
> #define PETSC_HAVE_VA_COPY 1
> #define PETSC_HAVE_CLOCK 1
> #define PETSC_HAVE_ACCESS 1
> #define PETSC_HAVE_SIGNAL 1
> #define PETSC_HAVE_USLEEP 1
> #define PETSC_HAVE_GETRUSAGE 1
> #define PETSC_HAVE_VFPRINTF 1
> #define PETSC_HAVE_NANOSLEEP 1
> #define PETSC_HAVE_GETDOMAINNAME 1
> #define PETSC_HAVE_TIME 1
> #define PETSC_HAVE_LSEEK 1
> #define PETSC_HAVE_SOCKET 1
> #define PETSC_HAVE_SYSINFO 1
> #define PETSC_HAVE_READLINK 1
> #define PETSC_HAVE_REALPATH 1
> #define PETSC_HAVE_DLOPEN 1
> #define PETSC_HAVE_MEMMOVE 1
> #define PETSC_HAVE__GFORTRAN_IARGC 1
> #define PETSC_HAVE_GETPAGESIZE 1
> #define PETSC_HAVE_SLEEP 1
> #define PETSC_HAVE_VPRINTF 1
> #define PETSC_HAVE_BZERO 1
> #define PETSC_SIGNAL_CAST
> #define PETSC_WRITE_MEMORY_BARRIER() asm volatile("sfence":::"memory")
> #define PETSC_MEMORY_BARRIER() asm volatile("mfence":::"memory")
> #define PETSC_READ_MEMORY_BARRIER() asm volatile("lfence":::"memory")
> #define PETSC_CPU_RELAX() asm volatile("rep; nop" ::: "memory")
> #define PETSC_BLASLAPACK_UNDERSCORE 1
> #define PETSC_MEMALIGN 16
> #define PETSC_VERSION_DATE_GIT "2016-03-17 19:05:32 -0500"
> #define PETSC_VERSION_BRANCH_GIT "next"
> #define PETSC_VERSION_GIT "pre-tsfc-2164-g9eb648e"
> #define PETSC_USE_INFO 1
> #define PETSC_Alignx(a,b)
> #define PETSC_USE_BACKWARD_LOOP 1
> #define PETSC_USE_DEBUG 1
> #define PETSC_IS_COLOR_VALUE_TYPE_SIZE PETSC_SIZEOF_SHORT
> #define PETSC_USE_LOG 1
> #define PETSC_IS_COLOR_VALUE_TYPE short
> #define PETSC_USE_CTABLE 1
> #define PETSC_HAVE_DYNAMIC_LIBRARIES 1
> #define PETSC_HAVE_SHARED_LIBRARIES 1
> #define PETSC_USE_SHARED_LIBRARIES 1
> #define PETSC_USE_GDB_DEBUGGER 1
> #define PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT 1
> #define PETSC_HAVE_GFORTRAN_IARGC 1
> #define PETSC_USE_PROC_FOR_SIZE 1
> #define PETSC_LEVEL1_DCACHE_LINESIZE 64
> #define PETSC_LEVEL1_DCACHE_SIZE 32768
> #define PETSC_LEVEL1_DCACHE_ASSOC 8
> #define PETSC__GNU_SOURCE 1
> #define PETSC__BSD_SOURCE 1
> #define PETSC__DEFAULT_SOURCE 1
> #define PETSC_HAVE_H5PSET_FAPL_MPIO 1
> #define PETSC_HAVE_SCHED_CPU_SET_T 1
> #define PETSC_HAVE_PTHREAD_BARRIER_T 1
> #define PETSC_HAVE_SYS_SYSCTL_H 1
> Using C/C++ compile: mpicc -c -fPIC  -Wall -Wwrite-strings
> -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3
> -I/home/acro018/software/PETSc/code/include
> -I/home/acro018/software/PETSc/code/linux-gnu-c-opt/include -I/usr/include
> -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi
> mpicc -show: gcc -I/usr/lib/openmpi/include
> -I/usr/lib/openmpi/include/openmpi -pthread -L/usr/lib/openmpi/lib -lmpi
> -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl
> Using Fortran compile: mpif90 -c -fPIC -Wall -Wno-unused-variable
> -ffree-line-length-0 -Wno-unused-dummy-argument -g
> mpif90 -show: gfortran -I/usr/lib/openmpi/include -pthread
> -I/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib -lmpi_f90 -lmpi_f77 -lmpi
> Using C/C++ linker: mpicc
> Using C/C++ flags: -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing
> Using Fortran linker: mpif90
> Using Fortran flags: -fPIC -Wall -Wno-unused-variable -ffree-line-length-0
> Using libraries:
> -Wl,-rpath,/home/acro018/software/PETSc/code/linux-gnu-c-opt/lib
> -L/home/acro018/software/PETSc/code/linux-gnu-c-opt/lib  -lpetsc -llapack
> -lblas -Wl,-rpath,/home/acro018/software/PETSc/code/linux-gnu-c-opt/lib
> -ltriangle -lX11 -lptesmumps -lptscotch -lptscotcherr -lscotch -lscotcherr
> -lexoIIv2for -lexodus -lnetcdf -Wl,-rpath,/usr/lib -L/usr/lib
> -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lssl -lcrypto -lchaco
> -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib
> -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.7
> -L/usr/lib/gcc/x86_64-linux-gnu/4.7 -Wl,-rpath,/usr/lib/x86_64-linux-gnu
> -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
> -L/lib/x86_64-linux-gnu -lmpi_f90 -lmpi_f77 -lgfortran -lm -lgfortran -lm
> -lgfortran -lm -lquadmath -lm -lmpi_cxx -lstdc++ -lrt -lm -lz
> -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu
> -L/usr/lib/x86_64-linux-gnu -ldl -lmpi -lopen-rte -lopen-pal -lnsl -lutil
> -lgcc_s -lpthread -ldl
> Using mpiexec: mpiexec
> Building PETSc using GNU Make with 7 build threads
> make[2]: Entering directory `/home/acro018/software/PETSc/code'
> /usr/bin/python ./config/gmakegen.py --petsc-arch=linux-gnu-c-opt
> make[2]: Leaving directory `/home/acro018/software/PETSc/code'
> Use "/usr/bin/make V=1" to see the verbose compile lines.
>           CC linux-gnu-c-opt/obj/src/sys/info/verboseinfo.o
>           CC linux-gnu-c-opt/obj/src/sys/info/ftn-auto/verboseinfof.o
>           CC linux-gnu-c-opt/obj/src/sys/info/ftn-custom/zverboseinfof.o
>           CC linux-gnu-c-opt/obj/src/sys/memory/mal.o
>           CC linux-gnu-c-opt/obj/src/sys/memory/mem.o
>           CC linux-gnu-c-opt/obj/src/sys/memory/mtr.o
>           CC linux-gnu-c-opt/obj/src/sys/memory/ftn-auto/memf.o
>           CC linux-gnu-c-opt/obj/src/sys/memory/ftn-custom/zmtrf.o
>           CC linux-gnu-c-opt/obj/src/sys/ftn-custom/zsys.o
>           CC linux-gnu-c-opt/obj/src/sys/ftn-custom/zutils.o
>           CC linux-gnu-c-opt/obj/src/sys/logging/xmllogevent.o
>           CC linux-gnu-c-opt/obj/src/sys/logging/plog.o
>           CC linux-gnu-c-opt/obj/src/sys/logging/xmlviewer.o
>           CC linux-gnu-c-opt/obj/src/sys/logging/ftn-auto/plogf.o
>           CC linux-gnu-c-opt/obj/src/sys/logging/ftn-custom/zplogf.o
>           CC linux-gnu-c-opt/obj/src/sys/logging/utils/classlog.o
>           CC linux-gnu-c-opt/obj/src/sys/logging/utils/stagelog.o
>           CC linux-gnu-c-opt/obj/src/sys/logging/utils/eventlog.o
>           CC linux-gnu-c-opt/obj/src/sys/logging/utils/stack.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/version.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/gcomm.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/gtype.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/olist.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/pname.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/tagm.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/destroy.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/gcookie.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/inherit.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/options.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/pgname.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/prefix.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/init.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/pinit.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ptype.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/state.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/aoptions.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/subcomm.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/fcallback.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/inheritf.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/gcommf.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/statef.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/optionsf.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/destroyf.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/ptypef.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/tagmf.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/pinitf.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zgcommf.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zoptionsf.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zpgnamef.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zpnamef.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zprefixf.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zdestroyf.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zstart.o
>           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zstartf.o
>           CC linux-gnu-c-opt/obj/src/sys/python/pythonsys.o
>           CC linux-gnu-c-opt/obj/src/sys/python/ftn-custom/zpythonf.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/arch.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/fhost.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/fuser.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/memc.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/mpiu.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/psleep.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/sortd.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/sorti.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/str.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/sortip.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/pbarrier.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/pdisplay.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/ctable.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/psplit.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/select.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/mpimesg.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/sseenabled.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/mpitr.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/mpilong.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/mathinf.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/mpits.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/segbuffer.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/psleepf.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/mpitsf.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/psplitf.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/sortif.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/sortdf.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/memcf.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/sortipf.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/mpiuf.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-custom/zarchf.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-custom/zstrf.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-custom/zpbarrierf.o
>           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-custom/zfhostf.o
>           CC linux-gnu-c-opt/obj/src/sys/error/adebug.o
>           CC linux-gnu-c-opt/obj/src/sys/error/err.o
>           CC linux-gnu-c-opt/obj/src/sys/error/errtrace.o
>           CC linux-gnu-c-opt/obj/src/sys/error/errabort.o
>           CC linux-gnu-c-opt/obj/src/sys/error/errstop.o
>           CC linux-gnu-c-opt/obj/src/sys/error/fp.o
>           CC linux-gnu-c-opt/obj/src/sys/error/signal.o
>           CC linux-gnu-c-opt/obj/src/sys/error/pstack.o
>           CC linux-gnu-c-opt/obj/src/sys/error/checkptr.o
>           CC linux-gnu-c-opt/obj/src/sys/error/ftn-auto/checkptrf.o
>           CC linux-gnu-c-opt/obj/src/sys/error/ftn-auto/errf.o
>           CC linux-gnu-c-opt/obj/src/sys/error/ftn-auto/signalf.o
>           CC linux-gnu-c-opt/obj/src/sys/error/ftn-auto/adebugf.o
>           CC linux-gnu-c-opt/obj/src/sys/error/ftn-auto/fpf.o
>           CC linux-gnu-c-opt/obj/src/sys/error/ftn-custom/zerrf.o
>           CC linux-gnu-c-opt/obj/src/sys/dll/dlimpl.o
>           CC linux-gnu-c-opt/obj/src/sys/dll/dl.o
>           CC linux-gnu-c-opt/obj/src/sys/dll/reg.o
>           CC linux-gnu-c-opt/obj/src/sys/dll/ftn-auto/regf.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/binary/binv.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/binary/ftn-auto/binvf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/binary/f90-custom/zbinvf90.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/binary/ftn-custom/zbinvf.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/draw/drawv.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/draw/ftn-auto/drawvf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/draw/ftn-custom/zdrawvf.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/socket/send.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/socket/ftn-custom/zsendf.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/hdf5/hdf5v.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/hdf5/ftn-auto/hdf5vf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/hdf5/ftn-custom/zhdf5f.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/vtk/vtkv.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/vtk/ftn-custom/zvtkvf.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/vu/petscvu.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/ascii/filev.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/ascii/vcreatea.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/ascii/ftn-auto/filevf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/ascii/ftn-custom/zfilevf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/ascii/ftn-custom/zvcreatef.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/string/stringv.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/string/ftn-custom/zstringvf.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/view.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/flush.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/viewregall.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/viewreg.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/viewa.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/dlregispetsc.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/viewers.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/dupl.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/ftn-auto/flushf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/ftn-auto/duplf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/ftn-auto/viewregf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/ftn-auto/viewf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/ftn-custom/zviewaf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/ftn-custom/zviewasetf.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/xinit.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/ximage.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/xcolor.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/xops.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/xioerr.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/xtext.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/xtone.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/drawopenx.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/ftn-custom/zdrawopenxf.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/tikz/tikz.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/impls/image/drawimage.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/draw.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dcoor.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dtext.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dpoint.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dmarker.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dline.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dpause.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dbuff.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dflush.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dsave.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dclear.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dmouse.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dviewp.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dtri.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/drect.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dellipse.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/drawreg.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/drawregall.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dflushf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dclearf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dbufff.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dpausef.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/drectf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dmousef.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/drawf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dsavef.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dtrif.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dmarkerf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/drawregf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dcoorf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dviewpf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dpointf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dlinef.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dellipsef.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dtextf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-custom/zdrawf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-custom/zdrawregf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-custom/zdtextf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-custom/zdtrif.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/axis.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/lg.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/dscatter.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/hists.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/zoom.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/cmap.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/lgc.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/axisc.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/bars.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/image.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-auto/lgf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-auto/axisf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-auto/histsf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-auto/axiscf.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-auto/lgcf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-auto/barsf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-auto/dscatterf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-custom/zaxisf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-custom/zlgcf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-custom/zzoomf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/random/impls/rander48/rander48.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/random/impls/rand/rand.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/random/impls/rand48/rand48.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/random/interface/random.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/random/interface/randreg.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/random/interface/dlregisrand.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/random/interface/randomc.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/random/interface/ftn-auto/randomf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/random/interface/ftn-auto/randomcf.o
>           CC
> linux-gnu-c-opt/obj/src/sys/classes/random/interface/ftn-custom/zrandomf.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/bag/bag.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/bag/ftn-auto/bagf.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/bag/f90-custom/zbagf90.o
>           CC linux-gnu-c-opt/obj/src/sys/classes/bag/ftn-custom/zbagf.o
>           CC linux-gnu-c-opt/obj/src/sys/time/cputime.o
>           CC linux-gnu-c-opt/obj/src/sys/time/fdate.o
>           CC linux-gnu-c-opt/obj/src/sys/time/ftn-auto/cputimef.o
>           CC linux-gnu-c-opt/obj/src/sys/time/ftn-custom/zptimef.o
>           CC linux-gnu-c-opt/obj/src/sys/totalview/tv_data_display.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/ffpath.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/ftest.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/ghome.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/mpiuopen.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/rpath.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/fpath.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/fwd.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/grpath.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/mprint.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/sysio.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/fretrieve.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/smatlab.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/fdir.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-auto/sysiof.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-auto/mpiuopenf.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-custom/zghomef.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-custom/zmpiuopenf.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-custom/zmprintf.o
>           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-custom/zsysiof.o
>           CC linux-gnu-c-opt/obj/src/sys/webclient/client.o
>           CC linux-gnu-c-opt/obj/src/sys/webclient/google.o
>           CC linux-gnu-c-opt/obj/src/sys/webclient/box.o
>           CC linux-gnu-c-opt/obj/src/sys/webclient/textbelt.o
>           CC linux-gnu-c-opt/obj/src/sys/webclient/globus.o
>           CC linux-gnu-c-opt/obj/src/sys/f90-src/f90_cwrap.o
>           CC linux-gnu-c-opt/obj/src/vec/is/utils/isio.o
>           CC linux-gnu-c-opt/obj/src/vec/is/utils/isltog.o
>           CC linux-gnu-c-opt/obj/src/vec/is/utils/pmap.o
>           CC linux-gnu-c-opt/obj/src/vec/is/utils/vsectionis.o
>           CC linux-gnu-c-opt/obj/src/vec/is/utils/ftn-auto/isltogf.o
>           CC linux-gnu-c-opt/obj/src/vec/is/utils/ftn-auto/pmapf.o
>           CC linux-gnu-c-opt/obj/src/vec/is/utils/ftn-auto/vsectionisf.o
>           CC linux-gnu-c-opt/obj/src/vec/is/utils/f90-custom/zisltogf90.o
>           CC
> linux-gnu-c-opt/obj/src/vec/is/utils/f90-custom/zvsectionisf90.o
>           CC linux-gnu-c-opt/obj/src/vec/is/utils/ftn-custom/zisltogf.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/impls/f90-custom/zblockf90.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/impls/stride/stride.o
>           CC
> linux-gnu-c-opt/obj/src/vec/is/is/impls/stride/ftn-auto/stridef.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/impls/block/block.o
>           CC
> linux-gnu-c-opt/obj/src/vec/is/is/impls/block/ftn-auto/blockf.o
>           CC
> linux-gnu-c-opt/obj/src/vec/is/is/impls/block/ftn-custom/zblockf.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/impls/general/general.o
>           CC
> linux-gnu-c-opt/obj/src/vec/is/is/impls/general/ftn-auto/generalf.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/interface/index.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/interface/isregall.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/interface/isreg.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/interface/ftn-auto/indexf.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/interface/ftn-auto/isregf.o
>           CC
> linux-gnu-c-opt/obj/src/vec/is/is/interface/f90-custom/zindexf90.o
>           CC
> linux-gnu-c-opt/obj/src/vec/is/is/interface/ftn-custom/zindexf.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/iscomp.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/iscoloring.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/isdiff.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/isblock.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/ftn-auto/isblockf.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/ftn-auto/isdifff.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/ftn-auto/iscoloringf.o
>           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/ftn-auto/iscompf.o
>           CC
> linux-gnu-c-opt/obj/src/vec/is/is/utils/f90-custom/ziscoloringf90.o
>           CC
> linux-gnu-c-opt/obj/src/vec/is/is/utils/ftn-custom/ziscoloringf.o
>           CC
> linux-gnu-c-opt/obj/src/vec/is/ao/impls/memscalable/aomemscalable.o
>           CC linux-gnu-c-opt/obj/src/vec/is/ao/impls/mapping/aomapping.o
>           CC
> linux-gnu-c-opt/obj/src/vec/is/ao/impls/mapping/ftn-auto/aomappingf.o
>           CC
> linux-gnu-c-opt/obj/src/vec/is/ao/impls/mapping/ftn-custom/zaomappingf.o
>           CC linux-gnu-c-opt/obj/src/vec/is/ao/impls/basic/aobasic.o
>           CC
> linux-gnu-c-opt/obj/src/vec/is/ao/impls/basic/ftn-custom/zaobasicf.o
>           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/ao.o
>           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/dlregisdm.o
>           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/aoreg.o
>           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/aoregall.o
>           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/ftn-auto/aof.o
>           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/ftn-custom/zaof.o
>           CC linux-gnu-c-opt/obj/src/vec/is/sf/impls/window/sfwindow.o
>           CC linux-gnu-c-opt/obj/src/vec/is/sf/impls/basic/sfbasic.o
>           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/dlregissf.o
>           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/sfregi.o
>           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/sf.o
>           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/sftype.o
>           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/ftn-auto/sff.o
>           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/ftn-custom/zsf.o
>           CC linux-gnu-c-opt/obj/src/vec/pf/impls/constant/const.o
>           CC linux-gnu-c-opt/obj/src/vec/pf/impls/string/cstring.o
>           CC linux-gnu-c-opt/obj/src/vec/pf/interface/pf.o
>           CC linux-gnu-c-opt/obj/src/vec/pf/interface/pfall.o
>           CC linux-gnu-c-opt/obj/src/vec/pf/interface/ftn-auto/pff.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/shared/shvec.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/shared/ftn-auto/shvecf.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/nest/vecnest.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/nest/ftn-auto/vecnestf.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/bvec2.o
>           CC
> linux-gnu-c-opt/obj/src/vec/vec/impls/nest/ftn-custom/zvecnestf.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/bvec1.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/dvec2.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/vseqcr.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/bvec3.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/ftn-custom/zbvec2f.o
>           CC
> linux-gnu-c-opt/obj/src/vec/vec/impls/seq/ftn-custom/zvsectionf.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/ftn-auto/vseqcrf.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/pbvec.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/pdvec.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/pvec2.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/vmpicr.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/commonmpvec.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/ftn-auto/pbvecf.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/ftn-auto/vmpicrf.o
>           CC
> linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/ftn-auto/commonmpvecf.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/ftn-custom/zpbvecf.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/vector.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/veccreate.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/vecreg.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/vecregall.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/dlregisvec.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/rvector.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/ftn-auto/vectorf.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/interface/ftn-auto/rvectorf.o
>           CC
> linux-gnu-c-opt/obj/src/vec/vec/interface/ftn-auto/veccreatef.o
>           CC
> linux-gnu-c-opt/obj/src/vec/vec/interface/f90-custom/zvectorf90.o
>           CC
> linux-gnu-c-opt/obj/src/vec/vec/interface/ftn-custom/zvecregf.o
>           CC
> linux-gnu-c-opt/obj/src/vec/vec/interface/ftn-custom/zvectorf.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vinv.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vscat.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vpscat.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vecio.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/comb.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vecstash.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vecmpitoseq.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vecs.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vsection.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/projection.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/vecmpitoseqf.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/vpscatf.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/veciof.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/vinvf.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/projectionf.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/combf.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/vscatf.o
>           CC
> linux-gnu-c-opt/obj/src/vec/vec/utils/f90-custom/zvsectionf90.o
>           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-custom/zvscatf.o
>           CC linux-gnu-c-opt/obj/src/mat/ftn-custom/zmat.o
>           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/color.o
>           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/degr.o
>           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/dsm.o
>           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/ido.o
>           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/numsrt.o
>           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/seq.o
>           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/setr.o
>           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/slo.o
>           CC linux-gnu-c-opt/obj/src/mat/color/impls/natural/natural.o
>           CC linux-gnu-c-opt/obj/src/mat/color/impls/jp/jp.o
>           CC linux-gnu-c-opt/obj/src/mat/color/impls/power/power.o
>           CC linux-gnu-c-opt/obj/src/mat/color/impls/greedy/greedy.o
>           CC linux-gnu-c-opt/obj/src/mat/color/interface/matcoloring.o
>           CC linux-gnu-c-opt/obj/src/mat/color/interface/matcoloringregi.o
>           CC
> linux-gnu-c-opt/obj/src/mat/color/interface/ftn-auto/matcoloringf.o
>           CC
> linux-gnu-c-opt/obj/src/mat/color/interface/ftn-custom/zmatcoloringf.o
>           CC linux-gnu-c-opt/obj/src/mat/color/utils/bipartite.o
>           CC linux-gnu-c-opt/obj/src/mat/color/utils/valid.o
>           CC linux-gnu-c-opt/obj/src/mat/color/utils/weights.o
>           CC linux-gnu-c-opt/obj/src/mat/partition/partition.o
>           CC linux-gnu-c-opt/obj/src/mat/partition/spartition.o
>           CC
> linux-gnu-c-opt/obj/src/mat/partition/impls/hierarchical/hierarchical.o
>           CC linux-gnu-c-opt/obj/src/mat/partition/impls/scotch/scotch.o
>           CC
> linux-gnu-c-opt/obj/src/mat/partition/impls/scotch/ftn-auto/scotchf.o
>           CC linux-gnu-c-opt/obj/src/mat/partition/impls/chaco/chaco.o
>           CC
> linux-gnu-c-opt/obj/src/mat/partition/impls/chaco/ftn-auto/chacof.o
>           CC linux-gnu-c-opt/obj/src/mat/partition/ftn-auto/partitionf.o
>           CC linux-gnu-c-opt/obj/src/mat/partition/ftn-custom/zpartitionf.o
>           CC linux-gnu-c-opt/obj/src/mat/coarsen/coarsen.o
>           CC linux-gnu-c-opt/obj/src/mat/coarsen/scoarsen.o
>           CC linux-gnu-c-opt/obj/src/mat/coarsen/impls/hem/hem.o
>           CC linux-gnu-c-opt/obj/src/mat/coarsen/impls/mis/mis.o
>           CC linux-gnu-c-opt/obj/src/mat/coarsen/ftn-auto/coarsenf.o
>           CC linux-gnu-c-opt/obj/src/mat/interface/matrix.o
>           CC linux-gnu-c-opt/obj/src/mat/interface/mhas.o
>           CC linux-gnu-c-opt/obj/src/mat/interface/matreg.o
>           CC linux-gnu-c-opt/obj/src/mat/interface/matregis.o
>           CC linux-gnu-c-opt/obj/src/mat/interface/matnull.o
>           CC linux-gnu-c-opt/obj/src/mat/interface/dlregismat.o
>           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-auto/matrixf.o
>           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-auto/mhasf.o
>           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-auto/matnullf.o
>           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-custom/zmatregf.o
>           CC linux-gnu-c-opt/obj/src/mat/interface/f90-custom/zmatrixf90.o
>           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-custom/zmatrixf.o
>           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-custom/zmatnullf.o
>           CC linux-gnu-c-opt/obj/src/mat/matfd/fdmatrix.o
>           CC linux-gnu-c-opt/obj/src/mat/matfd/ftn-auto/fdmatrixf.o
>           CC linux-gnu-c-opt/obj/src/mat/matfd/ftn-custom/zfdmatrixf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/submat/submat.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/submat/ftn-auto/submatf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/is/matis.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/is/ftn-auto/matisf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/fft/fft.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/fft/ftn-custom/zfftf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baij2.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact2.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgedi.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa3.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa4.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa5.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa2.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa6.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa7.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/aijbaij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact3.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact4.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact5.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact7.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact9.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact11.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact13.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijsolvtrannat.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijsolvtran.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijsolv.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijsolvnat.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/ftn-auto/baijf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/ftn-custom/zbaijf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/bstream/bstream.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/bstream/bstrmfact.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/mpibaij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/mmbaij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/baijov.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/mpb_baij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/ftn-auto/mpibaijf.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/ftn-custom/zmpibaijf.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/bstream/mpibstream.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/dense/seq/dense.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/dense/seq/ftn-custom/zdensef.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/dense/mpi/mpidense.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/dense/mpi/mmdense.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/dense/mpi/ftn-auto/mpidensef.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/dense/mpi/ftn-custom/zmpidensef.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/mffd.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/mffddef.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/mfregis.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/wp.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/ftn-auto/mffdf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/ftn-auto/wpf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/ftn-auto/mffddeff.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/ftn-custom/zmffdf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/composite/mcomposite.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/composite/ftn-auto/mcompositef.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/adj/mpi/mpiadj.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/adj/mpi/ftn-auto/mpiadjf.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/adj/mpi/ftn-custom/zmpiadjf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/maij/maij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/maij/ftn-auto/maijf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/lrc/lrc.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/lrc/ftn-auto/lrcf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/shell/shell.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/shell/shellcnv.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/shell/ftn-auto/shellf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/shell/ftn-custom/zshellf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/normal/normm.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/normal/normmh.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/normal/ftn-auto/normmhf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/normal/ftn-auto/normmf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/python/pythonmat.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/python/ftn-custom/zpythonmf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/nest/matnest.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/nest/ftn-auto/matnestf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/nest/ftn-custom/zmatnestf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/transpose/transm.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/transpose/htransm.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/transpose/ftn-auto/htransmf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/transpose/ftn-auto/transmf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/localref/mlocalref.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/localref/ftn-auto/mlocalreff.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/blockmat/seq/blockmat.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaij2.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact2.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sro.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact3.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact4.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact5.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact6.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact7.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact8.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact9.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact10.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact11.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact12.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/aijsbaij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/ftn-auto/sbaijf.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/ftn-custom/zsbaijf.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbstream/sbstream.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbstream/sbstrmfact.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/mpisbaij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/mmsbaij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/sbaijov.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/mpiaijsbaij.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/ftn-auto/mpisbaijf.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/ftn-custom/zmpisbaijf.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/sbstream/mpisbstream.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/aij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/aijfact.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/ij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/fdaij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/matmatmult.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/symtranspose.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/matptap.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/matrart.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/inode.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/inode2.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/matmatmatmult.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/aij/seq/mattransposematmult.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/ftn-custom/zaijf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/bas/basfactor.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/bas/spbas.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/csrperm/csrperm.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/crl/crl.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/ftn-auto/aijf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpiaij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mmaij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpiaijpc.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpiov.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/fdmpiaij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpiptap.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpimatmatmult.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpb_aij.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpimatmatmatmult.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpimattransposematmult.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/ftn-custom/zmpiaijf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/csrperm/mpicsrperm.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/ftn-auto/mpiaijf.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/crl/mcrl.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/scatter/mscatter.o
>           CC linux-gnu-c-opt/obj/src/mat/impls/scatter/ftn-auto/mscatterf.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/preallocator/matpreallocator.o
>           CC
> linux-gnu-c-opt/obj/src/mat/impls/preallocator/ftn-auto/matpreallocatorf.o
>           CC linux-gnu-c-opt/obj/src/mat/order/sp1wd.o
>           CC linux-gnu-c-opt/obj/src/mat/order/spnd.o
>           CC linux-gnu-c-opt/obj/src/mat/order/spqmd.o
>           CC linux-gnu-c-opt/obj/src/mat/order/sprcm.o
>           CC linux-gnu-c-opt/obj/src/mat/order/sorder.o
>           CC linux-gnu-c-opt/obj/src/mat/order/spectral.o
>           CC linux-gnu-c-opt/obj/src/mat/order/sregis.o
>           CC linux-gnu-c-opt/obj/src/mat/order/degree.o
>           CC linux-gnu-c-opt/obj/src/mat/order/fnroot.o
>           CC linux-gnu-c-opt/obj/src/mat/order/genqmd.o
>           CC linux-gnu-c-opt/obj/src/mat/order/qmdqt.o
>           CC linux-gnu-c-opt/obj/src/mat/order/rcm.o
>           CC linux-gnu-c-opt/obj/src/mat/order/fn1wd.o
>           CC linux-gnu-c-opt/obj/src/mat/order/gen1wd.o
>           CC linux-gnu-c-opt/obj/src/mat/order/genrcm.o
>           CC linux-gnu-c-opt/obj/src/mat/order/qmdrch.o
>           CC linux-gnu-c-opt/obj/src/mat/order/rootls.o
>           CC linux-gnu-c-opt/obj/src/mat/order/fndsep.o
>           CC linux-gnu-c-opt/obj/src/mat/order/gennd.o
>           CC linux-gnu-c-opt/obj/src/mat/order/qmdmrg.o
>           CC linux-gnu-c-opt/obj/src/mat/order/qmdupd.o
>           CC linux-gnu-c-opt/obj/src/mat/order/wbm.o
>           CC linux-gnu-c-opt/obj/src/mat/order/ftn-auto/spectralf.o
>           CC linux-gnu-c-opt/obj/src/mat/order/ftn-custom/zsorderf.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/convert.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/matstash.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/axpy.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/zerodiag.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/getcolv.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/gcreate.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/freespace.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/compressedrow.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/multequal.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/matstashspace.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/pheap.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/bandwidth.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/overlapsplit.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/bandwidthf.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/zerodiagf.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/getcolvf.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/axpyf.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/gcreatef.o
>           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/multequalf.o
>           CC linux-gnu-c-opt/obj/src/dm/label/dmlabel.o
>           CC linux-gnu-c-opt/obj/src/dm/label/ftn-auto/dmlabelf.o
>           CC linux-gnu-c-opt/obj/src/dm/label/ftn-custom/zdmlabel.o
>           CC linux-gnu-c-opt/obj/src/dm/interface/dm.o
>           CC linux-gnu-c-opt/obj/src/dm/interface/dmregall.o
>           CC linux-gnu-c-opt/obj/src/dm/interface/dmget.o
>           CC linux-gnu-c-opt/obj/src/dm/interface/dmi.o
>           CC linux-gnu-c-opt/obj/src/dm/interface/dlregisdmdm.o
>           CC linux-gnu-c-opt/obj/src/dm/interface/ftn-auto/dmf.o
>           CC linux-gnu-c-opt/obj/src/dm/interface/ftn-auto/dmgetf.o
>           CC linux-gnu-c-opt/obj/src/dm/interface/ftn-custom/zdmf.o
>           CC linux-gnu-c-opt/obj/src/dm/interface/ftn-custom/zdmgetf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/shell/dmshell.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/shell/ftn-auto/dmshellf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/shell/ftn-custom/zdmshellf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/network/networkcreate.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/network/network.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/network/networkmonitor.o
>           CC
> linux-gnu-c-opt/obj/src/dm/impls/network/ftn-auto/networkmonitorf.o
>           CC
> linux-gnu-c-opt/obj/src/dm/impls/network/ftn-auto/networkcreatef.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/network/ftn-auto/networkf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/composite/pack.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/composite/packm.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/composite/ftn-auto/packf.o
>           CC
> linux-gnu-c-opt/obj/src/dm/impls/composite/f90-custom/zfddaf90.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/composite/ftn-custom/zfddaf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/da2.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/da1.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/da3.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/daghost.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dacorn.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dagtol.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/daltol.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/daindex.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dascatter.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dacreate.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dadestroy.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dalocal.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dadist.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/daview.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dasub.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/gr1.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/gr2.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dagtona.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dainterp.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dapf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dagetarray.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dagetelem.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/da.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dareg.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/fdda.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/grvtk.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dageometry.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dadd.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/dapreallocate.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dageometryf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/daghostf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dagtonaf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dagtolf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dagetarrayf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dadistf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/gr1f.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/daddf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dapreallocatef.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dacornf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/daindexf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/daf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/fddaf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dalocalf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dacreatef.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dainterpf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/f90-custom/zda1f90.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zdaf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zda1f.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zda2f.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zda3f.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zdacornf.o
>           CC
> linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zdagetscatterf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zdaviewf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zdaindexf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/redundant/dmredundant.o
>           CC
> linux-gnu-c-opt/obj/src/dm/impls/redundant/ftn-auto/dmredundantf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexcreate.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plex.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexpartition.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexrefine.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexdistribute.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexcoarsen.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexinterpolate.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexpreallocate.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexreorder.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexgeometry.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexsubmesh.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexhdf5.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexexodusii.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexgmsh.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexfluent.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexcgns.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexvtk.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexpoint.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexvtu.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexfem.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexindices.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plextree.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexgenerate.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexorient.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexnatural.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexcgnsf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexpointf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexindicesf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexcreatef.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexgeneratef.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexsubmeshf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexorientf.o
>           CC
> linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexpartitionf.o
>           CC
> linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexinterpolatef.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexreorderf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plextreef.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexrefinef.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexfemf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexnaturalf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexgmshf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexgeometryf.o
>           CC
> linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexdistributef.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexexodusiif.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/f90-custom/zplexf90.o
>           CC
> linux-gnu-c-opt/obj/src/dm/impls/plex/f90-custom/zplexgeometryf90.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplex.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplexcreate.o
>           CC
> linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplexdistribute.o
>           CC
> linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplexinterpolate.o
>           CC
> linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplexsubmesh.o
>           CC
> linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplexexodusii.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplexgmsh.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplexfluent.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/sliced/sliced.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/forest/forest.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/forest/ftn-auto/forestf.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/patch/patchcreate.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/patch/patch.o
>           CC linux-gnu-c-opt/obj/src/dm/impls/patch/ftn-auto/patchcreatef.o
>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/dt.o
>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/dtfe.o
>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/dtfv.o
>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/dtds.o
>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/ftn-auto/dtdsf.o
>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/ftn-auto/dtf.o
>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/ftn-auto/dtfvf.o
>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/ftn-auto/dtfef.o
>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/f90-custom/zdtf90.o
>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/f90-custom/zdtdsf90.o
>           CC linux-gnu-c-opt/obj/src/dm/dt/interface/ftn-custom/zdtf.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bddc/bddcprivate.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bddc/bddc.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bddc/bddcgraph.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bddc/bddcscalingbasic.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bddc/bddcnullspace.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bddc/bddcfetidp.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bddc/bddcschurs.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bddc/ftn-auto/bddcf.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/lsc/lsc.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bjacobi/bjacobi.o
>           CC
> linux-gnu-c-opt/obj/src/ksp/pc/impls/bjacobi/ftn-auto/bjacobif.o
>           CC
> linux-gnu-c-opt/obj/src/ksp/pc/impls/bjacobi/ftn-custom/zbjacobif.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/is/pcis.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/is/ftn-auto/pcisf.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/is/nn/nn.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/mg.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/fmg.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/smg.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/mgfunc.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/ftn-auto/mgfuncf.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/ftn-auto/mgf.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/ftn-custom/zmgf.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/ftn-custom/zmgfuncf.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/sor/sor.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/sor/ftn-auto/sorf.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/pbjacobi/pbjacobi.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/cp/cp.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/eisens/eisen.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/eisens/ftn-auto/eisenf.o
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/telescope/telescope.o
>           CC
> linux-gnu-c-opt/obj/src/ksp/pc/impls/telescope/telescope_dmda.o
>           CC
> linux-gnu-c-opt/obj/src/ksp/pc/impls/telescope/ftn-auto/telescopef.o
> /home/acro018/software/PETSc/code/src/ksp/pc/impls/telescope/telescope.c:
> In function ‘PCSetUp_Telescope’:
> /home/acro018/software/PETSc/code/src/ksp/pc/impls/telescope/telescope.c:314:52:
> error: ‘struct _p_PC’ has no member named ‘nonzero_guess’
> In function ‘PCApply_Telescope’:
> /home/acro018/software/PETSc/code/src/ksp/pc/impls/telescope/telescope.c:420:9:
>           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/ksp/pcksp.o
> make[2]: *** [linux-gnu-c-opt/obj/src/ksp/pc/impls/telescope/telescope.o]
> Error 1
> make[2]: *** Waiting for unfinished jobs....
> /home/acro018/software/PETSc/code/src/ksp/pc/impls/telescope/telescope_dmda.c:
> In function ‘PCTelescopeMatCreate_dmda’:
> /home/acro018/software/PETSc/code/src/ksp/pc/impls/telescope/telescope_dmda.c:786:12:
> warning: variable ‘Bk’ set but not used [-Wunused-but-set-variable]
> In function ‘PCApply_Telescope_dmda’:
> /home/acro018/software/PETSc/code/src/ksp/pc/impls/telescope/telescope_dmda.c:904:9:
> make[2]: ***
> [linux-gnu-c-opt/obj/src/ksp/pc/impls/telescope/telescope_dmda.o] Error 1
> make[1]: *** [gnumake] Error 2
> make[1]: Leaving directory `/home/acro018/software/PETSc/code'
> [1;31m**************************ERROR*************************************
>   Error during compile, check linux-gnu-c-opt/lib/petsc/conf/make.log
>   Send it and linux-gnu-c-opt/lib/petsc/conf/configure.log to
> petsc-maint at mcs.anl.gov
> [0;39m [0;49m
> Finishing at: Fri Mar 18 13:44:58 NZDT 2016
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 84611
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160317/cc511449/attachment.html>
