[petsc-dev] PETSc blame digest (next) 2016-03-17
Dave May dave.mayhem23 at gmail.com
Thu Mar 17 09:37:04 CDT 2016
I've removed the unused variable and pushed the change.
PR426 (which introduced this commit) has been updated accordingly.
  Dave
On 17 March 2016 at 15:00, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov>
wrote:
> Dear PETSc developer,
> This email contains listings of contributions attributed to you by
> `git blame` that caused compiler errors or warnings in PETSc automated
> testing.  Follow the links to see the full log files. Please attempt to fix
> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are
> unable
> to resolve the issues.
> Thanks,
>   The PETSc development team
> warnings attributed to commit
> https://bitbucket.org/petsc/petsc/commits/ba1c356
> PCTelescope: * Added support for the case when KSPComputeOperators has
> been set
>   src/ksp/pc/impls/telescope/telescope_dmda.c:786
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-c-exodus-dbg-builder_frog.log
> /home/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:786:12:
> warning: variable 'Bk' set but not used [-Wunused-but-set-variable]
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-linux-pkgs-64idx_thrash.log
> /sandbox/petsc/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:786:12:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-linux-uni_crush.log
> /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:786:12:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-linux-pkgs-opt_crank.log
> /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:786:12:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-cuda-double_frog.log
> /home/balay/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:786:12:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-linux-gcc-pgf90_grind.log
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-linux-xsdk-dbg_cg.log
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log
> /usr/home/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:786:12:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-freebsd-cxx-pkgs-opt_wii.log
> /usr/home/balay/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:786:12:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-linux-pkgs-valgrind_grind.log
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-linux-pkgs-cxx-mlib_el6.log
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-linux-gcc-absoft_churn.log
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-freebsd-pkgs-opt_wii.log
> /usr/home/balay/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:786:12:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-linux-opt-cxx-quad_grind.log
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-viennacl_frog.log
> /home/balay/petsc.clone-4/src/ksp/pc/impls/telescope/telescope_dmda.c:786:12:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-cuda-single_frog.log
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-linux-pkgs-threadcomm_el6.log
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-linux-dbg-quad_churn.log
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/17/build_next_arch-linux-gcc-ifc-cmplx_crank.log
> To opt-out from receiving these messages - send a request to
> petsc-dev at mcs.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160317/6fa2ca35/attachment.html>
