[petsc-dev] DMPlex label distribution
Adrian Croucher a.croucher at auckland.ac.nz
Thu Mar 17 19:49:23 CDT 2016
hi
On 18/03/16 13:13, Matthew Knepley wrote:
> I believe I have fixed your bug:
> https://bitbucket.org/petsc/petsc/branch/knepley/fix-plex-distribute-label
> I merged to next, and it will get to master before the release.
Great, thanks- that does seem to have fixed it!
I can build your fix-plex-distribute-label branch OK, but currently am
getting build errors when I try to build 'next' (the problem seems to be
ksp/pc/impls/telescope/telescope.c). The make log is below.
Cheers, Adrian
make[1]: Entering directory `/home/acro018/software/PETSc/code'
See documentation/faq.html and documentation/bugreporting.html
for help with installation problems.  Please send EVERYTHING
printed out below when reporting problems.  Please check the
mailing list archives and consider subscribing.
   http://www.mcs.anl.gov/petsc/miscellaneous/mailing-lists.html
Starting on des108 at Fri Mar 18 13:44:32 NZDT 2016
Machine characteristics: Linux des108 3.2.0-4-amd64 #1 SMP Debian
3.2.73-2+deb7u2 x86_64 GNU/Linux
Using PETSc directory: /home/acro018/software/PETSc/code
Using PETSc arch: linux-gnu-c-opt
PETSC_VERSION_RELEASE    0
PETSC_VERSION_MAJOR      3
PETSC_VERSION_MINOR      6
PETSC_VERSION_SUBMINOR   3
PETSC_VERSION_PATCH      0
PETSC_VERSION_DATE       "unknown"
PETSC_VERSION_GIT        "unknown"
PETSC_VERSION_DATE_GIT   "unknown"
PETSC_VERSION_(MAJOR,MINOR,SUBMINOR) \
PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR)          \
PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
Using configure Options: --download-netcdf --download-exodusii
--with-hdf5-dir=/usr --download-triangle --download-ptscotch
--download-chaco
Using configuration flags:
#define INCLUDED_PETSCCONF_H
#define ANSI_DECLARATORS 1
#define IS_COLORING_MAX 65535
#define STDC_HEADERS 1
#define MPIU_COLORING_VALUE MPI_UNSIGNED_SHORT
#define PETSC_UINTPTR_T uintptr_t
#define PETSC_HAVE_PTHREAD 1
#define PETSC_HAVE_SSL 1
#define PETSC_DEPRECATED(why) __attribute((deprecated))
#define PETSC_REPLACE_DIR_SEPARATOR '\\'
#define PETSC_HAVE_HDF5 1
#define PETSC_HAVE_TRIANGLE 1
#define PETSC_HAVE_SO_REUSEADDR 1
#define PETSC_HAVE_MPI 1
#define PETSC_PREFETCH_HINT_T2 _MM_HINT_T2
#define PETSC_PREFETCH_HINT_T0 _MM_HINT_T0
#define PETSC_PREFETCH_HINT_T1 _MM_HINT_T1
#define PETSC_HAVE_FORTRAN 1
#define PETSC_DIR "/home/acro018/software/PETSc/code"
#define PETSC_HAVE_X 1
#define PETSC_LIB_DIR
"/home/acro018/software/PETSc/code/linux-gnu-c-opt/lib"
#define PETSC_USE_SOCKET_VIEWER 1
#define PETSC_USE_ISATTY 1
#define PETSC_HAVE_SOWING 1
#define PETSC_SLSUFFIX "so"
#define PETSC_FUNCTION_NAME_CXX __func__
#define PETSC_HAVE_ATOLL 1
#define PETSC_HAVE_ATTRIBUTEALIGNED 1
#define PETSC_HAVE_DOUBLE_ALIGN_MALLOC 1
#define PETSC_UNUSED __attribute((unused))
#define PETSC_ATTRIBUTEALIGNED(size) __attribute((aligned (size)))
#define PETSC_FUNCTION_NAME_C __func__
#define PETSC_HAVE_EXODUSII 1
#define PETSC_HAVE_VALGRIND 1
#define PETSC_USE_SINGLE_LIBRARY 1
#define PETSC_HAVE_CHACO 1
#define PETSC_HAVE_BUILTIN_EXPECT 1
#define PETSC_HAVE_PTSCOTCH 1
#define PETSC_HAVE_NETCDF 1
#define PETSC_DIR_SEPARATOR '/'
#define PETSC_PATH_SEPARATOR ':'
#define PETSC_HAVE_XMMINTRIN_H 1
#define PETSC_PREFETCH_HINT_NTA _MM_HINT_NTA
#define PETSC_Prefetch(a,b,c) _mm_prefetch((const char*)(a),(c))
#define PETSC_HAVE_BLASLAPACK 1
#define PETSC_HAVE_GZIP 1
#define PETSC_HAVE_STRING_H 1
#define PETSC_HAVE_SYS_TYPES_H 1
#define PETSC_HAVE_ENDIAN_H 1
#define PETSC_HAVE_SYS_PROCFS_H 1
#define PETSC_HAVE_DLFCN_H 1
#define PETSC_HAVE_SCHED_H 1
#define PETSC_HAVE_STDINT_H 1
#define PETSC_HAVE_LINUX_KERNEL_H 1
#define PETSC_HAVE_TIME_H 1
#define PETSC_HAVE_MATH_H 1
#define PETSC_TIME_WITH_SYS_TIME 1
#define PETSC_HAVE_SYS_PARAM_H 1
#define PETSC_HAVE_PTHREAD_H 1
#define PETSC_HAVE_UNISTD_H 1
#define PETSC_HAVE_STDLIB_H 1
#define PETSC_HAVE_SYS_WAIT_H 1
#define PETSC_HAVE_SETJMP_H 1
#define PETSC_HAVE_LIMITS_H 1
#define PETSC_HAVE_SYS_UTSNAME_H 1
#define PETSC_HAVE_NETINET_IN_H 1
#define PETSC_HAVE_SYS_SOCKET_H 1
#define PETSC_HAVE_FLOAT_H 1
#define PETSC_HAVE_SEARCH_H 1
#define PETSC_HAVE_SYS_RESOURCE_H 1
#define PETSC_HAVE_SYS_TIMES_H 1
#define PETSC_HAVE_NETDB_H 1
#define PETSC_HAVE_MALLOC_H 1
#define PETSC_HAVE_PWD_H 1
#define PETSC_HAVE_FCNTL_H 1
#define PETSC_HAVE_STRINGS_H 1
#define PETSC_HAVE_SYS_SYSINFO_H 1
#define PETSC_HAVE_SYS_TIME_H 1
#define PETSC_USING_F90 1
#define PETSC_USING_F2003 1
#define PETSC_HAVE_RTLD_NOW 1
#define PETSC_HAVE_RTLD_LOCAL 1
#define PETSC_HAVE_RTLD_LAZY 1
#define PETSC_C_STATIC_INLINE static inline
#define PETSC_HAVE_FORTRAN_UNDERSCORE 1
#define PETSC_HAVE_CXX_NAMESPACE 1
#define PETSC_HAVE_RTLD_GLOBAL 1
#define PETSC_C_RESTRICT  __restrict__
#define PETSC_CXX_RESTRICT  __restrict__
#define PETSC_CXX_STATIC_INLINE static inline
#define PETSC_HAVE_LIBBLAS 1
#define PETSC_HAVE_LIBZ 1
#define PETSC_HAVE_LIBDL 1
#define PETSC_HAVE_LIBGFORTRAN 1
#define PETSC_HAVE_LIBLAPACK 1
#define PETSC_HAVE_LIBCRYPTO 1
#define PETSC_HAVE_LIBPTSCOTCH 1
#define PETSC_HAVE_LIBM 1
#define PETSC_HAVE_LIBSCOTCHERR 1
#define PETSC_HAVE_LIBTRIANGLE 1
#define PETSC_HAVE_LIBPTESMUMPS 1
#define PETSC_HAVE_LIBMPI_F77 1
#define PETSC_HAVE_LIBHDF5 1
#define PETSC_HAVE_LIBMPI_F90 1
#define PETSC_HAVE_LIBNETCDF 1
#define PETSC_HAVE_LIBHDF5HL_FORTRAN 1
#define PETSC_HAVE_LIBX11 1
#define PETSC_HAVE_FENV_H 1
#define PETSC_HAVE_LIBEXODUS 1
#define PETSC_HAVE_LOG2 1
#define PETSC_HAVE_LIBHDF5_HL 1
#define PETSC_HAVE_LIBRT 1
#define PETSC_HAVE_LIBPTSCOTCHERR 1
#define PETSC_HAVE_LIBEXOIIV2FOR 1
#define PETSC_HAVE_ERF 1
#define PETSC_HAVE_LIBSSL 1
#define PETSC_HAVE_LIBQUADMATH 1
#define PETSC_HAVE_LIBHDF5_FORTRAN 1
#define PETSC_HAVE_LIBCHACO 1
#define PETSC_HAVE_TGAMMA 1
#define PETSC_HAVE_LIBSCOTCH 1
#define PETSC_ARCH "linux-gnu-c-opt"
#define PETSC_USE_SCALAR_REAL 1
#define PETSC_HAVE_ISINF 1
#define PETSC_HAVE_ISNAN 1
#define PETSC_HAVE_ISNORMAL 1
#define PETSC_USE_REAL_DOUBLE 1
#define PETSC_SIZEOF_MPI_COMM 8
#define PETSC_BITS_PER_BYTE 8
#define PETSC_SIZEOF_MPI_FINT 4
#define PETSC_USE_VISIBILITY_C 1
#define PETSC_SIZEOF_VOID_P 8
#define PETSC_RETSIGTYPE void
#define PETSC_HAVE_CXX_COMPLEX 1
#define PETSC_SIZEOF_LONG 8
#define PETSC_USE_FORTRANKIND 1
#define PETSC_USE_VISIBILITY_CXX 1
#define PETSC_SIZEOF_SIZE_T 8
#define PETSC_HAVE_SIGINFO_T 1
#define PETSC_SIZEOF_CHAR 1
#define PETSC_SIZEOF_DOUBLE 8
#define PETSC_SIZEOF_FLOAT 4
#define PETSC_HAVE_C99_COMPLEX 1
#define PETSC_SIZEOF_INT 4
#define PETSC_SIZEOF_LONG_LONG 8
#define PETSC_SIZEOF_SHORT 2
#define PETSC_CLANGUAGE_C 1
#define PETSC_HAVE_MPI_F90MODULE 1
#define PETSC_HAVE_OMPI_MINOR_VERSION 4
#define PETSC_HAVE_MPI_IN_PLACE 1
#define PETSC_HAVE_MPI_COMM_C2F 1
#define PETSC_HAVE_MPI_COMBINER_CONTIGUOUS 1
#define PETSC_HAVE_MPI_TYPE_GET_EXTENT 1
#define PETSC_HAVE_MPI_WIN_CREATE 1
#define PETSC_HAVE_MPI_TYPE_DUP 1
#define PETSC_HAVE_MPI_INIT_THREAD 1
#define PETSC_HAVE_MPI_LONG_DOUBLE 1
#define PETSC_HAVE_MPI_COMM_F2C 1
#define PETSC_HAVE_MPI_TYPE_GET_ENVELOPE 1
#define PETSC_HAVE_MPI_ALLTOALLW 1
#define PETSC_HAVE_OMPI_MAJOR_VERSION 1
#define PETSC_HAVE_MPI_REDUCE_SCATTER 1
#define PETSC_HAVE_MPIIO 1
#define PETSC_HAVE_MPI_COMM_SPAWN 1
#define PETSC_HAVE_MPI_FINT 1
#define PETSC_HAVE_MPI_FINALIZED 1
#define PETSC_HAVE_OMPI_RELEASE_VERSION 5
#define PETSC_HAVE_MPI_REPLACE 1
#define PETSC_HAVE_MPI_EXSCAN 1
#define PETSC_HAVE_MPI_COMBINER_DUP 1
#define PETSC_USE_ERRORCHECKING 1
#define PETSC_HAVE_STRCASECMP 1
#define PETSC_HAVE_GET_NPROCS 1
#define PETSC_HAVE_POPEN 1
#define PETSC_HAVE_SIGSET 1
#define PETSC_HAVE_GETWD 1
#define PETSC_HAVE_VSNPRINTF 1
#define PETSC_HAVE_TIMES 1
#define PETSC_HAVE_DLSYM 1
#define PETSC_HAVE_SNPRINTF 1
#define PETSC_HAVE_GETHOSTBYNAME 1
#define PETSC_HAVE_GETCWD 1
#define PETSC_HAVE_DLERROR 1
#define PETSC_HAVE_FORK 1
#define PETSC_HAVE_RAND 1
#define PETSC_HAVE_GETTIMEOFDAY 1
#define PETSC_HAVE_DLCLOSE 1
#define PETSC_HAVE_UNAME 1
#define PETSC_HAVE_GETHOSTNAME 1
#define PETSC_HAVE_MKSTEMP 1
#define PETSC_HAVE_SIGACTION 1
#define PETSC_HAVE_DRAND48 1
#define PETSC_HAVE_MEMALIGN 1
#define PETSC_HAVE_VA_COPY 1
#define PETSC_HAVE_CLOCK 1
#define PETSC_HAVE_ACCESS 1
#define PETSC_HAVE_SIGNAL 1
#define PETSC_HAVE_USLEEP 1
#define PETSC_HAVE_GETRUSAGE 1
#define PETSC_HAVE_VFPRINTF 1
#define PETSC_HAVE_NANOSLEEP 1
#define PETSC_HAVE_GETDOMAINNAME 1
#define PETSC_HAVE_TIME 1
#define PETSC_HAVE_LSEEK 1
#define PETSC_HAVE_SOCKET 1
#define PETSC_HAVE_SYSINFO 1
#define PETSC_HAVE_READLINK 1
#define PETSC_HAVE_REALPATH 1
#define PETSC_HAVE_DLOPEN 1
#define PETSC_HAVE_MEMMOVE 1
#define PETSC_HAVE__GFORTRAN_IARGC 1
#define PETSC_HAVE_GETPAGESIZE 1
#define PETSC_HAVE_SLEEP 1
#define PETSC_HAVE_VPRINTF 1
#define PETSC_HAVE_BZERO 1
#define PETSC_SIGNAL_CAST
#define PETSC_WRITE_MEMORY_BARRIER() asm volatile("sfence":::"memory")
#define PETSC_MEMORY_BARRIER() asm volatile("mfence":::"memory")
#define PETSC_READ_MEMORY_BARRIER() asm volatile("lfence":::"memory")
#define PETSC_CPU_RELAX() asm volatile("rep; nop" ::: "memory")
#define PETSC_BLASLAPACK_UNDERSCORE 1
#define PETSC_MEMALIGN 16
#define PETSC_VERSION_DATE_GIT "2016-03-17 19:05:32 -0500"
#define PETSC_VERSION_BRANCH_GIT "next"
#define PETSC_VERSION_GIT "pre-tsfc-2164-g9eb648e"
#define PETSC_USE_INFO 1
#define PETSC_Alignx(a,b)
#define PETSC_USE_BACKWARD_LOOP 1
#define PETSC_USE_DEBUG 1
#define PETSC_IS_COLOR_VALUE_TYPE_SIZE PETSC_SIZEOF_SHORT
#define PETSC_USE_LOG 1
#define PETSC_IS_COLOR_VALUE_TYPE short
#define PETSC_USE_CTABLE 1
#define PETSC_HAVE_DYNAMIC_LIBRARIES 1
#define PETSC_HAVE_SHARED_LIBRARIES 1
#define PETSC_USE_SHARED_LIBRARIES 1
#define PETSC_USE_GDB_DEBUGGER 1
#define PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT 1
#define PETSC_HAVE_GFORTRAN_IARGC 1
#define PETSC_USE_PROC_FOR_SIZE 1
#define PETSC_LEVEL1_DCACHE_LINESIZE 64
#define PETSC_LEVEL1_DCACHE_SIZE 32768
#define PETSC_LEVEL1_DCACHE_ASSOC 8
#define PETSC__GNU_SOURCE 1
#define PETSC__BSD_SOURCE 1
#define PETSC__DEFAULT_SOURCE 1
#define PETSC_HAVE_H5PSET_FAPL_MPIO 1
#define PETSC_HAVE_SCHED_CPU_SET_T 1
#define PETSC_HAVE_PTHREAD_BARRIER_T 1
#define PETSC_HAVE_SYS_SYSCTL_H 1
Using C/C++ compile: mpicc -c -fPIC  -Wall -Wwrite-strings
-Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3
-I/home/acro018/software/PETSc/code/include
-I/home/acro018/software/PETSc/code/linux-gnu-c-opt/include
-I/usr/include -I/usr/lib/openmpi/include
-I/usr/lib/openmpi/include/openmpi
mpicc -show: gcc -I/usr/lib/openmpi/include
-I/usr/lib/openmpi/include/openmpi -pthread -L/usr/lib/openmpi/lib -lmpi
-lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl
Using Fortran compile: mpif90 -c -fPIC -Wall -Wno-unused-variable
-ffree-line-length-0 -Wno-unused-dummy-argument -g
mpif90 -show: gfortran -I/usr/lib/openmpi/include -pthread
-I/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib -lmpi_f90 -lmpi_f77 -lmpi
Using C/C++ linker: mpicc
Using C/C++ flags: -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing
Using Fortran linker: mpif90
Using Fortran flags: -fPIC -Wall -Wno-unused-variable
Using libraries:
-Wl,-rpath,/home/acro018/software/PETSc/code/linux-gnu-c-opt/lib
-L/home/acro018/software/PETSc/code/linux-gnu-c-opt/lib  -lpetsc
-llapack -lblas
-ltriangle -lX11 -lptesmumps -lptscotch -lptscotcherr -lscotch
-lscotcherr -lexoIIv2for -lexodus -lnetcdf -Wl,-rpath,/usr/lib
-L/usr/lib -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lssl
-lcrypto -lchaco -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib
-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.7
-L/usr/lib/gcc/x86_64-linux-gnu/4.7 -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
-L/lib/x86_64-linux-gnu -lmpi_f90 -lmpi_f77 -lgfortran -lm -lgfortran
-lm -lgfortran -lm -lquadmath -lm -lmpi_cxx -lstdc++ -lrt -lm -lz
-L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -ldl -lmpi -lopen-rte -lopen-pal -lnsl
-lutil -lgcc_s -lpthread -ldl
Using mpiexec: mpiexec
Building PETSc using GNU Make with 7 build threads
make[2]: Entering directory `/home/acro018/software/PETSc/code'
/usr/bin/python ./config/gmakegen.py --petsc-arch=linux-gnu-c-opt
make[2]: Leaving directory `/home/acro018/software/PETSc/code'
Use "/usr/bin/make V=1" to see the verbose compile lines.
           CC linux-gnu-c-opt/obj/src/sys/info/verboseinfo.o
           CC linux-gnu-c-opt/obj/src/sys/info/ftn-auto/verboseinfof.o
           CC linux-gnu-c-opt/obj/src/sys/info/ftn-custom/zverboseinfof.o
           CC linux-gnu-c-opt/obj/src/sys/memory/mal.o
           CC linux-gnu-c-opt/obj/src/sys/memory/mem.o
           CC linux-gnu-c-opt/obj/src/sys/memory/mtr.o
           CC linux-gnu-c-opt/obj/src/sys/memory/ftn-auto/memf.o
           CC linux-gnu-c-opt/obj/src/sys/memory/ftn-custom/zmtrf.o
           CC linux-gnu-c-opt/obj/src/sys/ftn-custom/zsys.o
           CC linux-gnu-c-opt/obj/src/sys/ftn-custom/zutils.o
           CC linux-gnu-c-opt/obj/src/sys/logging/xmllogevent.o
           CC linux-gnu-c-opt/obj/src/sys/logging/plog.o
           CC linux-gnu-c-opt/obj/src/sys/logging/xmlviewer.o
           CC linux-gnu-c-opt/obj/src/sys/logging/ftn-auto/plogf.o
           CC linux-gnu-c-opt/obj/src/sys/logging/ftn-custom/zplogf.o
           CC linux-gnu-c-opt/obj/src/sys/logging/utils/classlog.o
           CC linux-gnu-c-opt/obj/src/sys/logging/utils/stagelog.o
           CC linux-gnu-c-opt/obj/src/sys/logging/utils/eventlog.o
           CC linux-gnu-c-opt/obj/src/sys/logging/utils/stack.o
           CC linux-gnu-c-opt/obj/src/sys/objects/version.o
           CC linux-gnu-c-opt/obj/src/sys/objects/gcomm.o
           CC linux-gnu-c-opt/obj/src/sys/objects/gtype.o
           CC linux-gnu-c-opt/obj/src/sys/objects/olist.o
           CC linux-gnu-c-opt/obj/src/sys/objects/pname.o
           CC linux-gnu-c-opt/obj/src/sys/objects/tagm.o
           CC linux-gnu-c-opt/obj/src/sys/objects/destroy.o
           CC linux-gnu-c-opt/obj/src/sys/objects/gcookie.o
           CC linux-gnu-c-opt/obj/src/sys/objects/inherit.o
           CC linux-gnu-c-opt/obj/src/sys/objects/options.o
           CC linux-gnu-c-opt/obj/src/sys/objects/pgname.o
           CC linux-gnu-c-opt/obj/src/sys/objects/prefix.o
           CC linux-gnu-c-opt/obj/src/sys/objects/init.o
           CC linux-gnu-c-opt/obj/src/sys/objects/pinit.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ptype.o
           CC linux-gnu-c-opt/obj/src/sys/objects/state.o
           CC linux-gnu-c-opt/obj/src/sys/objects/aoptions.o
           CC linux-gnu-c-opt/obj/src/sys/objects/subcomm.o
           CC linux-gnu-c-opt/obj/src/sys/objects/fcallback.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/inheritf.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/gcommf.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/statef.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/optionsf.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/destroyf.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/ptypef.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/tagmf.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-auto/pinitf.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zgcommf.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zoptionsf.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zpgnamef.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zpnamef.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zprefixf.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zdestroyf.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zstart.o
           CC linux-gnu-c-opt/obj/src/sys/objects/ftn-custom/zstartf.o
           CC linux-gnu-c-opt/obj/src/sys/python/pythonsys.o
           CC linux-gnu-c-opt/obj/src/sys/python/ftn-custom/zpythonf.o
           CC linux-gnu-c-opt/obj/src/sys/utils/arch.o
           CC linux-gnu-c-opt/obj/src/sys/utils/fhost.o
           CC linux-gnu-c-opt/obj/src/sys/utils/fuser.o
           CC linux-gnu-c-opt/obj/src/sys/utils/memc.o
           CC linux-gnu-c-opt/obj/src/sys/utils/mpiu.o
           CC linux-gnu-c-opt/obj/src/sys/utils/psleep.o
           CC linux-gnu-c-opt/obj/src/sys/utils/sortd.o
           CC linux-gnu-c-opt/obj/src/sys/utils/sorti.o
           CC linux-gnu-c-opt/obj/src/sys/utils/str.o
           CC linux-gnu-c-opt/obj/src/sys/utils/sortip.o
           CC linux-gnu-c-opt/obj/src/sys/utils/pbarrier.o
           CC linux-gnu-c-opt/obj/src/sys/utils/pdisplay.o
           CC linux-gnu-c-opt/obj/src/sys/utils/ctable.o
           CC linux-gnu-c-opt/obj/src/sys/utils/psplit.o
           CC linux-gnu-c-opt/obj/src/sys/utils/select.o
           CC linux-gnu-c-opt/obj/src/sys/utils/mpimesg.o
           CC linux-gnu-c-opt/obj/src/sys/utils/sseenabled.o
           CC linux-gnu-c-opt/obj/src/sys/utils/mpitr.o
           CC linux-gnu-c-opt/obj/src/sys/utils/mpilong.o
           CC linux-gnu-c-opt/obj/src/sys/utils/mathinf.o
           CC linux-gnu-c-opt/obj/src/sys/utils/mpits.o
           CC linux-gnu-c-opt/obj/src/sys/utils/segbuffer.o
           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/psleepf.o
           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/mpitsf.o
           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/psplitf.o
           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/sortif.o
           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/sortdf.o
           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/memcf.o
           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/sortipf.o
           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-auto/mpiuf.o
           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-custom/zarchf.o
           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-custom/zstrf.o
           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-custom/zpbarrierf.o
           CC linux-gnu-c-opt/obj/src/sys/utils/ftn-custom/zfhostf.o
           CC linux-gnu-c-opt/obj/src/sys/error/adebug.o
           CC linux-gnu-c-opt/obj/src/sys/error/err.o
           CC linux-gnu-c-opt/obj/src/sys/error/errtrace.o
           CC linux-gnu-c-opt/obj/src/sys/error/errabort.o
           CC linux-gnu-c-opt/obj/src/sys/error/errstop.o
           CC linux-gnu-c-opt/obj/src/sys/error/fp.o
           CC linux-gnu-c-opt/obj/src/sys/error/signal.o
           CC linux-gnu-c-opt/obj/src/sys/error/pstack.o
           CC linux-gnu-c-opt/obj/src/sys/error/checkptr.o
           CC linux-gnu-c-opt/obj/src/sys/error/ftn-auto/checkptrf.o
           CC linux-gnu-c-opt/obj/src/sys/error/ftn-auto/errf.o
           CC linux-gnu-c-opt/obj/src/sys/error/ftn-auto/signalf.o
           CC linux-gnu-c-opt/obj/src/sys/error/ftn-auto/adebugf.o
           CC linux-gnu-c-opt/obj/src/sys/error/ftn-auto/fpf.o
           CC linux-gnu-c-opt/obj/src/sys/error/ftn-custom/zerrf.o
           CC linux-gnu-c-opt/obj/src/sys/dll/dlimpl.o
           CC linux-gnu-c-opt/obj/src/sys/dll/dl.o
           CC linux-gnu-c-opt/obj/src/sys/dll/reg.o
           CC linux-gnu-c-opt/obj/src/sys/dll/ftn-auto/regf.o
           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/binary/binv.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/binary/ftn-auto/binvf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/binary/f90-custom/zbinvf90.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/binary/ftn-custom/zbinvf.o
           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/draw/drawv.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/draw/ftn-auto/drawvf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/draw/ftn-custom/zdrawvf.o
           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/socket/send.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/socket/ftn-custom/zsendf.o
           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/hdf5/hdf5v.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/hdf5/ftn-auto/hdf5vf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/hdf5/ftn-custom/zhdf5f.o
           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/vtk/vtkv.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/vtk/ftn-custom/zvtkvf.o
           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/vu/petscvu.o
           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/ascii/filev.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/ascii/vcreatea.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/ascii/ftn-auto/filevf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/ascii/ftn-custom/zfilevf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/ascii/ftn-custom/zvcreatef.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/string/stringv.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/impls/string/ftn-custom/zstringvf.o
           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/view.o
           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/flush.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/viewregall.o
           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/viewreg.o
           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/viewa.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/dlregispetsc.o
           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/viewers.o
           CC linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/dupl.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/ftn-auto/flushf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/ftn-auto/duplf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/ftn-auto/viewregf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/ftn-auto/viewf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/ftn-custom/zviewaf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/viewer/interface/ftn-custom/zviewasetf.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/xinit.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/ximage.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/xcolor.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/xops.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/xioerr.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/xtext.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/xtone.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/drawopenx.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/impls/x/ftn-custom/zdrawopenxf.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/impls/tikz/tikz.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/impls/image/drawimage.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/draw.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dcoor.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dtext.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dpoint.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dmarker.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dline.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dpause.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dbuff.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dflush.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dsave.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dclear.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dmouse.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dviewp.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dtri.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/drect.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/dellipse.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/interface/drawreg.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/drawregall.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dflushf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dclearf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dbufff.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dpausef.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/drectf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dmousef.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/drawf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dsavef.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dtrif.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dmarkerf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/drawregf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dcoorf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dviewpf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dpointf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dlinef.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dellipsef.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-auto/dtextf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-custom/zdrawf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-custom/zdrawregf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-custom/zdtextf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/interface/ftn-custom/zdtrif.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/axis.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/lg.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/dscatter.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/hists.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/zoom.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/cmap.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/lgc.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/axisc.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/bars.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/image.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-auto/lgf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-auto/axisf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-auto/histsf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-auto/axiscf.o
           CC linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-auto/lgcf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-auto/barsf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-auto/dscatterf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-custom/zaxisf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-custom/zlgcf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/draw/utils/ftn-custom/zzoomf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/random/impls/rander48/rander48.o
           CC linux-gnu-c-opt/obj/src/sys/classes/random/impls/rand/rand.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/random/impls/rand48/rand48.o
           CC linux-gnu-c-opt/obj/src/sys/classes/random/interface/random.o
           CC linux-gnu-c-opt/obj/src/sys/classes/random/interface/randreg.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/random/interface/dlregisrand.o
           CC linux-gnu-c-opt/obj/src/sys/classes/random/interface/randomc.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/random/interface/ftn-auto/randomf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/random/interface/ftn-auto/randomcf.o
           CC
linux-gnu-c-opt/obj/src/sys/classes/random/interface/ftn-custom/zrandomf.o
           CC linux-gnu-c-opt/obj/src/sys/classes/bag/bag.o
           CC linux-gnu-c-opt/obj/src/sys/classes/bag/ftn-auto/bagf.o
           CC linux-gnu-c-opt/obj/src/sys/classes/bag/f90-custom/zbagf90.o
           CC linux-gnu-c-opt/obj/src/sys/classes/bag/ftn-custom/zbagf.o
           CC linux-gnu-c-opt/obj/src/sys/time/cputime.o
           CC linux-gnu-c-opt/obj/src/sys/time/fdate.o
           CC linux-gnu-c-opt/obj/src/sys/time/ftn-auto/cputimef.o
           CC linux-gnu-c-opt/obj/src/sys/time/ftn-custom/zptimef.o
           CC linux-gnu-c-opt/obj/src/sys/totalview/tv_data_display.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/ffpath.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/ftest.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/ghome.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/mpiuopen.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/rpath.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/fpath.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/fwd.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/grpath.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/mprint.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/sysio.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/fretrieve.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/smatlab.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/fdir.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-auto/sysiof.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-auto/mpiuopenf.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-custom/zghomef.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-custom/zmpiuopenf.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-custom/zmprintf.o
           CC linux-gnu-c-opt/obj/src/sys/fileio/ftn-custom/zsysiof.o
           CC linux-gnu-c-opt/obj/src/sys/webclient/client.o
           CC linux-gnu-c-opt/obj/src/sys/webclient/google.o
           CC linux-gnu-c-opt/obj/src/sys/webclient/box.o
           CC linux-gnu-c-opt/obj/src/sys/webclient/textbelt.o
           CC linux-gnu-c-opt/obj/src/sys/webclient/globus.o
           CC linux-gnu-c-opt/obj/src/sys/f90-src/f90_cwrap.o
           CC linux-gnu-c-opt/obj/src/vec/is/utils/isio.o
           CC linux-gnu-c-opt/obj/src/vec/is/utils/isltog.o
           CC linux-gnu-c-opt/obj/src/vec/is/utils/pmap.o
           CC linux-gnu-c-opt/obj/src/vec/is/utils/vsectionis.o
           CC linux-gnu-c-opt/obj/src/vec/is/utils/ftn-auto/isltogf.o
           CC linux-gnu-c-opt/obj/src/vec/is/utils/ftn-auto/pmapf.o
           CC linux-gnu-c-opt/obj/src/vec/is/utils/ftn-auto/vsectionisf.o
           CC linux-gnu-c-opt/obj/src/vec/is/utils/f90-custom/zisltogf90.o
           CC
linux-gnu-c-opt/obj/src/vec/is/utils/f90-custom/zvsectionisf90.o
           CC linux-gnu-c-opt/obj/src/vec/is/utils/ftn-custom/zisltogf.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/impls/f90-custom/zblockf90.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/impls/stride/stride.o
           CC
linux-gnu-c-opt/obj/src/vec/is/is/impls/stride/ftn-auto/stridef.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/impls/block/block.o
           CC
linux-gnu-c-opt/obj/src/vec/is/is/impls/block/ftn-auto/blockf.o
           CC
linux-gnu-c-opt/obj/src/vec/is/is/impls/block/ftn-custom/zblockf.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/impls/general/general.o
           CC
linux-gnu-c-opt/obj/src/vec/is/is/impls/general/ftn-auto/generalf.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/interface/index.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/interface/isregall.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/interface/isreg.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/interface/ftn-auto/indexf.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/interface/ftn-auto/isregf.o
           CC
linux-gnu-c-opt/obj/src/vec/is/is/interface/f90-custom/zindexf90.o
           CC
linux-gnu-c-opt/obj/src/vec/is/is/interface/ftn-custom/zindexf.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/iscomp.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/iscoloring.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/isdiff.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/isblock.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/ftn-auto/isblockf.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/ftn-auto/isdifff.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/ftn-auto/iscoloringf.o
           CC linux-gnu-c-opt/obj/src/vec/is/is/utils/ftn-auto/iscompf.o
           CC
linux-gnu-c-opt/obj/src/vec/is/is/utils/f90-custom/ziscoloringf90.o
           CC
linux-gnu-c-opt/obj/src/vec/is/is/utils/ftn-custom/ziscoloringf.o
           CC
linux-gnu-c-opt/obj/src/vec/is/ao/impls/memscalable/aomemscalable.o
           CC linux-gnu-c-opt/obj/src/vec/is/ao/impls/mapping/aomapping.o
           CC
linux-gnu-c-opt/obj/src/vec/is/ao/impls/mapping/ftn-auto/aomappingf.o
           CC
linux-gnu-c-opt/obj/src/vec/is/ao/impls/mapping/ftn-custom/zaomappingf.o
           CC linux-gnu-c-opt/obj/src/vec/is/ao/impls/basic/aobasic.o
           CC
linux-gnu-c-opt/obj/src/vec/is/ao/impls/basic/ftn-custom/zaobasicf.o
           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/ao.o
           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/dlregisdm.o
           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/aoreg.o
           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/aoregall.o
           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/ftn-auto/aof.o
           CC linux-gnu-c-opt/obj/src/vec/is/ao/interface/ftn-custom/zaof.o
           CC linux-gnu-c-opt/obj/src/vec/is/sf/impls/window/sfwindow.o
           CC linux-gnu-c-opt/obj/src/vec/is/sf/impls/basic/sfbasic.o
           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/dlregissf.o
           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/sfregi.o
           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/sf.o
           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/sftype.o
           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/ftn-auto/sff.o
           CC linux-gnu-c-opt/obj/src/vec/is/sf/interface/ftn-custom/zsf.o
           CC linux-gnu-c-opt/obj/src/vec/pf/impls/constant/const.o
           CC linux-gnu-c-opt/obj/src/vec/pf/impls/string/cstring.o
           CC linux-gnu-c-opt/obj/src/vec/pf/interface/pf.o
           CC linux-gnu-c-opt/obj/src/vec/pf/interface/pfall.o
           CC linux-gnu-c-opt/obj/src/vec/pf/interface/ftn-auto/pff.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/shared/shvec.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/shared/ftn-auto/shvecf.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/nest/vecnest.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/nest/ftn-auto/vecnestf.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/bvec2.o
           CC
linux-gnu-c-opt/obj/src/vec/vec/impls/nest/ftn-custom/zvecnestf.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/bvec1.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/dvec2.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/vseqcr.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/bvec3.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/ftn-custom/zbvec2f.o
           CC
linux-gnu-c-opt/obj/src/vec/vec/impls/seq/ftn-custom/zvsectionf.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/seq/ftn-auto/vseqcrf.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/pbvec.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/pdvec.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/pvec2.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/vmpicr.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/commonmpvec.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/ftn-auto/pbvecf.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/ftn-auto/vmpicrf.o
           CC
linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/ftn-auto/commonmpvecf.o
           CC linux-gnu-c-opt/obj/src/vec/vec/impls/mpi/ftn-custom/zpbvecf.o
           CC linux-gnu-c-opt/obj/src/vec/vec/interface/vector.o
           CC linux-gnu-c-opt/obj/src/vec/vec/interface/veccreate.o
           CC linux-gnu-c-opt/obj/src/vec/vec/interface/vecreg.o
           CC linux-gnu-c-opt/obj/src/vec/vec/interface/vecregall.o
           CC linux-gnu-c-opt/obj/src/vec/vec/interface/dlregisvec.o
           CC linux-gnu-c-opt/obj/src/vec/vec/interface/rvector.o
           CC linux-gnu-c-opt/obj/src/vec/vec/interface/ftn-auto/vectorf.o
           CC linux-gnu-c-opt/obj/src/vec/vec/interface/ftn-auto/rvectorf.o
           CC
linux-gnu-c-opt/obj/src/vec/vec/interface/ftn-auto/veccreatef.o
           CC
linux-gnu-c-opt/obj/src/vec/vec/interface/f90-custom/zvectorf90.o
           CC
linux-gnu-c-opt/obj/src/vec/vec/interface/ftn-custom/zvecregf.o
           CC
linux-gnu-c-opt/obj/src/vec/vec/interface/ftn-custom/zvectorf.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vinv.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vscat.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vpscat.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vecio.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/comb.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vecstash.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vecmpitoseq.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vecs.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/vsection.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/projection.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/vecmpitoseqf.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/vpscatf.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/veciof.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/vinvf.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/projectionf.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/combf.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-auto/vscatf.o
           CC
linux-gnu-c-opt/obj/src/vec/vec/utils/f90-custom/zvsectionf90.o
           CC linux-gnu-c-opt/obj/src/vec/vec/utils/ftn-custom/zvscatf.o
           CC linux-gnu-c-opt/obj/src/mat/ftn-custom/zmat.o
           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/color.o
           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/degr.o
           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/dsm.o
           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/ido.o
           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/numsrt.o
           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/seq.o
           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/setr.o
           CC linux-gnu-c-opt/obj/src/mat/color/impls/minpack/slo.o
           CC linux-gnu-c-opt/obj/src/mat/color/impls/natural/natural.o
           CC linux-gnu-c-opt/obj/src/mat/color/impls/jp/jp.o
           CC linux-gnu-c-opt/obj/src/mat/color/impls/power/power.o
           CC linux-gnu-c-opt/obj/src/mat/color/impls/greedy/greedy.o
           CC linux-gnu-c-opt/obj/src/mat/color/interface/matcoloring.o
           CC linux-gnu-c-opt/obj/src/mat/color/interface/matcoloringregi.o
           CC
linux-gnu-c-opt/obj/src/mat/color/interface/ftn-auto/matcoloringf.o
           CC
linux-gnu-c-opt/obj/src/mat/color/interface/ftn-custom/zmatcoloringf.o
           CC linux-gnu-c-opt/obj/src/mat/color/utils/bipartite.o
           CC linux-gnu-c-opt/obj/src/mat/color/utils/valid.o
           CC linux-gnu-c-opt/obj/src/mat/color/utils/weights.o
           CC linux-gnu-c-opt/obj/src/mat/partition/partition.o
           CC linux-gnu-c-opt/obj/src/mat/partition/spartition.o
           CC
linux-gnu-c-opt/obj/src/mat/partition/impls/hierarchical/hierarchical.o
           CC linux-gnu-c-opt/obj/src/mat/partition/impls/scotch/scotch.o
           CC
linux-gnu-c-opt/obj/src/mat/partition/impls/scotch/ftn-auto/scotchf.o
           CC linux-gnu-c-opt/obj/src/mat/partition/impls/chaco/chaco.o
           CC
linux-gnu-c-opt/obj/src/mat/partition/impls/chaco/ftn-auto/chacof.o
           CC linux-gnu-c-opt/obj/src/mat/partition/ftn-auto/partitionf.o
           CC linux-gnu-c-opt/obj/src/mat/partition/ftn-custom/zpartitionf.o
           CC linux-gnu-c-opt/obj/src/mat/coarsen/coarsen.o
           CC linux-gnu-c-opt/obj/src/mat/coarsen/scoarsen.o
           CC linux-gnu-c-opt/obj/src/mat/coarsen/impls/hem/hem.o
           CC linux-gnu-c-opt/obj/src/mat/coarsen/impls/mis/mis.o
           CC linux-gnu-c-opt/obj/src/mat/coarsen/ftn-auto/coarsenf.o
           CC linux-gnu-c-opt/obj/src/mat/interface/matrix.o
           CC linux-gnu-c-opt/obj/src/mat/interface/mhas.o
           CC linux-gnu-c-opt/obj/src/mat/interface/matreg.o
           CC linux-gnu-c-opt/obj/src/mat/interface/matregis.o
           CC linux-gnu-c-opt/obj/src/mat/interface/matnull.o
           CC linux-gnu-c-opt/obj/src/mat/interface/dlregismat.o
           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-auto/matrixf.o
           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-auto/mhasf.o
           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-auto/matnullf.o
           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-custom/zmatregf.o
           CC linux-gnu-c-opt/obj/src/mat/interface/f90-custom/zmatrixf90.o
           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-custom/zmatrixf.o
           CC linux-gnu-c-opt/obj/src/mat/interface/ftn-custom/zmatnullf.o
           CC linux-gnu-c-opt/obj/src/mat/matfd/fdmatrix.o
           CC linux-gnu-c-opt/obj/src/mat/matfd/ftn-auto/fdmatrixf.o
           CC linux-gnu-c-opt/obj/src/mat/matfd/ftn-custom/zfdmatrixf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/submat/submat.o
           CC linux-gnu-c-opt/obj/src/mat/impls/submat/ftn-auto/submatf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/is/matis.o
           CC linux-gnu-c-opt/obj/src/mat/impls/is/ftn-auto/matisf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/fft/fft.o
           CC linux-gnu-c-opt/obj/src/mat/impls/fft/ftn-custom/zfftf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baij2.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact2.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgedi.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa3.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa4.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa5.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa2.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa6.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/dgefa7.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/aijbaij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact3.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact4.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact5.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact7.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact9.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact11.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijfact13.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijsolvtrannat.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijsolvtran.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijsolv.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/baijsolvnat.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/ftn-auto/baijf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/ftn-custom/zbaijf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/bstream/bstream.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/seq/bstream/bstrmfact.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/mpibaij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/mmbaij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/baijov.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/mpb_baij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/ftn-auto/mpibaijf.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/ftn-custom/zmpibaijf.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/baij/mpi/bstream/mpibstream.o
           CC linux-gnu-c-opt/obj/src/mat/impls/dense/seq/dense.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/dense/seq/ftn-custom/zdensef.o
           CC linux-gnu-c-opt/obj/src/mat/impls/dense/mpi/mpidense.o
           CC linux-gnu-c-opt/obj/src/mat/impls/dense/mpi/mmdense.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/dense/mpi/ftn-auto/mpidensef.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/dense/mpi/ftn-custom/zmpidensef.o
           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/mffd.o
           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/mffddef.o
           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/mfregis.o
           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/wp.o
           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/ftn-auto/mffdf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/ftn-auto/wpf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/ftn-auto/mffddeff.o
           CC linux-gnu-c-opt/obj/src/mat/impls/mffd/ftn-custom/zmffdf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/composite/mcomposite.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/composite/ftn-auto/mcompositef.o
           CC linux-gnu-c-opt/obj/src/mat/impls/adj/mpi/mpiadj.o
           CC linux-gnu-c-opt/obj/src/mat/impls/adj/mpi/ftn-auto/mpiadjf.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/adj/mpi/ftn-custom/zmpiadjf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/maij/maij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/maij/ftn-auto/maijf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/lrc/lrc.o
           CC linux-gnu-c-opt/obj/src/mat/impls/lrc/ftn-auto/lrcf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/shell/shell.o
           CC linux-gnu-c-opt/obj/src/mat/impls/shell/shellcnv.o
           CC linux-gnu-c-opt/obj/src/mat/impls/shell/ftn-auto/shellf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/shell/ftn-custom/zshellf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/normal/normm.o
           CC linux-gnu-c-opt/obj/src/mat/impls/normal/normmh.o
           CC linux-gnu-c-opt/obj/src/mat/impls/normal/ftn-auto/normmhf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/normal/ftn-auto/normmf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/python/pythonmat.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/python/ftn-custom/zpythonmf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/nest/matnest.o
           CC linux-gnu-c-opt/obj/src/mat/impls/nest/ftn-auto/matnestf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/nest/ftn-custom/zmatnestf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/transpose/transm.o
           CC linux-gnu-c-opt/obj/src/mat/impls/transpose/htransm.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/transpose/ftn-auto/htransmf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/transpose/ftn-auto/transmf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/localref/mlocalref.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/localref/ftn-auto/mlocalreff.o
           CC linux-gnu-c-opt/obj/src/mat/impls/blockmat/seq/blockmat.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaij2.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact2.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sro.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact3.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact4.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact5.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact6.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact7.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact8.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact9.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact10.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact11.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbaijfact12.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/aijsbaij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/ftn-auto/sbaijf.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/ftn-custom/zsbaijf.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbstream/sbstream.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/sbaij/seq/sbstream/sbstrmfact.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/mpisbaij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/mmsbaij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/sbaijov.o
           CC linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/mpiaijsbaij.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/ftn-auto/mpisbaijf.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/ftn-custom/zmpisbaijf.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/sbaij/mpi/sbstream/mpisbstream.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/aij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/aijfact.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/ij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/fdaij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/matmatmult.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/symtranspose.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/matptap.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/matrart.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/inode.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/inode2.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/matmatmatmult.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/aij/seq/mattransposematmult.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/ftn-custom/zaijf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/bas/basfactor.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/bas/spbas.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/csrperm/csrperm.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/crl/crl.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/seq/ftn-auto/aijf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpiaij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mmaij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpiaijpc.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpiov.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/fdmpiaij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpiptap.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpimatmatmult.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpb_aij.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpimatmatmatmult.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/mpimattransposematmult.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/ftn-custom/zmpiaijf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/csrperm/mpicsrperm.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/ftn-auto/mpiaijf.o
           CC linux-gnu-c-opt/obj/src/mat/impls/aij/mpi/crl/mcrl.o
           CC linux-gnu-c-opt/obj/src/mat/impls/scatter/mscatter.o
           CC linux-gnu-c-opt/obj/src/mat/impls/scatter/ftn-auto/mscatterf.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/preallocator/matpreallocator.o
           CC
linux-gnu-c-opt/obj/src/mat/impls/preallocator/ftn-auto/matpreallocatorf.o
           CC linux-gnu-c-opt/obj/src/mat/order/sp1wd.o
           CC linux-gnu-c-opt/obj/src/mat/order/spnd.o
           CC linux-gnu-c-opt/obj/src/mat/order/spqmd.o
           CC linux-gnu-c-opt/obj/src/mat/order/sprcm.o
           CC linux-gnu-c-opt/obj/src/mat/order/sorder.o
           CC linux-gnu-c-opt/obj/src/mat/order/spectral.o
           CC linux-gnu-c-opt/obj/src/mat/order/sregis.o
           CC linux-gnu-c-opt/obj/src/mat/order/degree.o
           CC linux-gnu-c-opt/obj/src/mat/order/fnroot.o
           CC linux-gnu-c-opt/obj/src/mat/order/genqmd.o
           CC linux-gnu-c-opt/obj/src/mat/order/qmdqt.o
           CC linux-gnu-c-opt/obj/src/mat/order/rcm.o
           CC linux-gnu-c-opt/obj/src/mat/order/fn1wd.o
           CC linux-gnu-c-opt/obj/src/mat/order/gen1wd.o
           CC linux-gnu-c-opt/obj/src/mat/order/genrcm.o
           CC linux-gnu-c-opt/obj/src/mat/order/qmdrch.o
           CC linux-gnu-c-opt/obj/src/mat/order/rootls.o
           CC linux-gnu-c-opt/obj/src/mat/order/fndsep.o
           CC linux-gnu-c-opt/obj/src/mat/order/gennd.o
           CC linux-gnu-c-opt/obj/src/mat/order/qmdmrg.o
           CC linux-gnu-c-opt/obj/src/mat/order/qmdupd.o
           CC linux-gnu-c-opt/obj/src/mat/order/wbm.o
           CC linux-gnu-c-opt/obj/src/mat/order/ftn-auto/spectralf.o
           CC linux-gnu-c-opt/obj/src/mat/order/ftn-custom/zsorderf.o
           CC linux-gnu-c-opt/obj/src/mat/utils/convert.o
           CC linux-gnu-c-opt/obj/src/mat/utils/matstash.o
           CC linux-gnu-c-opt/obj/src/mat/utils/axpy.o
           CC linux-gnu-c-opt/obj/src/mat/utils/zerodiag.o
           CC linux-gnu-c-opt/obj/src/mat/utils/getcolv.o
           CC linux-gnu-c-opt/obj/src/mat/utils/gcreate.o
           CC linux-gnu-c-opt/obj/src/mat/utils/freespace.o
           CC linux-gnu-c-opt/obj/src/mat/utils/compressedrow.o
           CC linux-gnu-c-opt/obj/src/mat/utils/multequal.o
           CC linux-gnu-c-opt/obj/src/mat/utils/matstashspace.o
           CC linux-gnu-c-opt/obj/src/mat/utils/pheap.o
           CC linux-gnu-c-opt/obj/src/mat/utils/bandwidth.o
           CC linux-gnu-c-opt/obj/src/mat/utils/overlapsplit.o
           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/bandwidthf.o
           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/zerodiagf.o
           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/getcolvf.o
           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/axpyf.o
           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/gcreatef.o
           CC linux-gnu-c-opt/obj/src/mat/utils/ftn-auto/multequalf.o
           CC linux-gnu-c-opt/obj/src/dm/label/dmlabel.o
           CC linux-gnu-c-opt/obj/src/dm/label/ftn-auto/dmlabelf.o
           CC linux-gnu-c-opt/obj/src/dm/label/ftn-custom/zdmlabel.o
           CC linux-gnu-c-opt/obj/src/dm/interface/dm.o
           CC linux-gnu-c-opt/obj/src/dm/interface/dmregall.o
           CC linux-gnu-c-opt/obj/src/dm/interface/dmget.o
           CC linux-gnu-c-opt/obj/src/dm/interface/dmi.o
           CC linux-gnu-c-opt/obj/src/dm/interface/dlregisdmdm.o
           CC linux-gnu-c-opt/obj/src/dm/interface/ftn-auto/dmf.o
           CC linux-gnu-c-opt/obj/src/dm/interface/ftn-auto/dmgetf.o
           CC linux-gnu-c-opt/obj/src/dm/interface/ftn-custom/zdmf.o
           CC linux-gnu-c-opt/obj/src/dm/interface/ftn-custom/zdmgetf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/shell/dmshell.o
           CC linux-gnu-c-opt/obj/src/dm/impls/shell/ftn-auto/dmshellf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/shell/ftn-custom/zdmshellf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/network/networkcreate.o
           CC linux-gnu-c-opt/obj/src/dm/impls/network/network.o
           CC linux-gnu-c-opt/obj/src/dm/impls/network/networkmonitor.o
           CC
linux-gnu-c-opt/obj/src/dm/impls/network/ftn-auto/networkmonitorf.o
           CC
linux-gnu-c-opt/obj/src/dm/impls/network/ftn-auto/networkcreatef.o
           CC linux-gnu-c-opt/obj/src/dm/impls/network/ftn-auto/networkf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/composite/pack.o
           CC linux-gnu-c-opt/obj/src/dm/impls/composite/packm.o
           CC linux-gnu-c-opt/obj/src/dm/impls/composite/ftn-auto/packf.o
           CC
linux-gnu-c-opt/obj/src/dm/impls/composite/f90-custom/zfddaf90.o
           CC linux-gnu-c-opt/obj/src/dm/impls/composite/ftn-custom/zfddaf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/da2.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/da1.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/da3.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/daghost.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dacorn.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dagtol.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/daltol.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/daindex.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dascatter.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dacreate.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dadestroy.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dalocal.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dadist.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/daview.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dasub.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/gr1.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/gr2.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dagtona.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dainterp.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dapf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dagetarray.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dagetelem.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/da.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dareg.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/fdda.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/grvtk.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dageometry.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dadd.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/dapreallocate.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dageometryf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/daghostf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dagtonaf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dagtolf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dagetarrayf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dadistf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/gr1f.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/daddf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dapreallocatef.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dacornf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/daindexf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/daf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/fddaf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dalocalf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dacreatef.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-auto/dainterpf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/f90-custom/zda1f90.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zdaf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zda1f.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zda2f.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zda3f.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zdacornf.o
           CC
linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zdagetscatterf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zdaviewf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/da/ftn-custom/zdaindexf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/redundant/dmredundant.o
           CC
linux-gnu-c-opt/obj/src/dm/impls/redundant/ftn-auto/dmredundantf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexcreate.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plex.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexpartition.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexrefine.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexdistribute.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexcoarsen.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexinterpolate.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexpreallocate.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexreorder.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexgeometry.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexsubmesh.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexhdf5.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexexodusii.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexgmsh.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexfluent.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexcgns.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexvtk.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexpoint.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexvtu.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexfem.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexindices.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plextree.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexgenerate.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexorient.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/plexnatural.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexcgnsf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexpointf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexindicesf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexcreatef.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexgeneratef.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexsubmeshf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexorientf.o
           CC
linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexpartitionf.o
           CC
linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexinterpolatef.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexreorderf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plextreef.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexrefinef.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexfemf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexnaturalf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexgmshf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexgeometryf.o
           CC
linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexdistributef.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-auto/plexexodusiif.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/f90-custom/zplexf90.o
           CC
linux-gnu-c-opt/obj/src/dm/impls/plex/f90-custom/zplexgeometryf90.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplex.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplexcreate.o
           CC
linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplexdistribute.o
           CC
linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplexinterpolate.o
           CC
linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplexsubmesh.o
           CC
linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplexexodusii.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplexgmsh.o
           CC linux-gnu-c-opt/obj/src/dm/impls/plex/ftn-custom/zplexfluent.o
           CC linux-gnu-c-opt/obj/src/dm/impls/sliced/sliced.o
           CC linux-gnu-c-opt/obj/src/dm/impls/forest/forest.o
           CC linux-gnu-c-opt/obj/src/dm/impls/forest/ftn-auto/forestf.o
           CC linux-gnu-c-opt/obj/src/dm/impls/patch/patchcreate.o
           CC linux-gnu-c-opt/obj/src/dm/impls/patch/patch.o
           CC linux-gnu-c-opt/obj/src/dm/impls/patch/ftn-auto/patchcreatef.o
           CC linux-gnu-c-opt/obj/src/dm/dt/interface/dt.o
           CC linux-gnu-c-opt/obj/src/dm/dt/interface/dtfe.o
           CC linux-gnu-c-opt/obj/src/dm/dt/interface/dtfv.o
           CC linux-gnu-c-opt/obj/src/dm/dt/interface/dtds.o
           CC linux-gnu-c-opt/obj/src/dm/dt/interface/ftn-auto/dtdsf.o
           CC linux-gnu-c-opt/obj/src/dm/dt/interface/ftn-auto/dtf.o
           CC linux-gnu-c-opt/obj/src/dm/dt/interface/ftn-auto/dtfvf.o
           CC linux-gnu-c-opt/obj/src/dm/dt/interface/ftn-auto/dtfef.o
           CC linux-gnu-c-opt/obj/src/dm/dt/interface/f90-custom/zdtf90.o
           CC linux-gnu-c-opt/obj/src/dm/dt/interface/f90-custom/zdtdsf90.o
           CC linux-gnu-c-opt/obj/src/dm/dt/interface/ftn-custom/zdtf.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bddc/bddcprivate.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bddc/bddc.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bddc/bddcgraph.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bddc/bddcscalingbasic.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bddc/bddcnullspace.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bddc/bddcfetidp.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bddc/bddcschurs.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bddc/ftn-auto/bddcf.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/lsc/lsc.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/bjacobi/bjacobi.o
           CC
linux-gnu-c-opt/obj/src/ksp/pc/impls/bjacobi/ftn-auto/bjacobif.o
           CC
linux-gnu-c-opt/obj/src/ksp/pc/impls/bjacobi/ftn-custom/zbjacobif.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/is/pcis.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/is/ftn-auto/pcisf.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/is/nn/nn.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/mg.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/fmg.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/smg.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/mgfunc.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/ftn-auto/mgfuncf.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/ftn-auto/mgf.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/ftn-custom/zmgf.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/mg/ftn-custom/zmgfuncf.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/sor/sor.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/sor/ftn-auto/sorf.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/pbjacobi/pbjacobi.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/cp/cp.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/eisens/eisen.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/eisens/ftn-auto/eisenf.o
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/telescope/telescope.o
           CC
linux-gnu-c-opt/obj/src/ksp/pc/impls/telescope/telescope_dmda.o
           CC
linux-gnu-c-opt/obj/src/ksp/pc/impls/telescope/ftn-auto/telescopef.o
/home/acro018/software/PETSc/code/src/ksp/pc/impls/telescope/telescope.c: In
function ‘PCSetUp_Telescope’:
/home/acro018/software/PETSc/code/src/ksp/pc/impls/telescope/telescope.c:314:52:
error: ‘struct _p_PC’ has no member named ‘nonzero_guess’
function ‘PCApply_Telescope’:
/home/acro018/software/PETSc/code/src/ksp/pc/impls/telescope/telescope.c:420:9:
           CC linux-gnu-c-opt/obj/src/ksp/pc/impls/ksp/pcksp.o
make[2]: ***
[linux-gnu-c-opt/obj/src/ksp/pc/impls/telescope/telescope.o] Error 1
make[2]: *** Waiting for unfinished jobs....
/home/acro018/software/PETSc/code/src/ksp/pc/impls/telescope/telescope_dmda.c:
In function ‘PCTelescopeMatCreate_dmda’:
/home/acro018/software/PETSc/code/src/ksp/pc/impls/telescope/telescope_dmda.c:786:12:
warning: variable ‘Bk’ set but not used [-Wunused-but-set-variable]
In function ‘PCApply_Telescope_dmda’:
/home/acro018/software/PETSc/code/src/ksp/pc/impls/telescope/telescope_dmda.c:904:9:
make[2]: ***
[linux-gnu-c-opt/obj/src/ksp/pc/impls/telescope/telescope_dmda.o] Error 1
make[1]: *** [gnumake] Error 2
make[1]: Leaving directory `/home/acro018/software/PETSc/code'
**************************ERROR*************************************
   Error during compile, check linux-gnu-c-opt/lib/petsc/conf/make.log
   Send it and linux-gnu-c-opt/lib/petsc/conf/configure.log to
petsc-maint at mcs.anl.gov
Finishing at: Fri Mar 18 13:44:58 NZDT 2016
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 84611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160318/96f6119a/attachment.html>
