[petsc-dev] PETSc release soon, request for input on needed fixes or enhancements
Matthew Knepley
knepley at gmail.com
Thu Mar 3 15:52:48 CST 2016
On Thu, Mar 3, 2016 at 5:42 AM, Éric Chamberland <
Eric.Chamberland at giref.ulaval.ca> wrote:
> Hi,
> since last night, with petsc-master.tar.gz, it seems that "make install"
> is broken.
> Please have a look at these errors:
Satish, do you see this?
We had something like this before, but it was fixed.
Matt
> CC arch-linux2-c-debug/obj/src/tao/leastsquares/impls/pounders/gqt.o
> CLINKER /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/arch-linux2-c-debug/lib/libpetsc.so.3.06.3
> gmake[2]: Leaving directory `/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug'
> gmake[1]: Leaving directory `/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug'
> Now to install the libraries do:
> make PETSC_DIR=/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug PETSC_ARCH=arch-linux2-c-debug install
> *** Using PETSC_DIR=/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug PETSC_ARCH=arch-linux2-c-debug ***
> No cached configure in RDict at /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/arch-linux2-c-debug/lib/petsc/conf/RDict.db
> Traceback (most recent call last):
> File "./config/install.py", line 380, in <module>
> Installer(sys.argv[1:]).run()
> File "./config/install.py", line 373, in run
> self.runsetup()
> File "./config/install.py", line 334, in runsetup
> self.setup()
> File "./config/install.py", line 60, in setup
> self.setupModules()
> File "./config/install.py", line 51, in setupModules
> self.setCompilers = self.framework.require('config.setCompilers', None)
> AttributeError: 'NoneType' object has no attribute 'require'
> make: *** [install] Error 1
> Some useful logs:
> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/configure_2016.03.03.02h00m01s.loghttp://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2016.03.03.02h00m01s_RDict.loghttp://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2016.03.03.02h00m01s_default.log
> Thanks!
> Eric
> Le 16-02-27 15:36, Barry Smith a écrit :
> PETSc Users,
> We are planning the PETSc release 3.7 shortly. If you know of any bugs that need to be fixed or enhancements added before the release please let us know.
> You can think of the master branch of the PETSc repository obtainable with
> git clone https://bitbucket.org/petsc/petsc petsc
> as a release candidate for 3.7. Changes for the release are listed at http://www.mcs.anl.gov/petsc/documentation/changes/dev.html
> Thanks
> Barry
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160303/40bf1bc1/attachment.html>
