[petsc-dev] PETSc release soon, request for input on needed fixes or enhancements
Éric Chamberland Eric.Chamberland at giref.ulaval.ca
Thu Mar 3 05:42:44 CST 2016
since last night, with petsc-master.tar.gz, it seems that "make install"
is broken.
Please have a look at these errors:
          CC arch-linux2-c-debug/obj/src/tao/leastsquares/impls/pounders/gqt.o
      CLINKER /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/arch-linux2-c-debug/lib/libpetsc.so.3.06.3
gmake[2]: Leaving directory `/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug'
gmake[1]: Leaving directory `/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug'
Now to install the libraries do:
make PETSC_DIR=/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug PETSC_ARCH=arch-linux2-c-debug install
*** Using PETSC_DIR=/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug PETSC_ARCH=arch-linux2-c-debug ***
     No cached configure in RDict at /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/arch-linux2-c-debug/lib/petsc/conf/RDict.db
Traceback (most recent call last):
   File "./config/install.py", line 380, in <module>
     Installer(sys.argv[1:]).run()
   File "./config/install.py", line 373, in run
     self.runsetup()
   File "./config/install.py", line 334, in runsetup
     self.setup()
   File "./config/install.py", line 60, in setup
     self.setupModules()
   File "./config/install.py", line 51, in setupModules
     self.setCompilers  = self.framework.require('config.setCompilers',         None)
AttributeError: 'NoneType' object has no attribute 'require'
make: *** [install] Error 1
Some useful logs:
http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/configure_2016.03.03.02h00m01s.log
http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2016.03.03.02h00m01s_RDict.log
http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2016.03.03.02h00m01s_default.log
Thanks!
Eric
Le 16-02-27 15:36, Barry Smith a écrit :
>     PETSc Users,
>      We are planning the PETSc release 3.7 shortly. If you know of any bugs that need to be fixed or enhancements added before the release please let us know.
>      You can think of the master branch of the PETSc repository obtainable with
> git clone https://bitbucket.org/petsc/petsc petsc
> as a release candidate for 3.7. Changes for the release are listed at http://www.mcs.anl.gov/petsc/documentation/changes/dev.html
>     Thanks
>     Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160303/861ec92b/attachment.html>
