[petsc-dev] PETSc release soon, request for input on needed fixes or enhancements
Thu Mar 3 16:29:25 CST 2016
I tried a few builds - but I can't reproduce. So I do not know whats
going on here [and what the trigger is]..
Tried a configure command as close as possible to this one.. [and used
the nightlytarball aswell]
balay at es^/scratch/balay/petsc-master $ ./configure --prefix=/scratch/balay/petsc-install --with-mpi-compilers=1 --with-make-np=12 --with-shared-libraries=1 --download-openmpi --with-debugging=yes --with-mkl_pardiso=1 --with-mkl_pardiso-dir=$MKL --download-ml=yes --download-mumps=yes --download-superlu=yes --download-superlu_dist=yes --download-parmetis=yes --download-ptscotch=yes --download-metis=yes --download-suitesparse=yes --download-hypre=yes --with-scalapack=1 --with-scalapack-include=$MKL/include --with-scalapack-lib="-lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64" --with-blas-lapack-dir=$MKL --download-cmake
Satish
On Thu, 3 Mar 2016, Matthew Knepley wrote:
> On Thu, Mar 3, 2016 at 5:42 AM, Éric Chamberland <
> Eric.Chamberland at giref.ulaval.ca> wrote:
> > Hi,
> > since last night, with petsc-master.tar.gz, it seems that "make install"
> > is broken.
> > Please have a look at these errors:
> Satish, do you see this?
> We had something like this before, but it was fixed.
>   Matt
> >          CC arch-linux2-c-debug/obj/src/tao/leastsquares/impls/pounders/gqt.o
> >      CLINKER /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/arch-linux2-c-debug/lib/libpetsc.so.3.06.3
> > gmake[2]: Leaving directory `/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug'
> > gmake[1]: Leaving directory `/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug'
> > Now to install the libraries do:
> > make PETSC_DIR=/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug PETSC_ARCH=arch-linux2-c-debug install
> > *** Using PETSC_DIR=/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug PETSC_ARCH=arch-linux2-c-debug ***
> >     No cached configure in RDict at /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/arch-linux2-c-debug/lib/petsc/conf/RDict.db
> > Traceback (most recent call last):
> >   File "./config/install.py", line 380, in <module>
> >     Installer(sys.argv[1:]).run()
> >   File "./config/install.py", line 373, in run
> >     self.runsetup()
> >   File "./config/install.py", line 334, in runsetup
> >     self.setup()
> >   File "./config/install.py", line 60, in setup
> >     self.setupModules()
> >   File "./config/install.py", line 51, in setupModules
> >     self.setCompilers  = self.framework.require('config.setCompilers',         None)
> > AttributeError: 'NoneType' object has no attribute 'require'
> > make: *** [install] Error 1
> > Some useful logs:
> > http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/configure_2016.03.03.02h00m01s.loghttp://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2016.03.03.02h00m01s_RDict.loghttp://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2016.03.03.02h00m01s_default.log
> > Thanks!
> > Eric
> > Le 16-02-27 15:36, Barry Smith a écrit :
> >    PETSc Users,
> >     We are planning the PETSc release 3.7 shortly. If you know of any bugs that need to be fixed or enhancements added before the release please let us know.
> >     You can think of the master branch of the PETSc repository obtainable with
> > git clone https://bitbucket.org/petsc/petsc petsc
> > as a release candidate for 3.7. Changes for the release are listed at http://www.mcs.anl.gov/petsc/documentation/changes/dev.html
> >    Thanks
> >    Barry
