[petsc-dev] using visibility by default?
Jed Brown
jed at jedbrown.org
Thu Mar 3 03:25:19 CST 2016
Barry Smith <bsmith at mcs.anl.gov> writes:
> Jed,
> Any reason we should not turn on --with-visibility by default when it works?
I would like it turned on. One "downside" is that users can't simply
include a private header to hack something using private functions --
those symbols are actually private. (Of course you can still access the
structs.)
I have a PETSC_ARCH that uses visibility, so at least one of us has been
testing it.
> def checkVisibility(self):
> if self.argDB['with-visibility']:
> if not self.checkCompile('','__attribute__((visibility ("default"))) int foo(void);'):
> raise RuntimeError('Cannot use visibility attributes')
> self.addDefine('USE_VISIBILITY',1)
> Currently we don't seem to use it hence to what end?
> Barry
> I came across this because I noticed we currently had a huge amount of private symbols exposed for no apparent reason except lack of testing/use.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160303/4041b7e9/attachment.sig>
