[petsc-dev] DMGetOutputDM hangs on multiple procs
Sander Arens
Sander.Arens at ugent.be
Wed Jul 13 05:21:57 CDT 2016
Ah, great! Thanks, Matt.
On 13 July 2016 at 04:44, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jun 23, 2016 at 8:33 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Thu, Jun 23, 2016 at 5:46 AM, Sander Arens <Sander.Arens at ugent.be>
>> wrote:
>>> I noticed that DMGetOutputDM hangs when using multiple procs. The
>>> culprit is
>>> https://bitbucket.org/petsc/petsc/commits/c26acbdef0eedda92db6423afb8b38a1502ca0c8.
>>> This doesn't work when one or more procs don't have any constraints
>>> while others have, because the ones with constraints call DMClone
>>> (collective) while the other procs don't.
>> Yep, will have to make the constraint logic global. I can do this at the
>> PETSc Meeting
>> next week in Vienna.
> My timing was off, but the fix is in 'next' if you want to try it.
> Thanks,
> Matt
>> Thanks,
>> Matt
>>> Thanks,
>>> Sander
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160713/5d2fe550/attachment.html>
