[petsc-dev] DMGetOutputDM hangs on multiple procs
Sander Arens Sander.Arens at ugent.be
Tue Jul 26 06:22:32 CDT 2016
Hi Matt,
Could you please change MPI_LAND into MPI_LOR in the MPI_Allreduce function?
Sander
On 13 July 2016 at 12:21, Sander Arens <Sander.Arens at ugent.be> wrote:
> Ah, great! Thanks, Matt.
> On 13 July 2016 at 04:44, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jun 23, 2016 at 8:33 AM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Thu, Jun 23, 2016 at 5:46 AM, Sander Arens <Sander.Arens at ugent.be>
>>> wrote:
>>>> I noticed that DMGetOutputDM hangs when using multiple procs. The
>>>> culprit is
>>>> https://bitbucket.org/petsc/petsc/commits/c26acbdef0eedda92db6423afb8b38a1502ca0c8.
>>>> This doesn't work when one or more procs don't have any constraints
>>>> while others have, because the ones with constraints call DMClone
>>>> (collective) while the other procs don't.
>>> Yep, will have to make the constraint logic global. I can do this at the
>>> PETSc Meeting
>>> next week in Vienna.
>> My timing was off, but the fix is in 'next' if you want to try it.
>>   Thanks,
>>      Matt
>>>   Thanks,
>>>     Matt
>>>> Thanks,
>>>> Sander
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160726/18dc5b46/attachment.html>
