[petsc-dev] DMGetOutputDM hangs on multiple procs
Tue Jul 12 21:44:58 CDT 2016
On Thu, Jun 23, 2016 at 8:33 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jun 23, 2016 at 5:46 AM, Sander Arens <Sander.Arens at ugent.be>
> wrote:
>> I noticed that DMGetOutputDM hangs when using multiple procs. The culprit
>> is
>> https://bitbucket.org/petsc/petsc/commits/c26acbdef0eedda92db6423afb8b38a1502ca0c8.
>> This doesn't work when one or more procs don't have any constraints while
>> others have, because the ones with constraints call DMClone (collective)
>> while the other procs don't.
> Yep, will have to make the constraint logic global. I can do this at the
> PETSc Meeting
> next week in Vienna.
My timing was off, but the fix is in 'next' if you want to try it.
     Matt
>   Thanks,
>     Matt
>> Thanks,
>> Sander
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160712/2cef54b3/attachment.html>
