[petsc-dev] p4est configure error
Mark Adams
mfadams at lbl.gov
Thu Jul 7 17:14:13 CDT 2016
Well, this did not work as you suspected ... FYI, it seems to work
with-debugging=0.
On Thu, Jul 7, 2016 at 11:13 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> /bin/sh ./libtool --tag=CC --mode=link cc -no-ipo -g -O0 -o
> libb64/sc_b64enc libb64/libb64_sc_b64enc-b64enc.o ./src/libsc.la -lgomp
> libtool: link: cc -no-ipo -g -O0 -o libb64/sc_b64enc
> libb64/libb64_sc_b64enc-b64enc.o ./src/.libs/libsc.a
> /opt/gcc/5.2.0/snos/lib/../lib64/libgomp.so -lrt -ldl -Wl,-rpath
> -Wl,/opt/gcc/5.2.0/snos/lib/../lib64 -Wl,-rpath
> For some reason libtool is converting "-lgomp" into
> "/opt/gcc/5.2.0/snos/lib/../lib64/libgomp.so" - and giving an ld error.
> On my linux box - I see:
> /bin/sh ./libtool --tag=CC --mode=link mpicc -g3 -o libb64/sc_b64enc
> libb64/libb64_sc_b64enc-b64enc.o ./src/libsc.la -lgomp -lpthread -lz -lm
> libtool: link: mpicc -g3 -o libb64/sc_b64enc
> libb64/libb64_sc_b64enc-b64enc.o ./src/.libs/libsc.a -lgomp -lpthread -lz
> -lm
> I don't really understand libtool - or this error..
> Satish
> On Thu, 7 Jul 2016, Tobin Isaac wrote:
> > Nope, different error: p4est autotools found an openmp library and tried
> to link it, but there's a shared/static mismatch. I'll try to get to the
> bottom of this.
> > On July 7, 2016 3:27:23 PM CDT, Mark Adams <mfadams at lbl.gov> wrote:
> > >I nuked and ran this twice:
> > >1013 rm -fr arch-xc30-dbg64-intel
> > > 1014 ../arch-xc30-dbg64-intel.py
> > > 1015 h
> > > 1016 ../arch-xc30-dbg64-intel.py
> > >Same error.
> > >On Thu, Jul 7, 2016 at 9:36 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > >> perhaps configure was not rerun - so a stale p4est was being used..
> > >> Satish
> > >> > p4est.py automatically pulls from whatever p4est branch I call
> > >'petsc'
> > >> > in my repo, so I don't see how this problem persists if you really
> > >> > nuked it.
> > >> > - Did you nuke the right directory?
> > >> > - Did you send me the right configure.log?
> > >> > - Is the new failure the same (the same stale p4est commit is being
> > >> > used)?
> > >> > On Thu, Jul 07, 2016 at 08:33:57PM +0200, Mark Adams wrote:
> > >> > > It sounds like I have not merged your fix. Should I pull from
> > >master?
> > >> > > I have nuked this many times.
> > >> > > On Thu, Jul 7, 2016 at 4:26 PM, Tobin Isaac <tisaac at uchicago.edu>
> > >> wrote:
> > >> > > > On Thu, Jul 07, 2016 at 03:16:40PM +0200, Mark Adams wrote:
> > >> > > > > p4est on Edison configures in w/o debugging, although I have
> > >to run
> > >> > > > > configure twice.
> > >> > > > > But with debugging it fails. I can not see any difference
> > >between
> > >> the
> > >> > > > two
> > >> > > > > configures other than debugging.
> > >> > > > > Mark
> > >> > > > The log shows that you are configuring a p4est commit (3d3e1)
> > >that is
> > >> > > > before the one I pushed specifically to avoid the fortran
> > >> > > > configuration error (f54bb3). Please clear the git.p4est
> > >directory,
> > >> > > > and confirm that you are configuring with the current 'petsc'
> > >branch
> > >> > > > of p4est (`grep 'checking Point version' configure.log` should
> > >show
> > >> > > > X.XXX-a9f22).
> > >> > > > Cheers,
> > >> > > > Toby
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160708/7edc8033/attachment.html>
