[petsc-dev] p4est configure error
Thu Jul 7 16:13:15 CDT 2016
/bin/sh ./libtool  --tag=CC   --mode=link cc  -no-ipo -g -O0   -o libb64/sc_b64enc libb64/libb64_sc_b64enc-b64enc.o ./src/libsc.la -lgomp
libtool: link: cc -no-ipo -g -O0 -o libb64/sc_b64enc libb64/libb64_sc_b64enc-b64enc.o  ./src/.libs/libsc.a /opt/gcc/5.2.0/snos/lib/../lib64/libgomp.so -lrt -ldl -Wl,-rpath -Wl,/opt/gcc/5.2.0/snos/lib/../lib64 -Wl,-rpath -Wl,/opt/gcc/5.2.0/snos/lib/../lib64
For some reason libtool is converting "-lgomp" into "/opt/gcc/5.2.0/snos/lib/../lib64/libgomp.so" - and giving an ld error.
On my linux box - I see:
/bin/sh ./libtool  --tag=CC   --mode=link mpicc  -g3   -o libb64/sc_b64enc libb64/libb64_sc_b64enc-b64enc.o ./src/libsc.la -lgomp -lpthread -lz -lm
libtool: link: mpicc -g3 -o libb64/sc_b64enc libb64/libb64_sc_b64enc-b64enc.o  ./src/.libs/libsc.a -lgomp -lpthread -lz -lm
I don't really understand libtool - or this error..
Satish
On Thu, 7 Jul 2016, Tobin Isaac wrote:
> Nope, different error: p4est autotools found an openmp library and tried to link it, but there's a shared/static mismatch.  I'll try to get to the bottom of this.
> On July 7, 2016 3:27:23 PM CDT, Mark Adams <mfadams at lbl.gov> wrote:
> >I nuked and ran this twice:
> >1013  rm -fr arch-xc30-dbg64-intel
> > 1014  ../arch-xc30-dbg64-intel.py
> > 1015  h
> > 1016  ../arch-xc30-dbg64-intel.py
> >Same error.
> >On Thu, Jul 7, 2016 at 9:36 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> perhaps configure was not rerun - so a stale p4est was being used..
> >> Satish
> >> > p4est.py automatically pulls from whatever p4est branch I call
> >'petsc'
> >> > in my repo, so I don't see how this problem persists if you really
> >> > nuked it.
> >> > - Did you nuke the right directory?
> >> > - Did you send me the right configure.log?
> >> > - Is the new failure the same (the same stale p4est commit is being
> >> >   used)?
> >> > On Thu, Jul 07, 2016 at 08:33:57PM +0200, Mark Adams wrote:
> >> > > It sounds like I have not merged your fix.  Should I pull from
> >master?
> >> > > I have nuked this many times.
> >> > > On Thu, Jul 7, 2016 at 4:26 PM, Tobin Isaac <tisaac at uchicago.edu>
> >> wrote:
> >> > > > On Thu, Jul 07, 2016 at 03:16:40PM +0200, Mark Adams wrote:
> >> > > > > p4est on Edison configures in w/o debugging, although I have
> >to run
> >> > > > > configure twice.
> >> > > > > But with debugging it fails.  I can not see any difference
> >between
> >> the
> >> > > > two
> >> > > > > configures other than debugging.
> >> > > > > Mark
> >> > > > The log shows that you are configuring a p4est commit (3d3e1)
> >that is
> >> > > > before the one I pushed specifically to avoid the fortran
> >> > > > configuration error (f54bb3).  Please clear the git.p4est
> >directory,
> >> > > > and confirm that you are configuring with the current 'petsc'
> >branch
> >> > > > of p4est (`grep 'checking Point version' configure.log` should
> >show
> >> > > > X.XXX-a9f22).
> >> > > > Cheers,
> >> > > >   Toby
