[petsc-dev] p4est configure error
Tobin Isaac
tisaac at uchicago.edu
Thu Jul 7 15:57:32 CDT 2016
Nope, different error: p4est autotools found an openmp library and tried to link it, but there's a shared/static mismatch. I'll try to get to the bottom of this.
On July 7, 2016 3:27:23 PM CDT, Mark Adams <mfadams at lbl.gov> wrote:
>I nuked and ran this twice:
>1013 rm -fr arch-xc30-dbg64-intel
> 1014 ../arch-xc30-dbg64-intel.py
> 1015 h
> 1016 ../arch-xc30-dbg64-intel.py
>Same error.
>On Thu, Jul 7, 2016 at 9:36 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> perhaps configure was not rerun - so a stale p4est was being used..
>> Satish
>> On Thu, 7 Jul 2016, Tobin Isaac wrote:
>> > p4est.py automatically pulls from whatever p4est branch I call
>'petsc'
>> > in my repo, so I don't see how this problem persists if you really
>> > nuked it.
>> > - Did you nuke the right directory?
>> > - Did you send me the right configure.log?
>> > - Is the new failure the same (the same stale p4est commit is being
>> > used)?
>> > On Thu, Jul 07, 2016 at 08:33:57PM +0200, Mark Adams wrote:
>> > > It sounds like I have not merged your fix. Should I pull from
>master?
>> > > I have nuked this many times.
>> > > On Thu, Jul 7, 2016 at 4:26 PM, Tobin Isaac <tisaac at uchicago.edu>
>> wrote:
>> > > > On Thu, Jul 07, 2016 at 03:16:40PM +0200, Mark Adams wrote:
>> > > > > p4est on Edison configures in w/o debugging, although I have
>to run
>> > > > > configure twice.
>> > > > > But with debugging it fails. I can not see any difference
>between
>> the
>> > > > two
>> > > > > configures other than debugging.
>> > > > > Mark
>> > > > The log shows that you are configuring a p4est commit (3d3e1)
>that is
>> > > > before the one I pushed specifically to avoid the fortran
>> > > > configuration error (f54bb3). Please clear the git.p4est
>directory,
>> > > > and confirm that you are configuring with the current 'petsc'
>branch
>> > > > of p4est (`grep 'checking Point version' configure.log` should
>show
>> > > > X.XXX-a9f22).
>> > > > Cheers,
>> > > > Toby
