[petsc-dev] p4est configure error
    Mark Adams
    mfadams at lbl.gov
    Thu Jul  7 15:43:59 CDT 2016
> > /usr/bin/ld: attempted static link of dynamic object
> `/opt/gcc/5.2.0/snos/lib/../lib64/libgomp.so'
> Looks like some libtool issue..
That is probably it. At NERSC, Cori does not have a libtool module (in
something else I assume) but it is required on Edison.  I was missing it,
> Satish
> On Thu, 7 Jul 2016, Mark Adams wrote:
> > I nuked and ran this twice:
> > 1013  rm -fr arch-xc30-dbg64-intel
> >  1014  ../arch-xc30-dbg64-intel.py
> >  1015  h
> >  1016  ../arch-xc30-dbg64-intel.py
> > Same error.
> > On Thu, Jul 7, 2016 at 9:36 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > perhaps configure was not rerun - so a stale p4est was being used..
> > > Satish
> > > On Thu, 7 Jul 2016, Tobin Isaac wrote:
> > > > p4est.py automatically pulls from whatever p4est branch I call
> 'petsc'
> > > > in my repo, so I don't see how this problem persists if you really
> > > > nuked it.
> > > > - Did you nuke the right directory?
> > > > - Did you send me the right configure.log?
> > > > - Is the new failure the same (the same stale p4est commit is being
> > > >   used)?
> > > > On Thu, Jul 07, 2016 at 08:33:57PM +0200, Mark Adams wrote:
> > > > > It sounds like I have not merged your fix.  Should I pull from
> master?
> > > > > I have nuked this many times.
> > > > > On Thu, Jul 7, 2016 at 4:26 PM, Tobin Isaac <tisaac at uchicago.edu>
> > > wrote:
> > > > > > On Thu, Jul 07, 2016 at 03:16:40PM +0200, Mark Adams wrote:
> > > > > > > p4est on Edison configures in w/o debugging, although I have
> to run
> > > > > > > configure twice.
> > > > > > > But with debugging it fails.  I can not see any difference
> between
> > > the
> > > > > > two
> > > > > > > configures other than debugging.
> > > > > > > Mark
> > > > > > The log shows that you are configuring a p4est commit (3d3e1)
> that is
> > > > > > before the one I pushed specifically to avoid the fortran
> > > > > > configuration error (f54bb3).  Please clear the git.p4est
> directory,
> > > > > > and confirm that you are configuring with the current 'petsc'
> branch
> > > > > > of p4est (`grep 'checking Point version' configure.log` should
> show
> > > > > > X.XXX-a9f22).
> > > > > > Cheers,
> > > > > >   Toby
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160707/bf42d835/attachment.html>
